Author Topic: 07 4" lift install  (Read 35376 times)
07 4" lift install
« Reply #15 on: March 04, 2012, 07:42:34 PM »
Shocks are fitting well?
Re: 07 4" lift install
« Reply #16 on: March 04, 2012, 11:52:03 PM »
fronts bolted on, rears didnt bolt on.
front steering stabilizer really isnt made to work with a skyjacker track bar relocation bracket, because the holes it uses are already used...
Road tested machine on new lift and rubber, good to go!
« Reply #17 on: March 05, 2012, 09:04:32 AM »
Hmmmm, did you use one of the stabilizers?
« Reply #18 on: March 05, 2012, 09:05:22 AM »
What did you do for the rears? Need some feedback to improve the design.
« Reply #19 on: March 05, 2012, 11:38:00 AM »
i made bar pins out of 3/4" bolts for the uppers-  3/4" is stupid big for shock eyes.  it would be nice if they came with bar pins.
for the lowers i drilled out the brackets to 3/4" holes, which was probably on the 1:1 factor of safety level.
« Reply #20 on: March 05, 2012, 11:53:26 AM »
3/4 holes should come with bushings to a normal common hole size. Even better would be a bushing assortment to common stock bolt sizes like 1/2 and 9/16 and the close metrics for the intended application.
« Reply #21 on: March 05, 2012, 12:21:43 PM »
bushings dont work with bar pins
« Reply #22 on: March 05, 2012, 01:18:54 PM »
how could a bushing not work?
oh, right, they flare out, and the bushing squishes around them, don't they?
I guess different bushings would have to be the answer then
« Reply #23 on: March 05, 2012, 01:29:49 PM »
actually now that you say that i probably could have taken a peice of poly tubing to slide over the bar pin.  that would be a cheap "soft" bushing that would work around the bar pin flare.  i really wasnt happy with what i did, and it wasted and hour of my time.
« Reply #24 on: March 05, 2012, 10:06:10 PM »
Picked up with a grinning customer!   8)
Ryan, whats the deal with charging that steering stabilizer.  jeep drives like a dream to 80mph, but when you hit a pot hole at like 40 there is just a little bit of shimmy for like 1-2 seconds.  i would have never noticed it because i drive shit trucks, but Anthony noticed it and showed me on one of our test drives...  not sure what could help that, maybe more toe? more dampening on the steering stab?
07 4" lift install
« Reply #25 on: March 05, 2012, 10:16:43 PM »
You can try upping the pressure to see if it helps.
Finding what the problem is would help more. :)
I would guess trac bar or bushing on a control arm.
« Reply #26 on: March 05, 2012, 10:24:02 PM »
everything was good and tight on track bar and all suspention components
« Reply #27 on: March 13, 2012, 09:08:31 AM »
Nitrogen pressure in the Profender stabilizer fixed it and all is well now!  I went over last night for a house call and some test and tune!
« Reply #28 on: March 13, 2012, 09:09:54 AM »
Front locker being dropped off today for this one too!
« Reply #29 on: April 20, 2012, 10:34:01 PM »
Aussie install done tonight along with a ujoint.  Snapped a wheel speed sensor that was seized.  No dealers or local parts stores have it.  FML.  Truck drives ok supprisingly.  Plugged the hole and its getting wheeled tomorrow!
