Author Topic: 07 4" lift install  (Read 35349 times)
07 4" lift install
« on: February 12, 2012, 07:32:52 PM »
this is the kit
http://www.cyberjeep.com/jk/pr/skyjacker-lift-kit-4-5-inch-classic-red
going in anthony's 4 door.
missing some parts, used lift.  should be interesting.
Re: 07 4" lift install
« Reply #1 on: February 14, 2012, 10:20:06 AM »
all the parts in the shop and ready to go minus tires.  looks like we got 99% of the missing parts filled in.
i need to order a 3/4 heim for his track bar to replace the junk one the kit has.
also need to track down a couple bushing inserts.
« Reply #2 on: February 14, 2012, 10:40:45 AM »
I have some 3/4 heims in stock.  :D
« Reply #3 on: February 14, 2012, 10:53:08 AM »
i need 1 right hand, dont need a bung
« Reply #4 on: February 14, 2012, 10:53:52 AM »
what did alex need to make your shocks fit to his JK?  inserts?
07 4" lift install
« Reply #5 on: February 14, 2012, 12:42:01 PM »
I will check stock.
Not sure what he did. He ever said they do fit somehow.
« Reply #6 on: February 14, 2012, 02:11:54 PM »
Alex needs bar pin eliminators
« Reply #7 on: February 14, 2012, 03:41:46 PM »
i was more concerned about the 3/4" hole in the ends of the shocks.....
« Reply #8 on: February 14, 2012, 09:28:32 PM »
have to make some calls tomorrow to skyjacker to get some replacement parts.  need 3 sleves and maybe a bushing or two.
replaced some zerks tonight, measured some stuff.
awl4928
« Reply #9 on: February 14, 2012, 11:31:03 PM »
If your talking about the eyes on the botom of the fronts they fit fine as is with the bushings they shipped with.  Just need a few washers on each side of the bushing to fill in space.   I have not squared away the rear yet.  Turns out they don't sell bar pin eliminators for studs.....so much for this weekends project.
07 4" lift install
« Reply #10 on: February 14, 2012, 11:47:14 PM »
I'm confused, all you need is a plate with a hole drilled in the middle of it
« Reply #11 on: February 15, 2012, 08:18:54 AM »
3/4" Heims look very small
« Reply #12 on: February 29, 2012, 02:30:43 PM »
next week!
« Reply #13 on: February 29, 2012, 02:55:47 PM »
I'll be stopping by to check this out next week.
« Reply #14 on: March 04, 2012, 08:26:50 AM »
starting on this today
