Projects place => Projects Section => Topic started by: M4wdFab on August 18, 2018, 02:44:13 PM
Need to reasearch the vin exactly what i bought but its home.
this one going on a 2014 GMC 6.0 chassis.
cab is pretty solid and its got a lot of things that i usually get nickled and dimed on like emblems, lights, working latching doors, good hod hinges ect. gona be a good one!
Should drop one on a rotten cummins truck sometime for a keeper lot rat that burns waste oil
That is some crafty trailer loading! I like it
Google says its a 1946 KS5, chassis number 40733
looks like about 10K made each year from 1940-1947
16" west coast mirrors ordered!
Hahaha. Love it!!!!
http://stores.restorationspecialties.com/990055-ws-pre-cut/
box freed from chassis
box gone. next to gut and scrap the cab getting the chassis free. then pop the doner cap and prep for swap mount.
pushed in the shop yesterday and started cleaning out the doner cab
pulled the cab tonight and dragged out the old chassis.
need to scrap a bunch of shit saturday and straighten out the GMC chassis that has a little crash damage.
GMC chassis bent back into shape. started standard chassis and LS prep for standalone.
close to its home! need to find an inch or so in the fire wall for the passenger side head but its close.
Cab cleaned out and demo done. Hood latch adjusted, fenders secure to cab.
Chassis prepped: oil cooler, AC, fan clutch all deleted. Heater core ports taped / plugged. both dip sticks shortened, oil fill extension deleted.
4 out of 5 cab mounts done, in its home.
cab mounted and done.
steering 1/2 connected with a plan.
steering completed.
hydro boost and brake assembly mounted.
seat mocked up.
glass and seals ordered tonight.
harness cleaned up tonight
battery has a tie down
PCM mounted
Fues box mounted
heavy gage wires run and one.
another night and it should fire with some wiring work.
ignition wiring, fan wiring, fuel pump, and gages for oil and water in.
only fires for a few seconds with the 4.8 PCM but was enough to let me know i forgot to hook up the oil line to the motor :(
sending out the PCM tomorrow along with the PCM and TCM from the 49 to try and fix out the idiot fleet trans tune he left.
post office closed bah!
PCM sent out for deletes
PCM should be back soon. fingers crossed for last time pushing this thing in an out of shop!
PCM returned. engine fires fine, zero trans movement. bah! F me.
also has zero brakes now. no idea whats going on with this thing. i didnt even crack into the brake system.... just the hydro boost which is a self bleeding system. lost.
glass finally came today!
havent been to the shop all week. bah.
new side windows installed. windshield mechanism inspection started but decided to save for another day.
unplugging trans harness got me forward and reverse in limp mode i assume. so have to hook up some can bus wires i cut apparently.
brakes- it dawned on me the master got drained as it was hanging. bled at master and all good.
moves on its own!
hemlock ordered!
started on the wood blocking for flat bed last night. good plan formulated. need supplies.
major hurtle i was not exited to tackle accomplished tonight!
rotten windshield frame rebuilt and new glass and seals installed. just need to free up some under dash linkage points and fold out windshield should function nice! cab behind windshield was super solid.
Awesome to hear. I hope that’s the case when I do my XJ’s windshield. Leak a lot of water in rain.
pics
flatbed hardware assembled.
flat bed deck fabrication 95% done with some finish welding. decided to call it quits and check out what gooseneck hitches are avail before i lock down my decking supports.
goose ball will have to be behind the axle just a bit with a 14' bed to clearance trailers ect.
full welded. Gose hitch tracking says tomorrow.
back on the truck and headake rack tomorrow, mount, and start eying up a rear crash bar / hitch ect
how big did you go on this one?
it's 14' long, last I saw he was trying to decide between 92/94/96" wide
96" wide, 14' long!
all done. that was a lot of wire!
bolted down and moved out of the shop for jeep work this week.
by the looks of that pic you need a bigger shop
yes
picked up wood today and roughed it out when i got home.
pulled out a lift post and skootched this thing in the shop for a little bit. pleanty of room to finish up the bed, do the rear hitch / crash bar, and finish any wiring / in cab work now.
screwed down. sealed up.
took another half day today and grabbed some steal. bumped into Zach doing the same!
rear crash bar and hitch done.
Looks great
my Tork locker hoodie to the brunt of the impact but lost a little skin on my left thumb holding an air chuck on this guy when it popped. ring hit my shoulder and left shin! probably only had 5-10 psi in it and was at least the 6th time i have filled it to move.
sketchy!
surprisingly metalico didnt care the chassis had 5 tires on it, and that it fell off the trailer in the middle of the yard! win!
I wonder if falling off the trailer is what made the tires not matter.
Those old split rims sure are hazardous!
trimmed headake rack bolts today.
looked at tail lights. ambition low!
put a solid day of wiring in on this guy. getting closer. rear lights and trailer plug hung. still a few more hours but getting there.
99% wired minus needing a brake switch (curse 2014 GM again), wipers and maybe some cab lights later.
hood latch work completed and functional.
crank out windshield mechanism repaired and functional.
hit list:
trans canbus wires need to be fixed
floor pans need re installed
steering column lower mount fixed to floor
seat permanently mounted
mirrors need installed
needs wipers.
needs a brake switch fitted.
looks like you really have the wiring harness down. looks clean.
transmission shifter completed, fresh west coast mirrors mounted, mud flaps installed to bed today.
side steps mounted, filler neck mounted.
looks like a real truck now!
havent been able to find <edit: was being lazy, see below> schematics or info i need to tackle getting the 6l90e to talk to what it needs.
900$ fix here. bah
https://www.lsxceleration.com/pcs-gm-6l80e-6l90e-transmission-control-module-tcm-2650/
John C know anything?
http://www.trucktransdiag.com/downloads/6L80_technical_tips.pdf
john doesnt do E38 PCMS
i did get some feed back from brendan to try.
The ecm and tcm in both must communicate with each other. Sometimes data circuits go through other modules between the two. Unplug one module the entire chain is broken and no communication. There is also a accessory wake up signal (dark blue wire) that may need hooked up.it's a 12v+ signal that the bcm usually provides in the stock vehicle to enable communications.
In the end, you want the ECM data wires to go to the TCM, than the TCM to the OBD2 port. (TCM Inside 6l90 trans) So ECM pins 27,28 will go to Transmission pins 11,10. Next, Transmission pins 13,14 go to the OBD2 port.
pin9 BU blue?
(http://67-72chevytrucks.com/vboard/attachment.php?attachmentid=1639044&stc=1&d=1491356423)
PCM, 73 pin BLACK connector for 27,28 location:
(http://lt1swap.com/E38%20ECM%20Connector%20Pinouts_files/image002.gif)
enough i think above now to run 3 wires from trans connector to PCM connector and see if we are good!
I think we have success! hooked up can hi and low from the trans to the ECM and gave the wake up ignition power. plugged back in trans harness and still have forward and reverse which is much better than the last time the trans was plugged in!
noting here, if its funny OD issues, there is a brake switch input to TCM to release the lockup i assume. should be an easy hookup if needed later.
made a floor support, bolted floor tins back in, bolted lower steering column down, mounted gas petal, affixed a brake switch and wired it it.
major progress! would be driving it tomorrow if the salt was gone!
hit list
cab marker lights in the mail
head liner install
rubber floor mat install
new wiper motors and switch in the mail, install
mount seat and raise it 2"
cab clearance lights installed and wired
electric wipers installed, adjusted, wired
picked up a 3'x4' rubber mat from TSC to trim down for the floor
put the floor in tonight after getting home from buffalo visit.
best 20$ spent on the project. Im getting too good at this.....
The horse mat right?
Been meaning to pick some up and try this in the rover..
ya from TSC. they have two kinds. a 4'x6' sheet that has ribbed texture and its legit 3/4" thick (heavy!) 40$
this time i went with the smaller 3' x 4' one that is a little thinner like 5/8" and has a different texture surface. 20$ worked out great.
insured today. 35$ a year to add, ha. plates from 49 should be back in mail to me tomorrow.
good test drive. motor and trans lots of power no issues.
has a little power steering whine need to check that, and the driver mirror mount needs a support inside the door to stop the rattle.
other wise sweet machine. need to hit the dmv this week.
have a buyer, will see if he comes though.
dirty night run down to the CAT scales this unit is 6440lbs!
9 forms for this guy filled out. DMV tomorrow or tuesday!
manny attempts cant get a good VIN etch. bringing the VIN tag in my pocket and have super good pictures printed out. Hopefully the dumb bitch wont require a sheriff verification again.
will be a last ditch effort if needed, and will not leave my hands. its legit held on by 4 flat head screws on all 4 of my trucks i have done.....
scrapped out dust and paint with a needle and got a semi decent vin Etch. should be good to go.
never transferred Historical plates before, doesn't seem to be clear if MV82 is good enough. MV440H doesnt have a transfer section.... love the DMV rolling the dice. folder up to 11 documents this time!
listed for sale 12K.... 9500 is bottom drive home
for sale 2
f0r sale 3
for sale 4
Mobile dmv ftw. Henrietta office can eat it.
I’m making a habit of gates on friday. Works well from work.
Does Livingston county have a dmv office in Avon? That’d be handy for you.
3pm today wasnt too bad. 45min wait, 15 min at the counter.
cant believe im saying that wasnt too bad.
All went well after expected edjucation and supervisor input as usual. 9 documents total on this one.
registered, plated insured, Albany to send transferable in mail fingers crossed! 67$ lol
Cheaper than transferring plates to my newest Dub.
Someday sooner than I’m comfortable with, they’ll be 25 years old.
pulled the 48' enclosed loaded with two cars out of the snow and ice this afternoon. was fully ready to have to chain it up but did great. Ram bed was full.
deposit received adds pulled! Heading south next weekend!
Mike is gonna love that thing
Could throw my Golf or your ZJ on the deck and hawg instead of trailering. Titan is crated while I’m gone. You know where I keep keys.
Golf is a slow machine with the turbo limp mode thing but I bet it gets 60mpg in slow mode hahaha. Long ramps are in Joe. Welcome to any of it.
i think ill take the comforts of my RAM over 8 hours in that thing when im being paid any day haha
also wana get some miles on the ram with a light tow before the 48' gets put behind it.
ill have to check on the weather down there. maybe i need a self beach day haha
All good calls. Bet it’ll be cold
wrapped up all the little odds and ends on this guy and ready to deliver.
took a nice cruise. man is this thing nice and tight. ton of power. would be a sweet tow rig.
testing out the goose ball if its not raining tomorrow too bad!
fixed two issues after test tow. Passenger side mirror mount needed same fix i did to the driver door to stiffen up and eliminate rattle. Also added some support to transmission cable shift linkage under the dash. found it would start to bind going into park after several cycles.
really going to miss this one. its a sweet machine!
already being put to work boat show style!
:o
clean papers came today for this guy! another one in the books!
will send out via mail to MD next week to get my plates back :)
Ha. Working well in its beach home....
thats awesome!
FARM RAMP USE"
dig it.
That is super cool! What a cool market you’ve tapped into I didn’t really even know existed.
still doing work down in MD
thats awesome
I like the wheels
i actually cant stand them lol. needs blacked out. not a shinny truck. onlything he really changed to the truck besides adding stake pockets to the 14' bed
Mike reached out to me, said trans started acting up after sitting for a year and on its way home from a photo shoot for bring a trailer.
should be interesting to see what it brings after rebuild. he has added wheels and tires to it since i built it.
I still like the wheels 8)
Still one of my favorites
It's live now.
https://bringatrailer.com/listing/1946-international-ks5
(https://bringatrailer.com/wp-content/uploads/2024/11/1946_international_ks5_1946_international_ks5_18bed0cb-cafe-4422-9f45-b829d7053651-QgJDrH-02850-02850-scaled.jpg?w=1240)
ha, you beat me, ya Mike Tagged me. cool truck.
looks great and 95% same as i delivered, except hate the seats he swapped in for the bench i had. not crazy about the wheels either he put on.
haha, I setup a KS-5 alert when you mentioned earlier that it was going to be posted on BAT.
closing today and still 3 hrs left and up to 10K already nice, glade its looking like Mike will get more than he paid me for it
After seeing more pics of it with the new chrome wheels, I like the gray ones better now. I take back what I said.
BAT seems not like a great platform. they take 5% from the bidder at time of bid and seller fee to list. but they are hands off and have nothing to do with final transaction payment, and buyer can back out or ghost seller at any time. buyer just complains to credit card company and backcharges to get their 5% back
seems useless and lots of complaints about it on net.
i was hoping seller would just get payment from BAT. something about escrow on their site as an option but not explained clearly.
ebay dont you have to pay in full?
I'm a bit surprised they don't escrow or broker more than that. 5% seems like a hefty cut for just advertising when it doesn't cut down on the rifraf
they'd probably have a whole lot more liability as an actual dealership if they were more involved, but the online peer-to-peer broker-dealership I used to buy my i3 - KeySavvy - was smooth like butter and way cheaper than 5%. and got me a Minnesota dealer plate for 30 days immediately, too.
IDK how ebay works for vehicles.
no, ebay you don't have to pay in full
You won’t pay for the vehicle on eBay. All financing and payment details will be worked out with the dealer https://www.ebay.com/help/buying/getting-started-ebay/buying-vehicles-parts-accessories?id=4639
BAT is a great platform for a seller compared to mecum auctions that charges sellers fees. BAT charges the buyer and is only 5% and capped at 7500. There are tons of cars that sells for hundreds of thousands of dollars and fee only 7500 is cheap for that.
I think the nonpayment issue doesn't happen that often. Remember, people who complain are loud and people who are happy don't really say anything. BAT does thousands of auctions a month.
but i still have to deal with a buyer and buyer funds? thats anoying, dealing with cash or personal check or bank check- seems no better than a private deal with associated risks.
Yes, true however BAT brings a shitload of eyes that have moolah onto your listings for sale. The caveat is that if you claim to have a low mileage anything, it will be torn to shreds by viewers for any mistakes or flaws - EVEN MORE ESPECIALLY if the vehicle is not detailed/clean.
It has pros and cons.
only got to 11500 and looks like it didnt meet reserve. boo
