Projects place => Projects Section => Topic started by: etk300ex on January 24, 2025, 09:46:16 AM
New ride. 6-speed, 100k. New upper & lower control arms, tie rods, struts, front wheel bearings, cv shafts, front rotors, sway bar links, clutch, pilot and release bearing, MBRP cat back (sounds like shit lol).
must be a rough 100k for all of those parts.
That's NY. I've replaced all those same parts on my 06. Its cheaper to replace the entire control arms then just ball joints.
how's the corrosion situation? Hopefully better situation than the 06?
Frame is typical, new front end parts, body is much better. It just has one small spot starting above the driver rear wheel well.
One owner, have all service records since original sale from Nissan
(https://uploads.tapatalk-cdn.com/20250127/7346b24ceca57597e5ed8e8e86673c37.jpg)
Took the day off to check this thing out since its going to be real cold tomorrow. Straightened out the brush guard with some come-a-long action. Refastened both front inner-fenders that were just sitting in there, missing all fasteners. New marker light bulb. Checked all fluids, all full and clean. Ordered rear shocks, they are seriously rusty and a exhaust hanger that is broke. Inspection Wednesday, should be good to go. Ordered new radio, speakers, and a powered subwoofer.
Installed radio and door speakers. I sprung for the extra $27 to have Crutchfield solder the wiring kit together. That was well worth it, installed in less than 10 minutes. The exhaust sounds great but the drone is horrible. I can fit a short resonator in the tailpipe section, going to try that before replacement. Headlights suck, I should swap headlights with my old Frontier. Sweet ride, loving having a standard DD again!
Installed a Vibrant 10" resonator and it's wonderful!
Old Frontier sold
New rear shocks. New gas tank straps. New belt, tensioner, pulley. Front diff, rear diff and tcase fluids changed. New plugs, which requires removal of intake manifold. Should be good for another 100k!
Strong fuel smell in intake manifold. Is that normal?
(https://uploads.tapatalk-cdn.com/20250322/f896b4578b277a62924bbbbe45125a23.jpg)
i mean thats where the fuel goes so ya ;D
I mean in the upper piece where the throttle body is. I had to open the windows. With all the air that runs through the I didn’t expect it to smell that bad. I suppose that is still where the fuel is lol.
(https://uploads.tapatalk-cdn.com/20250322/46a938a29b38b02704c9682e2a34afcc.jpg)
Twice now I've fired this up to warm up and came back out to a cold truck. Key cycle and heat. I first thought blend door issue, but, it was already on hot both times. Would the blend door default to cold when shut down? Blend door works as it should any other time.
Mark will suggest a fix that'll have it warm, once.
I might second that.
Must have the key cycle to get heat, moving temp knob to cold and back to hot does nothing?
I've thankfully never had a modern HVAC issue, my stepper motors have all continued right on stepping. I could imagine that it would park one way or the other instead of staying put, to re-zero. but that sure seems like putting just about infinitely more cycles on it than it'd have otherwise and that seems very much not worth it.
This was two random times. Its works as it should any other time.
When it doesn't work, no, the temp knob doesn't change anything.
The blend door is very quite. If it happens again I will shut the engine off and see if its doing anything.
