Projects place => Projects Section => Topic started by: mr.mindless on May 21, 2020, 12:16:34 PM
Title: Dumb mower
Post by: mr.mindless on May 21, 2020, 12:16:34 PM
What could possibly go wrong?
Serious answers.
is it overkill? sure. I don't need 17 acres per hour cutting speed, and I'll surely not be able to achieve that anyway with trees and narrow spots.
But - could I get a functional similar hours/quality zero turn for less? I'm not sure. He already said he'd to $2200. I don't know that I can get him better than that.
Hoses are generic, hydro motors are generic.
blades and spindles could be tough
belts are generic
it's a Cummins and a Dana 60.
They sold this as a snowblower too, with hydro drive hubs on the steer axle. Doubt I can find those parts but it would be plenty of snowthrower to do all needs here if I could.
I think the parts issues are probably people who want to go to a dealer and buy a thing without thought.
The issue is the weight on my lawn. I don't know distribution but I'm guessing by tires at 60/40 front biased? engine is pretty far back though. Duals on the front may solve, or the rear steers may be an issue as well.
Would certainly take some time to learn how to drive it.
other down side is that if it doesn't work it'll probably take a good while to sell.
https://www.facebook.com/marketplace/item/1817172161749876/
Title: Re: Dumb mower
Post by: mr.mindless on May 21, 2020, 12:18:53 PM
http://www.howardpriceturf.com/specsheet_hydropower180.htm
Post by: mr.mindless on May 21, 2020, 04:48:16 PM
edging towards yes.
did a little more shopping. cheap $1000 runner zero turn sold in less than a day from craigslist this morning. all other comparables are more expensive than this even at 2200. can put 500 into it and still be cheaper than most zeros - either to have something way cooler or completely useless. that's the debate...
Post by: mr.mindless on May 21, 2020, 04:54:07 PM
this is the other "cheap" option - a 50" Ariens with a weak engine for $700
not that replacing an engine is cheap.
and 50" is small for my use, I think
https://rochester.craigslist.org/grd/d/rochester-ariens-zoom-2050-turn/7127860289.html
Post by: mr.mindless on May 21, 2020, 05:04:56 PM
Woods 20hp 60" $1200 2060hr
Seems underpowered.
https://www.facebook.com/marketplace/item/2708202726127618/
Post by: mr.mindless on May 21, 2020, 05:19:42 PM
$1500 cub cadet 27hp 60" 430hr
hour south of buffalo though :(
https://www.facebook.com/marketplace/item/567836030812161/
Hey Josh...
Post by: mr.mindless on May 21, 2020, 05:32:44 PM
I don't know how I missed this one. 72" 22hp diesel Jacobsen with 1900 hours, 4 miles from home, asking 2k
going to test drive at 10:00 tomorrow
https://www.facebook.com/marketplace/item/517627342521538
Post by: mr.mindless on May 21, 2020, 05:33:06 PM
I think that might be perfect.
Post by: TrailTamer on May 21, 2020, 05:45:24 PM
I’ve read that people have a great success with “dimple knobby” tires (the kind you see on Honda 3 wheelers) who had issues with zero turns on hills or soggy ground. Far more doable with that Jacobsen
Post by: Wingman on May 21, 2020, 06:00:20 PM
That is a great ad
Post by: mr.mindless on May 21, 2020, 06:09:55 PM
Good call Brett!
I’ve got a good feeling on this one. Excited. And unlike the batwing, not scared.
Post by: mr.mindless on May 22, 2020, 10:29:36 AM
It’s a winner. Getting cash now.
Post by: M4wdFab on May 22, 2020, 12:03:37 PM
o boy!
Post by: mr.mindless on May 22, 2020, 08:31:22 PM
Didn’t do continuous, so I don’t have a time. Probably 3.5-4hr? Got it stuck 3x, only when I got the drives in existing ruts from the Cub in wet.
Could use another 10-15hp in tall grass. Could use another 10mph for transit too. Top speed is only 8.
Wonder if I could turbo it?
I don’t know that the ATV tires would clean out. I think at tires are the only way to go if I want to upgrade.
Have to reverse up the big hill at the pond for weight transfer. Works once I figured the technique.
Met another neighbor, he drove the Deere the last time I got the Jacobsen stuck. Doug.
(https://uploads.tapatalk-cdn.com/20200523/513e789337f1595e7b9db08e57624279.jpg)
Post by: TrailTamer on May 22, 2020, 08:46:15 PM
Is it Rear discharged?
I wonder does it’s top speed changed when mower is running? If not, might can try find that extra oomph of flow to wheel motors for transit?
Post by: M4wdFab on May 22, 2020, 09:18:20 PM
hmm HP was first thing i thought of when i read that add.
i would take a look at the blades- a new set of blades or a quick sharpen with a flap wheel will do wonders for the mower.
Post by: M4wdFab on May 22, 2020, 09:20:55 PM
the hill is pretty good.  i couldnt side hill it, had to go up and over and only about 3' to spare from the pond when trying to slow down lol
how did it do out front with all the trees behind the pond?
Post by: mr.mindless on May 22, 2020, 10:19:49 PM
I didn’t duck between every tree. Too damn many.
That’s like an every third mow thing.
It retards downhill no problem! Not scared of the pond, it slows well.
Came with spare blades, just mowed with whatever is on it.
Highest deck setting diagramed on the deck is 4 or 4.5, i forget. I set it there. I think there are more holes and it may go higher if I read the manual. Far more complex to adjust height than my mid mount or your zero.
Got it for 1800, doesn’t need tires or a seat. Well cared for. Most of a tank of diesel too. I do need to fill that already though. Burned well over 1/2 tank.
Post by: mr.mindless on May 22, 2020, 10:23:07 PM
And yes it’s rear discharge. I don’t think deck motor steals much from wheel motors. Just wish for more hp to keep deck speed up on taller grass. I think 72” really needs more like 30hp to mow at 5+mph
Post by: mr.mindless on May 31, 2020, 06:32:45 PM
Put half a turn, then another quarter turn on the “smoke screw”. I may not need a turbo. Found another 5hp I bet. Whether that makes it 20 or 25hp now I don’t care. I think it might be enough.
If I get dissatisfied, I’ll put 2 more turns on it and make sure it’s thick black smoky enough to support more air. Then install a rotary muffler.
Got it stuck testing. Put my spare set of mowzer chains on it and rocked it out. Fun to do that in the mud. Mower a bit with chains on. Not bad. One got crooked so I took them off but they may make future appearances. I’m confident I’d have not gotten stuck in the first place if I were chained up.
Post by: TrailTamer on June 01, 2020, 09:02:06 AM
Excellent  8)
how exactly the 'traction assist pedal' work? did chains chew up your lawn on turns, though?
Post by: mr.mindless on June 01, 2020, 09:29:40 AM
it's a 3' turning radius or so, didn't do bad things when steering as tight as possible. reduced spin when turning increased speed when turning tight. inside tire clearly slips a fair bit. Clearance to the deck and to traction pedal linkage is an issue when chained up.
I'm curious what ag tires would be like. spare wheels would be nice. Shame the bolt patterns between the deere and jacobsen don't match, since drive tire size does match. Steer tire size might even match, didn't check.
traction pedal is a left tire brake, and that's it. It's not a locker engage that I'd hoped for. a right side brake with matching pedal was an option.
Post by: mr.mindless on June 01, 2020, 09:36:42 AM
no complaints at all after I finished mowing. If I see/hear my neighbor Mike go mow the vacant house I may join him, looks like that's a good 6-8" tall and would be a good test.
Post by: etk300ex on June 01, 2020, 09:54:45 AM
Thats great!
Post by: TrailTamer on June 03, 2020, 02:38:05 PM
my big girl is rear. It's not even though and that makes me not like it. It leaves cuttings in 2 stripes, where the three blades overlap. I think it's worse than side discharge for leaving clippings piles, and I think it's a big source of my bogging in tall grass, since it just fills up inside the deck. I do love it for edging though.
what type blades you're running now? and is the deck clean underneath? packed deck (less space for grass to fly around & re-cut and bog down also) and low lift dull blades tend to do that.
I get "Gator" blades whenever I need to buy a blade. worth the money, better mulching and for some reason they're much more resist to bending when hitting foreign objects.
Post by: mr.mindless on June 03, 2020, 04:50:45 PM
read around on frustration with similar issues briefly earlier in the week - many said that low lift blades made their mowers suffer more from similar bogging, while others disagreed. I think what works best has more to do with deck design than anything else. I have not had a close look at the bottom of the deck, since I couldn't pick it up on a 2 post lift and haven't removed the deck. It doesn't pick it up very high. Car ramps plus deck at max height should give me OK access.
I have rubber edging around the deck front and rear, I wonder about adjusting that so it can puke more grass - hopefully without covering the operator or hucking rocks.
Post by: mr.mindless on June 08, 2020, 03:49:54 PM
I just had a thought - I think backspacing may be an issue, but I almost bet my rear tires on the brolite could be a fit for a more aggressive drive tire on the Jacobsen. That'd be a funny swap back n forth. I think they're a 26x12.50r14, and they are certainly 5x4.5 which I bet is right. Not sure about that diameter clearing.
Post by: M4wdFab on June 08, 2020, 04:51:08 PM
my ferris is 5x4.5 lug  (jeep/ranger) too
Post by: mr.mindless on June 19, 2020, 09:00:37 AM
Had to rinse off the radiator last night 3/4 done. Lots of crap on it, just I can hear the high temp alarm at 225-230, over hearing protection.
Have all new filters, probably flush coolant too. So much maint to do!
Post by: mr.mindless on June 19, 2020, 09:03:35 AM
Fan blows towards the front, with rear radiator. Probably crapped up when I ran it without the hood for a couple mows while tuning.
Post by: mr.mindless on August 13, 2020, 02:15:34 PM
Found an okay cross reference for Gator blades. 1/16” longer. One center hole, not three. Way cheaper than my discontinued NLA blades. Order actually went through so we’ll see if better.
Post by: TrailTamer on August 13, 2020, 10:07:13 PM
would be nice to send the jacobsen and mow with whatever tractor instead of having machinery multiplication, and that's not the right unit for that I don't think. Too big, too weird.
It is nice to be able to hold a cold beverage while mowing. Another vote on belly mounted mower. Although it’s nice to not relying on one equipment to do everything.
You’re welcome to ‘test’ out my 44” hydro walk behind w/ sulky to get a feel on what one can do for you as if in conjunction with a mower tractor. I suppose a WB can temporarily the primary mower during the wet and soggy in spring
Post by: M4wdFab on August 13, 2020, 10:13:49 PM
are you down to mowing a 1/2 acer yet instead of 5?
then sure mow with X
Post by: mr.mindless on August 13, 2020, 11:40:21 PM
zero interest in a walkbehind, that's silliness for a property this size that's mostly clear, not darting through trees.
that crazy batwing thing that started this thread is more appealing all the time.
Title: Dumb mower
Post by: mr.mindless on August 30, 2020, 09:01:49 PM
Couple bolts rattled loose. Minor issue resulted. Lots of things attach to the front axle so when it moved 1.5” relative to the chassis i could no longer disengage pto, lift the deck, or move backwards.
Has top locks now. No damage done.
(https://uploads.tapatalk-cdn.com/20200831/de9df9a3f703ee06a4c8f38c4a8c7fc3.jpg)
I would be unhappy if I hadn’t paid under 2 grand for this. But it’s good enough for now. Still clumpy discharge. It’s just not built for how I mow; I cut too much off at once and want too fast of travel speed. Not lacking for power anymore though. Tackled 8” long wet ditch grass and loaded up and rolled coal, but did not bog down.
Post by: mr.mindless on September 25, 2020, 01:51:56 PM
ready to hawg come springtime. or a wet fall.
25x10-12 replacing 23x10.5-12. they're really squished width-wise from shipping.
may or may not need to push the deck forward a little, that's an easy adjustment if I do. I think fenders will clear without modification. will need to determine how far to lower the rear of the deck to compensate, expect 1" but will see. If I move the deck forward I think that will complicate that due to how its suspended.
Post by: mr.mindless on November 10, 2020, 07:07:01 PM
Had to swap fuel filter today. Didn’t pick up a bunch of power from before. Hopefully not a problem going forward with my fueling station! Not sure how it could be with the 10 micron between pump and nozzle?
Post by: mr.mindless on April 14, 2021, 05:21:35 PM
Zero stucks. Smoother ride. Had to air up a bit over spec (7psi) to not tear up on every turn. Do have to be careful with acceleration when cornering to not tear things out but overall a springtime success. Mowed straight through the big center backyard puddle without hesitation. 3-4” deep. I was aiming to skirt that one but saw it through the grass a bit late and committed. Probably could do a few other places I avoided.
Now if only I were dragging a heavy assed loan roller and could squish down some of the high spots into the low spots….
Mild rub on one side. Did have to push the deck forward an inch. Drilled one hole a tiny bit too low and annoyed myself. It’s fine.
(https://uploads.tapatalk-cdn.com/20210414/02f8d9057f11ac3dec5ed0832dfba493.jpg)
(https://uploads.tapatalk-cdn.com/20210414/a3e835632c3edea3d2d95273068473e1.jpg)
(https://uploads.tapatalk-cdn.com/20210414/33f71401aa7ca7d28d80da82ba5d49b1.jpg)
Post by: mr.mindless on April 14, 2021, 05:42:54 PM
(https://uploads.tapatalk-cdn.com/20210414/8fbee65e886ba6556e7faa3132dc01cc.jpg)
(https://uploads.tapatalk-cdn.com/20210414/c637f4b68dc8e33fff20f57312ae7d72.jpg)
(https://uploads.tapatalk-cdn.com/20210414/fb3cb1839c179918403cefd2685f7bbd.jpg)
(https://uploads.tapatalk-cdn.com/20210414/c12e298fc8a57f36af02f62485b23bda.jpg)
Post by: M4wdFab on April 14, 2021, 06:33:59 PM
nice.  did the fence holes fill them selves in yet?
Post by: mr.mindless on April 14, 2021, 07:10:12 PM
I filled those with the backfill I pulled away from the foundation last year. Can’t see them at all anymore.
Post by: mr.mindless on April 14, 2021, 07:12:24 PM
No way I could have mounted these without tubes. I gave a valiant effort.
Post by: mr.mindless on May 02, 2021, 01:58:57 PM
Another plugged fuel filter? Sure running like it. Fuel in the bowl looked fine. Guess I need to keep a filter on the shelf if that is the issue. Hmm.
Post by: mr.mindless on May 02, 2021, 03:36:53 PM
Was drawing down fuel level in the bowl. Got that bled and now fine. Cause unknown. Bad tank to filter line? There is a post filter lift pump so air leaks could be a thing.
Post by: TrailTamer on May 02, 2021, 07:54:40 PM
I just noticed US General tool chest oh-shit handles. Nice touch 😎
Post by: mr.mindless on May 23, 2021, 01:35:37 PM
My yard is annoyingly rough to mow. It’s mostly dried out now and goes from sopping mess of nearly getting stuck to concrete. How the F to smooth that out? I think I could take a roller compactor across most or all of it now but it seems likely that there’s only a couple day window where that’s true before the roller would do nearly nothing.
Damn horses and low spots.
I guess I should just re-grade and fix the low spots to delete the mud so it stays flat once it’s smoothed out mechanically. Then I just need to deal with getting something other than weeds to grow in the concrete after re-grading.
So I just need better suspension
Post by: M4wdFab on May 23, 2021, 03:57:37 PM
i dont remember it rough when i mowed, but im sure chains on forklift and UTV tires on the mower are not helping compared to the turf saver tires on mine.
not sure what the solution is
Post by: TrailTamer on May 23, 2021, 04:01:58 PM
https://www.facebook.com/marketplace/item/2205797656219650/
Post by: Wingman on May 23, 2021, 04:12:22 PM
sheep  :P
Post by: mr.mindless on May 23, 2021, 07:21:38 PM
Parts of the pastures were rough to begin with. Ruts from mowing and otherwise crossing the wet areas compound it. The couple forklift stucks and heavy trailers haven’t fully smoothed out.
I put a yard or two of topsoil in the holes this spring but the rough parts are still rough. I could lower pressure in the ATV tires and get a good ride but it increases tear out. There’s no suspension on the deck idlers up front so it beats that framework up pretty good if I don’t slow up.
I wonder if I could just tow a roller when I mow now that it’s not soupy and just peck away at at or if the concrete clay won’t move.
Post by: M4wdFab on May 23, 2021, 07:23:21 PM
My tractor pulling out 100 fence posts probably didnt help either when it was mushy!
Post by: etk300ex on May 23, 2021, 08:45:42 PM
Rolling smooths my yard out for a week then it’s right back to bumpy.  Had it done three weeks in a row last year with one of those mini rollers, same results.
Post by: M on May 24, 2021, 12:10:33 AM
My lawn is so damn bumpy...  so when I bought my zero turn a couple of months ago, I opted for the suspension system (Toro's MyRide).  Absolutely love it!  It really made a difference in how I felt after cutting my lawn.
Post by: cracker on May 24, 2021, 12:24:40 AM
My sitework guy offered to let me use this big guy for a weekend to flatten out some of my pastures last fall when he was on site to give estimates, but I have not asked if he was really serious or not.. my whole property is also extreme clay soil, and very punched up from all the horses.  I am just not sure if the roller will pack the soil to much and hurt the grass.
Post by: Wingman on May 24, 2021, 07:56:38 AM
I used one of those big boys on my yard years ago. Didn’t bother the grass one bit. Also didn’t seem to make a difference - too dry.
Post by: mr.mindless on May 24, 2021, 12:12:44 PM
yeah there's definitely a narrow sweet spot where it's hard enough to support but soft enough to make a difference. I wonder if maybe a good watering before rolling during late season dry times might be the ticket?
Post by: mr.mindless on August 21, 2021, 06:27:11 PM
Well that might be the worst mow job since springtime mudbogs but it's done for a couple days and shorter hayfield will dry more quickly.
Played with deck angle a bit since clumping was criminal. Higher in front was way better. May go another notch.
Deck has a very slight twist. Had been dead level on one side and front low on the other. I still think my blade speed is too low and bogs. Haven’t looked at plumbing in pressure gauges or trying to measure rpm.
(https://uploads.tapatalk-cdn.com/20210821/aa38781c913635363ee9329ccd9eb810.jpg)
Post by: mr.mindless on August 21, 2021, 07:02:31 PM
Before and after adjusting
(https://uploads.tapatalk-cdn.com/20210821/37e0088bdd38c6223a7b6142623ad0dc.jpg)
(https://uploads.tapatalk-cdn.com/20210821/e15f2158e112e87f45ff7e7a7199ac34.jpg)
Post by: Wingman on August 21, 2021, 08:45:42 PM
theory: front should be the lowest, else you are cutting the same blade of grass over and over again...
Post by: TrailTamer on August 21, 2021, 09:14:07 PM
There’s a relief valve somewhere on PTO hydraulic circuit? Maybe the valve or worn hydro motor bypassing when under load slowing down blade tip speed?
I reckons the rear discharge don’t help any. It has to do with either deck design or insufficient spindle speed. Id close off the rear discharge to keep grass in the deck and mulch.
Post by: mr.mindless on August 21, 2021, 09:51:39 PM
worn motor not unlikely.
I'm familiar with that concept mark. but I noticed while avoiding making big ruts today that it cut way cleaner in reverse. so I thought I'd try going against that logic instead of going stronger to front down when one side was already 1/4" lower in front, and it improved significantly. so...
Post by: M4wdFab on August 21, 2021, 10:59:05 PM
needs more fuel plate  8)
Post by: M4wdFab on August 21, 2021, 11:03:15 PM
i have found during this rainy season, im more happy to mow ever 6 days instead of every 7, because i like to go full speed  instead of 80% speed haha
Thats an impressive amount of uniform silage for rear discharge!   how long was it since last mow? lol
Post by: mr.mindless on August 21, 2021, 11:07:44 PM
I probably cut off 60% of length.
had probably been 2 weeks. day job issues.
Post by: M4wdFab on August 22, 2021, 08:24:34 PM
lol @ 2 weeks
Title: Dumb mower
Post by: mr.mindless on September 23, 2021, 07:57:01 AM
Flat on one side :(
(It is tubed)
(https://uploads.tapatalk-cdn.com/20210923/77ee528a2385b03e505cede05795b6f0.jpg)
Post by: mr.mindless on October 01, 2021, 10:14:53 PM
Tire leaks down in a couple hours.
Didn’t fix it yet. Did mow until dark and then put a couple lights on it, then fill the tire and mow a bit more.
Post by: M4wdFab on October 01, 2021, 10:19:31 PM
i have now patched and tubed both my zero turn drives- they have been holding up so far this year.
im really tempted to just spend the money on the tweels, but havent yet.
Post by: mr.mindless on October 02, 2021, 01:37:32 PM
Pulled the tire, felt nothing inside. Soaped the tube and saw nothing. Reassembled and finished mowing. Now already flat in the garage an hour later.
Guess I’ll either squirt some Slime in next time i fill it, or just swap the tube. Must be something small enough to only open up at operating pressure but be sealed at naked tube inflated to non sketchy stretch size.
Post by: TrailTamer on October 04, 2021, 09:10:07 AM
Check the valve stem. I have had ones got me good when the valve core or stem leaks
Post by: mr.mindless on October 06, 2021, 07:17:57 PM
Stem and core were checked twice before first tear down. Still good now.
Tube at 2x static size exposed a pin hole. Unknown source. Surprised it didn’t leak when soaped at inflation but even at scary balloon size it’s like 4psi, so just a learning experience/ reminder I guess. 95% of my tube knowledge is on bike tires.
I appear to only have radial patches. Will order spare tube and a couple tube patches.
(https://uploads.tapatalk-cdn.com/20211006/10c3522cd31bd7a0ac2fa3fdc45f0648.jpg)
Post by: mr.mindless on October 07, 2021, 07:34:27 PM
Stopped leaking once it shrunk down. Slimed it and mowed for an hour or 90. Hopefully it takes.
Patch and spare tubes late next week.
(https://uploads.tapatalk-cdn.com/20211007/44ee6dbebde0086f6ef7a5662ca65341.jpg)
(https://uploads.tapatalk-cdn.com/20211007/a65752f34a3836e5f8d9fcd94179dcfc.jpg)
(https://uploads.tapatalk-cdn.com/20211007/64675aa0cef5408d074203226ff686d1.jpg)
Post by: M on October 08, 2021, 04:46:14 PM
Nice! I added lights on my zeroturn earlier in the year and love it.
Post by: mr.mindless on October 08, 2021, 06:28:10 PM
Not flat!
Post by: Wingman on October 08, 2021, 07:27:02 PM
Not flat!
Yea!
Post by: mr.mindless on October 13, 2021, 09:55:39 PM
It’s now a week flat instead of a day flat. Will have to pull it again. Went from 15 to 11.5psi in an after dark rip roaring record setting 1.9 hour complete mow.
Post by: mr.mindless on May 08, 2022, 01:15:39 PM
about to tear into the transaxle. actuating the H-N-L shifter directly does not feel broken. With cold fluid after sitting about 18 hours, the travel control does load up the engine.
No funny noises at all, but it will not move.
No funny feelings or noises when it stopped either, and no preceding abuse.
Found a service manual directly from Jacobsen, its diagnostics for "will not move" say only:
a. Differential bevel gears broken.
b. Stripped teeth on gears.
c. Broken input pinion.
there is no PTO cover or other viewing option unfortunately, so this is just about a complete teardown :(
Post by: mr.mindless on May 08, 2022, 01:17:04 PM
I just added a bunch of slime to that same right side tire before I started mowing yesterday, it was flat again.
Post by: mr.mindless on May 08, 2022, 03:08:55 PM
Eaton model 11 hydrostatic transmission output shaft sheared. (https://uploads.tapatalk-cdn.com/20220508/55cedc7b1e6d2f3eb13250bfa5540e17.jpg)
(https://uploads.tapatalk-cdn.com/20220508/7e7063b8793e19de6847f6867ecffd15.jpg)
(https://uploads.tapatalk-cdn.com/20220508/f39b8dc217164ea81847120554c80815.jpg)
Post by: mr.mindless on May 08, 2022, 03:10:03 PM
(https://uploads.tapatalk-cdn.com/20220508/911d8bbd34e7422e6c3f3039f439ec46.jpg)
Some disassembly required
Post by: mr.mindless on May 08, 2022, 04:40:08 PM
I have not been able to find the part or a part number for this output shaft yet. Concerning…
OD is just under 3/4, minor dia of the splines is about .535
Ratings on this Eaton model 11 range to 20hp. I’m supposed to be 22hp and have turned it up a little. That doesn’t seem great, either.
(https://uploads.tapatalk-cdn.com/20220508/91decc83a0cca84019db2317ec3c2035.jpg)
(https://uploads.tapatalk-cdn.com/20220508/c118ae1ccec7146a6339e671a486dc51.jpg)
(https://uploads.tapatalk-cdn.com/20220508/17894c62788c3ebd424a6b77324a1a3b.jpg)
Post by: mr.mindless on May 08, 2022, 06:15:05 PM
Ebayed a complete used model 11 trans for like 280 with tax and ship. Silliness.
I bet that part would retail for 100+ anyway as new old stock. Probably unsellable trans without a good output shaft, but I’ll try… definitely feel like I should have a spare output on the shelf right now and plan send the whole unit with stock size tires if it happens again. Will have to keep an eye out for cheap spares I guess.
Post by: mr.mindless on May 15, 2022, 09:50:48 PM
Notably bad packing job on the eBay trans but no damage and part was a match.
Seemed to take forever to put back together but no issues and it’s operating great.
Post by: mr.mindless on June 05, 2022, 02:32:53 PM
This worked pretty well. I kept the Jacobsen in low range the whole time, hopefully saving load overall on that tiny transmission output, and finished my first mow with this setup about half an hour quicker than usual. Done right, I bet I can get to 2hr instead of 2:45-3.
(https://uploads.tapatalk-cdn.com/20220605/174ff25aba5574b80a23a6abac7bcdd8.jpg)
I need to make some adjustments and deck repairs. It operates fully on its own, hydrostatic drive. The oil looked like SHIT: very shiny. So maybe the Kohler is on its way out, maybe just neglected. I have changed it twice now. Splash lube/ no filter.
I picked it up CHEAP along with another similar unit (belt drive, not hydrostatic, but deck is perfect). I don’t think I could run with two of these at once without impressive complexity, so I’ll get the other running and probably sell whichever goes first. Turning left moves the towed mower off track quickly and leaves a stripe. If I wanted to run two wings like this I’d need to make a compensator of some sort to adjust track of the rear decks to compensate for the steering.
To run further forward in the middle of the wheelbase where off-tracking wouldn’t be an issue, all 4 wheels must be swivel casters. To do that, I could absolutely use these decks but in that case I’d want to drive them with two more hydraulic motors like the front deck. I don’t think I have the flow to do that and I don’t think I have an easy option to get more hydraulic power. I see very clearly why the machines with wing mowers are twice or more the size of this one.
Post by: KingtheZJ on June 05, 2022, 05:49:11 PM
I need more pictures of this setup please
Post by: M4wdFab on June 05, 2022, 06:29:12 PM
F pictures, we need a video
Post by: etk300ex on June 05, 2022, 09:05:14 PM
You’re a machine!
Post by: mr.mindless on June 12, 2022, 08:12:52 PM
Got the other walk behind running today. Needs a main seal, ordered parts. Needs one tire fixed too. Not sure what it’ll sell for. Probably make it the towable and sell the Woods after deck repair(https://uploads.tapatalk-cdn.com/20220613/8ebd5763ad8c4f81b0c99c7f634c25b2.jpg)
Mowed on Friday and did it all in 2.5hr in low, instead of 2.75-3hr in high without the “wing”.
Not the speed up I was hoping for but I bet it’ll make the Jake transmission not break again.
About 2 gallons of gasoline on top of the Jake’s diesel. It’s probably burning just as much as without towing.
Idk.
Probably test a zero turn sometime and just keep eyes out for a great deal on one.
Post by: mr.mindless on August 28, 2022, 02:01:38 PM
blade RPM dropped to about useless today. need to diag hydraulics. I have a service manual but not the necessary gauges.
Anyone have hydraulic test stuff, or tees and plugs?
There's a likely good test stand on ebay for relatively reasonable money https://www.ebay.com/itm/265849695469
but I'm still short lines and adaptors to 37? JIC, according to the service manual:
a. #6 9/16 18
b. #8 3/4 16
c. #10 7/8 14
Post by: mr.mindless on August 28, 2022, 05:55:13 PM
Finished mowing with the Mowzer. Blade and deck both on from pushing some stuff around whenever I last did that. Oooooof does it need power steering to ever do that again. My hands feel like I just stripped half a roof of shingles.
Post by: etk300ex on August 29, 2022, 08:43:45 AM
Swapping in a tdi tonight?  ;D
Post by: mr.mindless on September 03, 2022, 07:20:25 PM
bad mechanical cooling fan bearing confirmed, removed, ordered.
hydraulic motor removed.
I have no idea where I'm going to find stuff to plug this with. I guess I need to browse TSC for hydraulic fittings and plugs? I think it's -12 ports? Not sure if I'd rather find out it's the pump or the motor, the motor was easy to pull. pump doesn't look too bad if I have to.
Mowzer on mowing duty sometime this week. Definitely with the gang mower setup.
Post by: M4wdFab on September 03, 2022, 09:29:35 PM
i finally mowed a nice full green lawn yesterday.  it was looking pretty dead and dry for the month of august.
Post by: mr.mindless on September 08, 2022, 02:49:53 PM
2hr mowing and mowzer is out of gas. Lawn nearly done with gang mower setup on it.
Mowzer is working hard to not be pushed around by the gang mower. But absolutely does cut time in half if I have to cut with it, compared to almost no time savings going slower with the Jacobsen.
Got some 37* JIC plugs and caps yesterday and plugged up the motor. I suspect the motor is bad, it’s stiff to turn one way and  not too difficult to turn the other way using the 8” pulley. So probably will throw a motor at it, and depending how much that hurt$, maybe still get the hydraulic tester and set the relief valve to spec or a smidge tighter and maybe get it cutting much better. I hope?
Post by: mr.mindless on September 08, 2022, 04:16:31 PM
And like another hour to finish mowing the hills where Mowzer can’t handle the gang. Including removing the gang and fueling.
Definitely only a temporary solution.
Post by: mr.mindless on September 08, 2022, 08:57:03 PM
New cooling fan bearing here. Couldn’t get old to budge at all out of mount. Can’t see any clips. Out of small tank propane to heat and expand. I really need to get a press
(https://uploads.tapatalk-cdn.com/20220909/b0aae222d56f1c4661e8bf97cdb2fce9.jpg)
Post by: mr.mindless on September 13, 2022, 12:09:47 PM
I keep forgetting to grab the hydraulic motor to see if cylinder service can match it up.
I might want to borrow my neighbor's Ferris and see how a ZT does my yard... I think the front deck is awful nice for the pine trees. but meh if it's quicker overall
Post by: M4wdFab on September 13, 2022, 02:32:16 PM
i didnt have any problems with my Ferris on your lawn, just watch the ROPs on some of your trees and the ditch up front!
Post by: mr.mindless on September 15, 2022, 02:53:46 PM
Dropped this morning.
Post by: mr.mindless on September 16, 2022, 02:34:24 PM
$450 and 23 week lead time
Fuuuuuck.
Post by: etk300ex on September 16, 2022, 04:31:16 PM
jeez
Post by: M4wdFab on September 17, 2022, 06:54:08 PM
lame.  at least its end of season in a few mows.
id still like a bit more HP, but i dont think im at the trade in point for my initial investment of 7800 to upgrade, although its been nice to just mow and no issues for 4 seasons.
Title: Dumb mower
Post by: mr.mindless on September 17, 2022, 07:34:46 PM
Got half mowed in 6hr with the Mowzer today. Deck drive belt issue and then 2 trips and  6-8 belts later it’s still an inch small.
Length didn’t match published specs I found of either 64 or 106 for primary or secondary. What I took off measured 80 and was under tensioned so I got a 79
Then went back for 80 through 84 and got it running. I think it wants an 85 or maybe 86
Neighbor with the Ferris is away.
(https://uploads.tapatalk-cdn.com/20220918/0771534170d10f391a7b9c038eb09a90.jpg)
Post by: mr.mindless on September 18, 2022, 11:51:46 PM
Snapped the 84 today. Traded in the rest of that pile for a pair of 85s. They don’t seem to like to stay twisted like the mule drive needs and run on the wrong face. May need to get a Deere belt if I can find the right part number. Failed in that so far so we’ll see.
Expect it’s a 4 hour cut without problems. Tolerable for another month I guess. Annoying.
Title: Dumb mower
Post by: mr.mindless on September 20, 2022, 10:04:01 PM
Found a used pump on eBay for 300. Hopefully pick up on my way to f&f on Friday. Overpriced but availability is what it is I guess
Post by: mr.mindless on September 30, 2022, 08:32:20 PM
Fully buggered. Going to have to waste half the day mowing with the Mowzer one day this weekend.
The motor I got is supposed to be from the same model tractor. Textron dealer I contacted said the motor comes with the tractor, not the deck, so i figured by application should be safe.
This motor had 2 different size ports, and was a shade shorter in height than the motor being replaced. I went up to PowerDrives today and got the needed fittings and got everything put back together. It spins the blades fast as fuck! To the point the mower engine is loaded up a bit and hazing under moderate load as i take a test pass. Blades sound like they’re really flying but cut quality doesn’t look great… could it be backwards?
I had to change fittings after all…
Sure enough, blades are spinning backwards.
Flipped the hoses and it just puked fluid through the seal. Probably blew that seal out in that quick test.
So back to hunting. And hopefully find a seal and a proper application for this motor to sell it.
I wish hydraulic motor part numbers weren’t just made up out of nowhere to intentionally make cross reference difficult. Fuck.
Post by: M4wdFab on October 01, 2022, 09:54:49 PM
i can run out tomorrow with my ferris if you need help im free let me know.
Post by: mr.mindless on October 02, 2022, 10:19:21 AM
I spent 4hr on the little Deere yesterday getting it done.
That machine isn’t meant for the duty cycle. That’s 2 full tanks of gas and one stiff back!
Post by: mr.mindless on October 30, 2022, 08:11:40 PM
Brought some parts machines home today. Also found a maybe perfect machine roadside “for sale” on my way to the second machine.
I have a groundskeeper to call tomorrow and may part out everything I have now and buy a ready to run big boy. AWD low ground pressure 50 horse. I need to read up on it. I hope the price I was told today is right…
Post by: mr.mindless on November 04, 2022, 04:15:12 PM
Swapped the deck drive motor from the spare identical mower I brought home last weekend. Mowed no issues. Yay!
Same blade speed I had before and lots of windrowing still there. Meh!
The spare mower came with a super fancy articulating deck. It's a bit incomplete but I'm going to try and use it. Seems to be in reasonable shape. Should give a much better cut, following terrain which is a bit of an issue with some spots with the 72" deck, and more importantly should bounce a lot less too the way the casters and rollers are set up. Looking forward to that. Bearings all good, needed all rollers and casters and belts. I have new rollers on the way and should be able to move casters and blades to it from other things here. Belts might be OK for a test run, TBD.
Now that grass is mowed, going to swap starter onto the new to me mower and see if it'll start. It cranked once or twice and then wouldn't, but compression got better while cranking... I have my doubts. I should have beat him up a little harder on the price but I think it'll be OK. Need to get the other one I brought home brought in to start parting out too. Greens reel mower that didn't work out for the previous owner, and he harvested the Kubota out of it. Didn't want to part it for some reason and sold the whole machine for the price of the hydraulic pump.
Post by: mr.mindless on November 04, 2022, 04:17:27 PM
Superintendent got back to me and said "it should be sold"
¯\_(?)_/¯
I'll call again next week and if it's not gone I'd still pick it up.
Post by: mr.mindless on November 04, 2022, 05:30:42 PM
Oh I wish I had both earplugs in for that. Tire slice too long for tube. Ouch
(https://uploads.tapatalk-cdn.com/20221104/64d13fdd633dcad5b06ced9f2ad7b9d1.jpg)
Post by: mr.mindless on November 04, 2022, 08:55:22 PM
I layered up the popped tube over a new one and didn't bother to seat the beads. Holding. good enough for maneuvering.
engine runs well once I got it fired. air filter housing was FULL of water, mud, rust and maybe seeds and shit? That was probably the firing fail before the started failed: it was choked. no idea how, housing is complete.
hydraulic pump is good, engine bogs with the lines plugged if I tickle the PTO.
Travel is super slow. will check linkage adjustment closer in daylight but it looks OK-ish. goes backwards way better than forwards so maybe it's linkage.
Should be good parts, hoping that transmission is good and not just the transaxle, but so far so good, really.
Post by: mr.mindless on November 04, 2022, 09:10:06 PM
(https://uploads.tapatalk-cdn.com/20221105/ba7733646fc52bb36d32c5d3e4e4302a.jpg)
Post by: M4wdFab on November 04, 2022, 09:23:03 PM
im confused
you bought another of the same mower semi broken/fixable other than the fancy deck, or is it bigger/more power?
Post by: mr.mindless on November 05, 2022, 10:07:35 AM
Another of same with the fancy deck, it got me the hydraulic motor i needed. Part out the spare bits.
I was hoping to get to part both turfcats if I could get the big one but that’s looking not good. I’ll follow up on that next week.
Post by: etk300ex on November 05, 2022, 05:03:34 PM
That’s a sweet turf cat!
Post by: mr.mindless on November 05, 2022, 08:13:16 PM
Was worried the hydrostat was shot on the new to me turfcat. Wasted hub and axle shaft, was taken apart and brake was gutted once. Shaft spinning in the hub. (https://uploads.tapatalk-cdn.com/20221106/a3cba129b4b62d626474b18a9da0aee8.jpg)
See the wear in the bottom bracket from the back of the drum too. Someone did a lot of hours in oops mode.
Hub is totally wasted. About 20% of the shaft is broken out.
That and a bad starter is all that’s really WRONG
Time to put it all on the shelf and get it on eBay.
Came with a full tank of diesel too.
Post by: mr.mindless on June 24, 2023, 04:50:56 PM
When I can’t find the Mowzer later, I left it in the stable
(https://uploads.tapatalk-cdn.com/20230624/ed02bb40695e677064aeb28c45bae6f9.jpg)
Post by: mr.mindless on December 14, 2023, 12:23:42 PM
Have had a hard start on this unit for the last 2-4 mows. Seemed like low volts, was expecting a charging issue. Needed to move it last night, battery charger on START didn't help. Figured battery must be shorted, but it tested good. New battery that also tested good didn't help. Booster box hooked directly to starter didn't help either.
Figured it must be the starter, then. Pulled it and found the bushing in the snout of the starter is just about gone.
May be able to get away with just replacing that bushing but I'm unsure. Presently intend to check with that alternator/starter place. not sure I'll make it there before closing today.
Post by: mr.mindless on June 23, 2024, 12:37:57 AM
Has been all good since new starter.
Just did oil and filter at 2094 hours, almost 200 hours in 4 years.
Had a shop accident. This thing is not conducive to being picked up on a lift, and I found out the hard way that both right side lift arms on one of my lifts don't have good stops (the toothed ones that engage when off ground level to keep the arms from moving). Will be addressing that shortly.
Only casualty is my oil drain trolly and  big oil mess from 2 changes worth of oil, and some mildly bent tin on the tractor body. Didn't seem to take out any hoses or anything. Something else may come to light later, like a bent deck or bent axle or something.
It fell from about 5' while I was standing right next to it. gave no warning at all, and _something_ just barely grazed my head. I think it was one of the rear lift arms (a front one slipped). Not enough to injure at all, just feel.
This will only ever be hung to pick it up in the future. Second time it's slipped on me, out of three or maybe four times picking it up.
No lotto for me, my luck got spent a few times over.
Took longer to clean up 2ish gallons of oil spilled than the rest of the day's maintenance and mowing.
Post by: etk300ex on June 24, 2024, 08:23:57 AM
 :o
Post by: M4wdFab on June 24, 2024, 02:59:05 PM
glad it wasnt a bigger event.  best to take it as a learning point for future!
my mower doesnt fit well on my lift either.  it was sketch this year again.  i may add lift points now ha
Post by: mr.mindless on July 09, 2024, 10:20:28 AM
Definitely bent some things up front. Raised the deck a bit and it’s still too low. Can tell one of the big casters is bent and about an inch shorter than the other.
Post by: mr.mindless on April 20, 2025, 01:20:35 PM
Seems I may need to slap a tube in the right front. It’s already tubed and I think already slimed but leaks almost as cars as I add air.
Back yard is looking long already :(
Post by: M4wdFab on May 07, 2025, 08:59:49 AM
still happy with the ATV tires?  I was talking with Jeffs buddy Stratton yesterday that has a similar forward deck unit but his complaint is the turf tires.  i was gona send him some picture of your unit from page 2/3
Post by: mr.mindless on May 07, 2025, 10:55:19 AM
They tear out pretty good sometimes if you spin a tire or pivot turn, but if you're on a well established lawn it's not deep enough to matter. Roots stay and it comes right back
I mowed 99% of my swamp successfully yesterday morning and didn't get stuck anywhere. Turf tires never could have done that.
I removed the leaky tube and the naked tire has held since.
I put the hole in the tube facing down so the slime would find it, and it has held pressure since as well. 2 fixes for the price of a dismount/remount.
Post by: mr.mindless on May 07, 2025, 11:16:55 AM
love rereading my own threads.
Post by: mr.mindless on May 12, 2025, 07:59:54 PM
Victory as dead weight, surprisingly
(https://uploads.tapatalk-cdn.com/20250512/1215a0f7eab5ffbafa01682b631ee606.jpg)
Post by: cracker on May 13, 2025, 08:07:45 AM
My Sara got our Ferris suck yesterday too.. but she was on flat ground.. just found a wet patch
Post by: mr.mindless on June 04, 2025, 10:33:57 PM
Buried it, solo recovered w the jeep.
(https://uploads.tapatalk-cdn.com/20250605/a17ffc49ff82bf3257e38cb3ff492df3.jpg)
Jeep is a birds nest,
Just in the last week or 2
(https://uploads.tapatalk-cdn.com/20250605/cb24fb18529548c44c8745e2c1eb0fce.jpg)
I am pretty seriously shopping for a better wet area mower. Would be nice to get one before the ground firms up so I can flatten some of these ruts
Post by: M on June 07, 2025, 10:40:01 AM
Yarbo, let it do the work for you  ;D
the price tag though  :o
Post by: mr.mindless on June 14, 2025, 01:01:47 PM
Thee miles walked. 5 tanks of gas burned. This is why I don’t trim but every other year.
Didn’t do a single pine tree in the windrows. Just the buildings, shop lot, fences and some of the pond inlet ditch. Seems like a job to consider hiring out lol
Where’s the neighbor kids who mow for $20 these days?
(https://uploads.tapatalk-cdn.com/20250614/9e2736b48730850bc2b2be2ea43507bd.jpg)
Post by: M4wdFab on June 14, 2025, 09:54:06 PM
how do you walk 3 miles on 4 acers lol
42% was on sale for 55$ for a 2.5 gal at TSC this week, i plan to hit my overgrowth and gravel when i get time in the the next few weeks
Post by: mr.mindless on June 15, 2025, 03:04:53 PM
Doesn’t seem to knock my gravel growth back for more than a week or two, and I don’t want to put it around my trees.
Most of the walking was back and forth for gas and line. Filled the spool twice too.
Post by: M4wdFab on June 15, 2025, 08:21:43 PM
i can trim my property on 1 tank and 1 fill of line.  i do it about 3 times a season if im feeling tidy
no trees is nice but building is big and lots of polls
Post by: mr.mindless on July 08, 2025, 04:06:56 PM
2600 hour 25hp kubota diesel
Center pivot steering, 4x4
Lots of attachment options. This is a 72”
Side discharge.
Might put the plow jeep up for sale and reduce fleet count.
It’s harder to drive, more physical steering effort. Deck moves backwards compared to the rear steer which is weird. Better ride and will do much less rutting and hopefully less stucking.
Maybe upgrade to newer similar style in a few years if I like it. It’s absurdly easy to spend 30k on this style tractor if you’re willing. I’m 5900 into this with a couple small engine leaks and some tired looking hoses. Needs a new end on the auxiliary too, one drips.
(https://uploads.tapatalk-cdn.com/20250708/a46721300d34ebb6d0fbac148250d4f8.jpg)
(https://uploads.tapatalk-cdn.com/20250708/9c116b8ba40f9c460c0b3440a9b2692e.jpg)
(https://uploads.tapatalk-cdn.com/20250708/b4f8f87ef3b449733bb61292fc92e870.jpg)
Post by: etk300ex on July 08, 2025, 04:20:57 PM
Sweet machine!
Post by: M4wdFab on July 08, 2025, 04:34:21 PM
neat
Post by: M on July 10, 2025, 02:39:13 PM
It even has the rollers for striped lawns!
Post by: mr.mindless on July 11, 2025, 01:18:23 AM
Hoping I can use that roller with down pressure to knock down some ruts and wet spots when it is soggy again.
I think it’ll work.
Post by: mr.mindless on July 15, 2025, 04:28:39 PM
Don’t immediately realize this deck flips up. Manual, but cool!
(https://uploads.tapatalk-cdn.com/20250715/1d7c0bb1921fafe584c6c67cec7436f4.jpg)
Post by: mr.mindless on July 17, 2025, 09:36:41 PM
Had to do some belts. Seems all good now. Inop hour meter replaced.
Post by: mr.mindless on July 21, 2025, 09:45:02 PM
One of these has 5x the power of the other. Any guesses which?
(https://uploads.tapatalk-cdn.com/20250722/bae0e7d73b2457539913d23d77ebe736.jpg)
(https://uploads.tapatalk-cdn.com/20250722/0681f9e519a26f4942d53cad3e0fd4cd.jpg)
Post by: mr.mindless on July 21, 2025, 09:46:54 PM
(https://uploads.tapatalk-cdn.com/20250722/8ee8782fb3f70f0349040a4e7669731f.jpg)
Post by: mr.mindless on October 05, 2025, 04:38:41 PM
Lost one of the crunchy hydro lines yesterday. Big one to/from the rear drive.
Pretty large investment to re-hose the thing, all but 3 or 5 look original and show it. No outside rubber coating left at all.
Looking everything over carefully before pulling that $500 trigger I find that the engine to pump driveshaft splines are shot. I can get a shaft for money, but unsure if the splines on the engine come with. Need to get a better look at it but it didn’t immediately want to come apart last night.
Post by: mr.mindless on October 12, 2025, 11:53:00 PM
engine to pump driveshaft is PTO shaft parts by caliper measurement. so I can make adjustments as needed there and make a new slip in the middle, and lock down those loose splines. Probably just add a couple set screws to it and tighten the dogshit out of them, and hopefully make a short square slip between the middle yokes. I hope I have enough length to do that well without getting fancy.
probably have to pull the engine to get at that shaft, and also to make running new lines easy.
Pulled the trigger on lines and fluid and a filter, so I am sticking about $500 into it. Only other known issue is a sloppy shutdown actuator on the injector pump. bushing and seal are shot and it's a diesel dripper. It definitely had electronic shutoff actuator originally, but that's a $300 list item which is probably why it got a mechanical linkage, and the added load of that linkage is probably what shot the bushing over time.
