Projects place => Projects Section => Topic started by: M4wdFab on August 01, 2016, 09:18:46 PM
confirmed seized motor tonight.
mechanicals look not to bad, front end looks tight
new tires
needs exhaust clamp at header, and tail pipe connected back to muffler.
one unibody spot soft, but not terrible.
have a 99 xj motor sitting on the shop floor i got for 300$ but there are many differances that will require most of the accessories to be swapped, the distributor and a few other sensors to be swapped.
waiting on chip to pick up his phone and respond to me. it was Andies sons jeep that died and was towed. still havent seen the title, dont want to start on it till i do
Wouldn't this be wonder 4.0 as the black 5.9 ZJ was not a Wonder?
Oh I get it, wonder 3.0 was white one.
might bail on this thing
its pretty rotten, not sure its worth the bs and labor and parts to have maybe a 1200 ZJ in the end to drive
could more than 4x my investment after 3 hrs labor tonight.
drive shafts, trans/case pulled from underneath. has good front axle shafts, and almost brand new street tires.
Cant get the motor to turn its so seized to get the TC off and get at the flywheel/tone ring i need to swap to the other 4.0 along with a bunch of sensors and the distributor probably.
impressive level of seized, wow.
motor has to be pulled for for scrap anyway
i suppose i could flip it over and pull the pan to get the crank out but that seems like alot of work lol
finished cutting this up last night, 124$ in scrap today at 127$/ton with 2180lbs?
seems odd math
does 127.00 / GT not mean 127$ per 2000lbs?
No gross ton = 2240
It's the nautical mile of mass! Yuck
gross ton - a British unit of weight equivalent to 2240 pounds
Learn something new every day!
hmmm google failed me i was wondering if it was something like that
interesting.
15 gallons of fuel reclaimed
UPDATED
picked up another 97 4.0 ZJ limited today. white NC truck. 200K on body, 99 4.0 swapped in at some point.
add pics looked terrible rot but with that parts list it was worth looking at
got there, front fenders were cut and peeling not rotted
3 holes were rock slam tears that then started to rust when brought to NY
entire unibody and under hood everywere you could eat off of it clean with some red dirt from wheeling down south.
kid was not happy after putting 3K in lift parts into and and forced to sell, going to Europe for a while in a couple weeks.
NC title thats notorized with out a buyer filled in :o see how that goes tomorrow.
solid buy even if it needs a tranny. somethign is shuttering or skipping at 2-4mph then cleans up fine. have another 97 ZJ 4.0 trans sitting on the shop floor from Chips GF son jeep that got cut up ready.
CL ADD details:
built this jeep in NC and just dont have time for it
230k on body 140k on motor WITH RECEIPTS and full tuneup, battery, plugs, dizzy cap, reset timing, air filter etc... no oil burn, runs mint.
I would like to trade for an MPG car or car plus cash on your end if it is a rough car
4.0 inline 6
5.5 inch extended and adjustable 3 link long arms in the front
Rc adjustable arms in the rear
4.5 inch Rc springs
AWD full time t case swap from a V8
Rc swaybar quick disconnects
ARB bumper
Adjustable Trac bars
Rustys extended travel shocks
Steering stabilizer
Fog lights
2" spacers
33 inch TSL swampers 2 good tread 2 low tread
Every option available, heated seats, sunroof and leather
The bad stuff
Exhaust manifold gasket could be replaced
Needs alignment
Control arm bushings are shot
Power steering leaks
Transmission hose leaks
AC and heat blower motor does not work (fuse? Looking into it)
Sunroof is caulked shut but the motor works (previous owner did this)
plates transferred and registered.
Had to hustle on it in case they caught that the NC title was dated in march, and no weight on title... kid going to Europe next week for a year and his address and licences is still in NC.
Kid some how got it notarized without a buyer filled in lol
date modification and googled the weight lol
all set
put some miles on this thing today. its functional. talking with work people sounds like the shudder is the torque converter that has some vans let go.
threw up on the lift. serviced front brake sliders, replaced missing bolts, starter inspecting ever thing.
under body clean.
changed wheel spacers to 2" instead of 1.5" with missing studs and missing inner lug nuts :o
gona try to cut and stretch rear links 1-1.5" in the rear to fit 35 SCRs. eventually i think this thing is 1ton swap and 40's worthy.
o wow
http://www.rustysoffroad.com/jeep-suspension/jeep-suspension-lift-kits/zj-grand-cherokee-93-98-jeep-suspension-lift-kits/rustys-zj-grand-cherokee-long-arm-upgrade.html
1350$
night two on this guy. serous progress.
adjustable rear control arms found to have super long threads, and i was able to safely increase the length of all 4 links by 1.5" to clear 35"s in the forward portion of the rear fender well, and trimming in the rear portion of the rear wells.
Front was good with a fender trim fix and ARB bumper trim.
Found front CV drive shaft to have exploded and shot CV joint at case. was hopping that was my low speed shudder but no good.
trans was 1.5 quarts low
returned from a test drive, radiator hose torn and spraying. fixed.
runs mint looks mint. started tending to things like bulbs and headliner fixes.
needs a good vacuuming but driving tomorrow!
drove to work!
looks like a sweet machine!
really nice stance as is
rear stretch and trim i did last night worked out great
front trim fix also really cleaned up the lines.
ill throw some rock sliders on it to get rid of the only 4 rust holes on the truck. rest of truck 100% clean with some southern clay red mud on it!
i keep thinking there is something wrong with the motor
then i remember its a 4.0 pushing 35"s instead of a 5.9 pushing 30"s :'(
ordered front header panel and all new front end lights
blown out, vacuumed, and changed a rear brake light bulb! solid night of wrenching!
found that blower motor goes high when you touch a random wire hanging from under the dash to ground lol
its hot.
solid 20 mile trip no issues. comfy ride
i think this thing is starting in 2nd though
reading says Governor Pressure Sensor and Solenoid may be the issue, or sometimes down stream o2 frayed / shorting wires flake out the GPS&S reading.
my first jeep was a 95 4.0 with same 42RE trans.
the TCM failed and it stuck in 3rd all the time.
sounds like a different issue, but just FYI.
this thing shudders off the line, maybe slipping, some time squeels, seems very sluggish to 30MPH or so, then high gear and OD are ok. somp on it doing 45, it down shifts and goes.
guess i need to pay more attention and adjust the wheel so i can see the tach also would help lol
reverse no issues.
I experienced a lot of 2nd or 3rd gear start (usually called as limp mode) with the 47re my dodge. 42-48re are relatively same on how they work.
To get your first gear; must be completely stopped, put the shifter in neutral and wait for a second or two at minimum then manual shift *straight* to 1st gear then you should have your first gear again. When you're moving, manually up shift to confirm you have the 1-2-3-4 shifting. You'll need to come to a complete stop to shift back in neutral then shift straight to 1st again to get the 1st gear back for the take off.
Don't drive it too much if it's actually don't take off in first gear or you'll cook the trans quick.
The jeep don't throw any codes for the trans? They usually have codes set when either the governor transducer or the solenoid is malfunctioning.
The 95 have a separated module for the trans? I thought they're controlled by the PCM.
I had to manually shift my 47re from Denver>Las Vegas>Phoenix when the governor transducer broke on it. At least it was mostly on highway haha. Bah.
OBD I were weird, separate TCM on all the electronic transmissions 95 and down as I recall. I think that may be just 94-95 or maybe back to 93? hazy on that.
guess this thing has a factory alarm.
i locked doors with door button, came back unlocked driver door with key, horn beep and antitheft 2 seconds motor run only.
key lock and unlock to driver door like my 5.9 98 did not turn it off. google let me know on 97 limited you have to lock and unlock the passenger door WTF
smooth cruse control at 70 no issues on thruway. love this thing.
win.
win.
Yeah. Everyone on I-90 drove like they have a woman in labor on our way back in town. How can it be fun to drive like that?
i actually flipped off that black shit box with NJ plates that went right lane left lane right lane just squeezing by me and another car to my back left passing at a normal speed. next car that passed me at normal speed chick smiled at me haha
blew a radiator hose on the commute this morning!
hack fix i tried cutting it shorter and was good for 40 miles or so lol
Foul!
Your commute is about .4 miles... ;D
ya not sure why it didnt blow or care driving it to J&J
back in business with a new radiator hose.
limited mirrors i got are not auto dim, and dont fit 100% my limited. wedged in and power function doesnt work then. Black frames dont fit either. fail.
gross evap leak o no you didnt!
new header pannel and 6 new lights installed. had to pull ARB bumper
headlight switch swapped, does the same thing, only interior night lights come on when you push on or near it
center console lid with working latch swapped.
rear plate light fixed. had to pull hatch plastics and fix a break in the wire harness. not even sure how i found it but got lucky.
front left shock bushing changed
right swaybar disconnect fixed
steering stabilizer mount to tie rod fixed
horns connected back up
head lights adjusted.
whats left:
no obvious evap issues at canister, lines, or tank
dome light no work from any door when doors opened, but works of you turn them on
HTR control
hatch calendars
rear brakes screech 100% of time after sitting, no noise on lift odd.
headliner glue up spots
Dome light:
If you press and hold the rear light lens it will toggle between having the dome light come on with the door open and never coming on when the door opens.
no go with dome lights. may have to do with rear dome never comes on, bulb looks good.
front inner fenders pounded in for 35" turning full lock.
rear brakes disassembled and seized ebrake hardware freed up and lubed.
ebrake adjustor in seized and ebrakes adjusted and working.
tank dropped all looks good but found pump nut retainer ring pretty loose. tightened and cleared code.
tires sold for 180 that came with this unit. mismatched bald dry rot 33's on jeep wheels. 100$ in wheels 10$ in rubber.
investment down to 620$ for this unit 8)
trans still same
kind of annoying.
notice there is a hack fix on the TV cable. going to try and swap that first, and adjust it as per web instructions.
if not, going to try and research governor sol / governor pressure sensor.
if that fails ill pull the trans and replace with spare. lines weeping anyway.
still need to get inspected. dropped tank, cant find LARGE evap leak to fix code. smell gas in rear on multiple occasions upon shut down. maybe its as simple as a bad gas cap? hoses and clamps all new and tight. canister lines look good.
There's any codes set for the trans?
When it shakes, the rpm bounces? It slips or it felt like it either upshift/downshift or TCC lock/unlock?
rear hatch struts changed
gas cap changed- still smelled gas this morning
rear dome light bulb changed, still no rear dome or any dome lights ever.
The light isn't as simple as a factory dome override switch activated or inoperative, is it?
seems inop
dome rear has a switch to turn on or off doom lights with doors open, i am thinking its a power issue in the hatch since i have never had that light or any of the doom lights come on. door panel courtesy lights work as they should.
the vic is also gone, but sure if that has anything to do with it.
hopped on thruway yesterday to go see mom, realized tank was empty, stopped in Batavia to fill. proceeded to pump 22.5 gallons into the jeep and 1.5 gallons on the ground.
Evap leak probably coming from top of tank somewhere lol.
guess the tank needs to be dropped again and inspected / gasket changed
bah
rebuilt front CV shaft and installed for winter 4x4
changed sway bar bushings
bipassed whatever is wrong with heater control so has working heat and defrost
dropped tank and changed fuel pump/sending unit.
tank to pump had NO gasket present- gross evap leak identified.
now fuel gage reads empty. cant win.
Didn't you just get home
Do laundry and each some football ;)
couple laps around Henrietta Tokyo drifting in the snow knocked the sender loose and working.
foot ball sucks and i need a 4x4 jeep, next is the plow truck. i am thinking i should have worked on the plow truck sunday instead of the jeep lol
it'll melt. I'm counting on it.
tractor is in the back yard with the mower deck still on, ready to do the last of the leaves!
Same boat here...
ordered a solenoid and pressure sensor kit for transmission. going to give it a go at fixing trans issue!
3-4 spring change
https://www.youtube.com/watch?v=6oMC-r1OXzI
gove press and sol replace
https://www.youtube.com/watch?v=kvl-_-vY6rk&t=3s
lockup spring
(http://www.oregonperformancetransmission.com/mm5/graphics/00000001/SNX-22771-19K.jpg)
fail.
3hrs, fluid, 100$ parts.
no change, same. maybe 1-2 shift 5% better. still shudders at takeoff
swapped TV cable that was hack fixed, played with it- no change
fluids topped
noticed coolant was low last week- steam occured last local drive. heater core hoses rotted out and failed at Tstat housing.
great.
both heater core hoses replaced. its really painful to get the advance guy to just sell you 3' of 3/4" and 5/8" ID HTR hose :(
reason to not go to advance
yes i know, sadly.
played tow truck for Matt last night
my jeep ended up past the truck in the background of this picture before we got him back far enough to pop out of the ditch
got an oil and filter change today at 239xxx
new cold stumble for a minute or so at idle last couple weeks. found #1 spark plug to be loose in hole and gave it 3 full turns to snug, neat.
front rugged ridge tie rod shot. its a 50$ goofy unit bah.
tie rod installed and aligned.
got a sticker last week no issues.
seems to have a coolant leak when parked. must have something to do with pulley squeeking last few months. probably needs a water pump or something.
was put out back from leaking coolant last week
new lower hose no fix
2nd time around, had to pull the front apart to change water pump, leaking from block interface or somewhere.
got an AC delete pulley and a good coolant flush.
Back to daily duty.
2.5"x3.5" rockers burned in tonight. need more paint to finish second side.
probably gona get a trans swap and put up for sale. need to thin the fleet
rockers painted. bored with this and probably put up for sale.
might do a trans swap- or at least attempt to adjust bands.
noticed this guy was all over the road at highway speed during the highway cleanup! have been driving he 49 and CJ a lot more.
Found both ends of the track bar needing service, also found a jam nut loose on one of the drag link ends.
back in business!
finally just broke apart passenger rear door liner to get the door open. didnt find anything broken just needed lube. havent been able to open rear passenger door for at least a year!
almost started on a trans swap today. meh.
front blinker bulb and fluids topped! ready for winter.
got an oil change, front lube, and steering wheel alignment today
has a plow half mounted to it tonight haha
Oh boy...
How were those SCRs on the way home Sunday? Felt real greasy in the ole dually
The SCR's were doing work pulling the dead Ford around in the snow yesterday!
Tway was pretty salty and dry on my drive home. scrs are great if you stay in the gas, little sliddy under heavy braking and the rear wants to walk out 90 degrees if no power haha
first test plowing went well. trans seems fine with case in low range and doesnt skip at all. solid unit!
need to fix up the manual til option but power lift with ATV winch is wired. need to clean up incab but its functional and tested!
Is this the unit from the shovel?
Jonboy’s leavings
ya its a much lighter 7'4" plow than my other two full size plows i have.
its lifted by an ATV winch, and has a manual tilt function.
Made a pin mount and structure out of old 2x2 square buggy links. Was supprised the jeep only drops about 1/2" when you pick up the plow.
pushes snow fine, maybe needs the springs tightened up for frozen snow now in the lot
Sweet
for future reference, this is a thing that apparently exists
https://www.amazon.com/Buyers-Products-SW710-Rotary-Switch/dp/B01D05Z2LS/ref=pd_rhf_dp_s_qp_0_3?_encoding=UTF8&pd_rd_i=B01D05Z2LS&pd_rd_r=MKWNEYBE08MJDDPQAPS5&pd_rd_w=Ez99I&pd_rd_wg=cbnL7&psc=1&refRID=MKWNEYBE08MJDDPQAPS5
mostly unrelated but interesting: small 200a relay, only $14.
https://www.amazon.com/OLS-Split-Charge-Relay-Switch/dp/B01MYPTVJD/ref=pd_rhf_dp_s_qp_0_35?_encoding=UTF8&pd_rd_i=B01MYPTVJD&pd_rd_r=Y1J5MHBVEPBKHNPW44T0&pd_rd_w=PwS0q&pd_rd_wg=ouDbI&psc=1&refRID=Y1J5MHBVEPBKHNPW44T0
I wonder if they're really good to 200a
this looks like a reversing relay, with a 3 dollar switch this would be great for me
https://www.amazon.com/dp/B004VAGKZE/ref=psdc_15731411_t1_B00KGICYAA
I already have one of those on the way.
plow controls poked through fire wall.
so much nicer to plow with a fuel injected auto with heat and radio! needed this 6 years ago!
ordered a few 50amp 5gage quick connects so i can drop the plow. I think a 400$ XJ will be procured next year for plow duties if im still in the same location. Too easy.
oil change
trans fluids topped off
looks like it needs trans cooler lines and at least one ball joint
plow frame attached
cleaned out
needs a new switch for heater blower and should be good for winter duty minus a valid inspection sticker
still a sweet plowing machine.
borrowed time and in need of service on this unit.
sweet burning ATF machine and got awful front end issues. sticker is almost 2 years out and needs a windsheild. might be time to send
getting a windshield today!
trans cooler line leaks repaired
cracked exhaust manifold welded
tail pipe welded back to muffler
failed inspection for multiple front end issues. if i thought he was going to actually look at it i wouldn't have bothered lol
all front end parts and brakes ordered. i think i have unit bearings in stock.
silly that entire V8 steering is cheaper than one replacement tie rod end for the rugged ridge system thats on the jeep.
bah.
between this and a new windsheild, should have just bought another jeep!
1997 JEEP GRAND CHEROKEE 4.0L L6
ACDELCO 46D0058A Ball Joint $ 10.47 $ 0.00 2 $ 20.94
ACDELCO 46D2117A Ball Joint $ 10.87 $ 0.00 2 $ 21.74
CARDONE 663220 (66-3220) CV Half Shaft Assembly $ 35.79 $ 0.00 1 $ 35.79
CARDONE 663221 (66-3221) CV Half Shaft Assembly $ 44.79 $ 0.00 1 $ 44.79
CENTRIC 10206660 (102.06660) Brake Pad $ 9.02 $ 0.00 1 $ 9.02
CENTRIC 10204770 (102.04770) Brake Pad $ 9.70 $ 0.00 1 $ 9.70
CENTRIC 12167032 (121.67032) Rotor $ 15.36 $ 0.00 2 $ 30.72
CENTRIC 12167022 (121.67022) Rotor $ 16.94 $ 0.00 2 $ 33.88
CENTRIC 11861037 (118.61037) Parking Brake Hardware Kit $ 11.73 $ 0.00 1 $ 11.73
CENTRIC 11007010 (110.07010) Parking Brake Shoe $ 8.97 $ 0.00 1 $ 8.97
1997 JEEP GRAND CHEROKEE 5.2L V8
SKP SDS1310 Tie Rod End $ 20.79 $ 0.00 1 $ 20.79
SKP SDS1312 Tie Rod End $ 16.66 $ 0.00 1 $ 16.66
SKP SES3096L Tie Rod End $ 4.54 $ 0.00 2 $ 9.08
SKP SPES2079S Tie Rod End Adjusting Sleeve $ 4.35 $ 0.00 2 $ 8.70
Discount $ -14.12
Shipping Ground $ 59.95
Tax $ 26.27
Order Total $ 354.61
i guess i still know how to work on jeeps. not bad.
installed everything above tonight in 4 hours.
got a sticker yesterday, reg renewed today!
good for another 2 years whooo
anyone ever adjust the front band on a 42re? looks fairly straight forward once you manage to get access to it.
i have shudder/ slipping from stop to 1-2MPH if load is anything over minimal untill speed gets above 3-5mph. not RPM related.
adjusted bands on the 44RE in my Dakota a few times. Easy procedure: tighten until touching (I think it's 12 or 18 inch-pounds or similar) and back off prescribed number of turns, and tighten the lock nut. One is on the side of the trans and one is in the pan IIRC.
ya did some reading. its just buried to get to.
nothing that clearly relates to any symptom i have. replaced the bag of normal parts you through at a 42RE and nothing changed. has not changed its performance or issue in 5 years, same issue with prevous owner also.
last issue with the jeep id like to fix after putting glass and parts into it this time around. bah
Kim's Venza developed similar symptom forever ago. Toyota said full trans rebuild, it's gonna grenade within months. She's still driving it without having touched that $3500 job as far as I know. Probably put 60k on it since. It was light throttle 2-3 shift on a 6 speed. Felt fine in as full-boogie as a 2.7L 4cyl can do.
42RE is a lot easier to find than an AWD Toyota trans. Shame they're probably all raped.
i have a known good spare sitting downstairs same year. lost the known good TQ in the move though. pulling and swap is a pain with the long arm kit it has installed so that's why it hasn't occurred. Not hard failing also makes swap effort not exciting.
The shudder still occurs when shifted in “low�
I still think it’s something to do with drivetrain. I remember it’s transmission mount is very ‘soft’ and allowing a ton of movement. Ratchet strap the t-case down onto the trans crossmember tight and go test drive and see what change.
not going to waste my time with thinking it has anything to do with drive train. 100% obvious a trans issue. yes occurs in D and 1, but seems better or different in 1.
front band adjusted to factory spec, no change.
key cycle says trans code 12
looks like im checking some tail harness connections and changing a speed sensor
Tranny codes for 1994 OD button LED
11 Engine RPM input
12 Output shaft sensor input
13 Vehicle speed input
14 Governor pressure sensor input
15 Throttle position sensor input
16 Transmission fluid temperature input
17 Overdrive override (control) switch input
18 System voltage
19 Internal fault in module
21 Governor pressure solenoid output
22 Overdrive solenoid output
23 Converter clutch solenoid output
24 Overdrive override (control switch) lamp output
25 Internal fault in module
26 Governor pressure sensor offset drift
55 End of code transmission
new output speed sensor installed. no change
could it be the transmission itself is fucked and a new rebuilt tranny fixes your troubles?
ill pull the pan and adjust the rear band- that's the last thing i can do, then im done again trying to fix it.
not worth pulling and swapping without a catastrophic failure, especially with 3x the work involved with the long arm kit in the way. it drives fine for me, and even plows snow fine if you are not a moron.
Rear band has nothing to do with your symptom. It’s only used when shifted into R or L
That doesn’t make sense. Shifter position doesn’t impact what the trans does in 1st gear, whether in low/1/2/D
I don’t know what band is which but 1 and R typically share the lowest gear
no L selection in this application. 12DNR
shifts and acts much better when manually shifted. still has the issue though to some extent.
Sorry, L and 1 means same thing. Service manual call 1st gear selection as “lowâ€, so...
The rear band sparsely get used as it only engages when manually shifted into 1st/L or R. Pretty much why it’s buried inside as it hardly ever need adjusting for most people, or why you see a lot of old Ram plow trucks for sale saying “no reverse†from shifting between D and R all night long.
Trans get its first gear different way when shifter is in “Dâ€
Crazy.
Automagic
Crazy.
Automagic
Crazy.
Automagic
Crazy.
Automagic
Crazy.
Automagic
Insanity
yearly service on the lift tonight
3.5 quarts low on trans fluid
1.5 quarts low on tcase
diffs and motor good
doors lubed
front end lubed
rock rails stripped and painted
interior semi cleaned out
ready for winter season
pulled plow today
fill trans
spent time on 3 seized doors and seized rear hatch. won on all of them except rear passenger door i cant get open. tired hard.
pulled plow today
Now that you've done it, expect some snow soon! ;D ;D
picked up a torque converter for this guy tonight. i guess i am going to commit to pulling the long arm out to get the trans out- try the new TQ, and then if no change, swap in the spare trans i have that was known good from another 97 ZJ i cut up with bad motor. (lost TQ in move )
threw a battery in this thing, fired right up and pulled into shop.
have to fix it or turn the plates in next monday. bah!
looks like the long arm cross member is getting sectioned and made removable.
trans out
new converter installed.
no change.
BAH!
At least you won’t have a question mark trans on the shelf I guess. I’d have been very very sorely tempted to swap both at once.
i would have but i have already done all the 42RE valve body fixes to this trans, and it functions great other than the 1st gear shudder/slippage.
the other trans was out of a ZJ that one of chips girlfriends sons seized the motor in on 390, supposed functional trans. meh
swapped in the second trans, all seems to function and do all slush box things without complaint!
all gears work, down shifts, OD, ect.
just had a small drip per 4 seconds i noticed after filling but pretended i didnt see it before test drive. back on the lift after i remembered i left one of cooler lines finger tight that i had to swap, all good now!
i guess the jeep will get a muffler and tail pipe, a trans pan gasket and filter, and look at some front steering leaks. other wise if i can get the monitors to set maybe ill try to get a sticker this week and get reg renewed.
Neat
RA sells a full extensive rebuild kit for 42RE for 136$
i guess ill explore that when this one gives up- now i know i have a good Spare TC and a good spare assemble with 1st gear issues only.
ran to buffalo and back tonight in this hog.
wasn't making temp on the way down past 130, so stopped mid way home and beat on the thermostat housing which it then sat at 210- got the 5th of 7 emissions monitors to set shortly after that. 6th should run purge tomorrow since the tank is now between 1/4 and 3/4 and should be able to pass plug in even if the last one doesnt run.
trans and cruse works great.
id say the tires are a mess, needs a valve cover gasket (constant oil burn smell if fresh air intake HVAC is on), needs probably full exhaust over haul and brakes are dragging /squeaking intermittently from sitting so long.
otherwise, plenty fine for winter duty if it sticks around.
Fresh sticker today so should be ready for another two years of service!
hasnt had heat in a while and temp gage reading 100 or so. it got a new Tstat a few weeks ago to fix and all good. picked up a new AC delete pulley because the one i put on years ago its talking pretty good.
shot out to buffalo and back today, high way cruse control machine. :o
pushed a lot of snow this morning, might need to put some drive SCRs on the front for winter instead of steer cuts, but other wise she hawgs pretty good with the new to it transmission.
it does want to stall now though when going from revers to drive or drive to reverse. need to google that and see if its something that can be fixed / adjusted.
bAH, rear D35 gear set gave up from heavy plowing. i thought it was the front drive shaft talking, but its the rear set
looking for a used D35 3.54 get set.
3.54 gears are blown. i started dissasembly thinking it was an 8,25 which i had a used set in my pile- realized its a D35 bah.
i have a YJ 3.07 gear set that i think is the same and could pull the front drive shaft
i kinda need the jeep this week. RAM is blue sticker, needs brakes and tires and inspection done bah
I guess if i slap in the 3.07s in ill confirm YJ sets are same to a ZJ D35, and either order a 50$ used gear set off ebay, I do have a used set of 4.56 gears for the front low pinion D30, so i could commit a sin and order 4.56 gears for the D35 lol bah
Stickers are such bullshit
i still dont have a good place that will take the RAM either. its annoying.
best i can tell says all D35 gear sets are same across all jeep yj XJ MJ ZJ WJ with maybe a different pinion seal and spider gear differences of course.
amazon has 139$ 4.56 D35 gear sets and i already have the 3.54 and up carrier. have mismatched stuff for the front in stock. i guess ill go that way, but to get it off the lift it will get 3.07s slapped in it. its already apart and C clip, o well.
ill stop rambling about this misfortune now
Lol
I have the D35 3.54 ring and pinion from my Comanche sitting in a box at home. 190k or so on them. If you can confirm they'll fit, I can ship to you. It's an early non c-clip axle, not sure what other differences may exist.
Bummer, I was just home last week
45$ on ebay got me a used 3.54 set headed my way, thanks
still plows snow with a few pinion teeth missing :o
once the transmission warms up it shudders and stalls/locks up in reverse- i guess this trans has always been like this since installed i just didnt notice till plowing. annoying.
i think its time for a new wonder this year sometime.
ebay rear gear set installed, fixed front squirters too!
I know its not around the corner, but have you tried Scotty's?
talk to pauly and tell him you know arie and me
more 42RE sighs.
trans performs 100% cold, but very shortly once it warms up begins to want to "stay locked up" when coming to a stop (occasionally), and after a short drive will lock and stall engine if you shift to reverse (100% of time warm) from park/neutral. like if you pull into a parking spot at a store, it better be a pull through...
my research shows:
could be issue with brake switch not giving signal to unlock TC
bad TCC solonoid
bad TC (less than 500miles on new TC when trans installed)
not really anything i can find that sounds like a smoking gun
annoying!
i have had this transmission out twice now, and i have fixed or bipassed cooler lines at least 2 other times.
how is it that i did not realized until today there is a check valve in one of the cooler lines?
i was flushing out the cooler with air and noticed it only going one way. pulled the pan and valve body today and did the HD upgrade kit. filter and magnet was packed with fines but not chunks or hard parts in the pan.
if this doesn't change it, im guessing the new torque converter has failed or the lockup solenoid is intermittently bad.
and zero change with the 42RE fix kit, filter, fluids. another 150$ down the drain.
i guess next will be a brake light switch and then a lockup solenoid- but its probably better to just get another jeep. really sad this TN truck still has no exterior rust and isnt falling apart.
I vote TCC
i bought all the ATF+4 in my zip code that was available on the shelf.... i guess its time to start stocking 5 gal buckets like i do in gear oil.
also, the HD kit i got came with a " Lock-up Spring (Heavy Duty) Upgrade" and the internet could not tell me its location, i gave up trying to find it.
https://www.ebay.com/itm/194073381775
soleniods are common issues. no cracked accumulator pistons when you did the upgrades? I remember that being a thing from my Dakota days
the govenor pressure sensor / solenoid is the well known failure in the 42RE and apparently a big snap ring breaks and you loose reverse and then 4th.
neither were issues in both transmissions i have.
i have found one or two threads that describe exactly what i have by the poster, but no clear resolution ever posted.
ill try the TCC solenoid and brake switch next time its back in the shop. had to put the snow plow back on today.
new shoes mounted today.
tire machine wires pretty good- plenty of room for a 35 or 37
these measure out at about 33"
empty equipment trailer behind this unit almost deleted the trailer hitch. apparently more structural rot than i had though.
wonder if the dealer will put a new hitch on for the exploding gas tank rear collision fix recall, or if crusty rotten brokenness deems it safe enough not to replace.
tried some seat covers as ZJ seat bottoms are impossible to find in 2022
better than $29.95 rando ones but not sure worth the 109$ i spent. bottoms fit nice, backs are too loose. bottoms need better side fastening.
TCC solenoid came in and i have a 5 gal bucket of sny ATF+4 now.
im really starting to think its a valve body problem. i have another 42re i could rob the valve body from and it can be changed from underneath. i guess i have to think if i should do that first or second. i guess its only fluid and pan gaskets
spare trans on the bench and pulled apart, a few you tube videos later jeep on lift, valve body pulled.
plan is to swap valve bodies, adjust both bands, replace governor and pressure sensor, replace lockup solenoid and harness, fresh filter and fluid.
reverse band was about 2 turns too loose.... not sure what that means meh.
might be fixed or at least more better?
it just kinda lugs a little bit now in reverse now but doesnt lock up and clank / stall any more.
asked will if he has a fancy scan tool i can borrow
one thing thats different. if you do a rolling shift from drive to reverse, it doesnt go into revers unless you hit gas.
found one thread said fix was pump replacement. maybe scan tool will say if pump pressure is low?
bah
at least i didnt break it worse doing all what i did.
pulled in today, fluids topped off
no codes but has 2 monitors not set, wont pass. evap and catalist. cant remember when last dead battery was but has to be weeks and hundreds of miles ago so thats a bummer.
sticker up, i guess it will get a buffalo trip to hopefully set monitors.
fresh red sticker, whoohoo
has sat since may this year
put a fresh battery in it
aired up a tire, 2 quarts of atf, washed windsheild and dash
first trip to buffalo and back tonight excellent performance!
just about to hit 250K this week.
latest update has been giving a CEL for no lockup RPM change, and i notice i loose OD after about 30-40min on highway speed / warm. Fluid was low, and also added some lucas trans fix that i found free in a parts jeep. similar result though after last buffalo trip. I need to order more ATF+4. price has doubled this year bah.
yesterday single digitF starter motor would not fire. not a power or solenoid issue.
today, it took 3 or 4 clicks same result but it did fire over (with pleanty of power) and restarted hot at bank and HF no issues.
Im guessing i should just throw a starter motor at it next time the lift is free so i dont get stranded after 2 warnings.
no repeated starter motor issues
pass side low beam out noticed last night. found 2 new bulbs in glove box score!
headlight bulbs changed, tires aired up, plow removed (last time?)
3hrs or so of city runarounds today with Chip in this unit, got some sticking calipers putting some major heat into front rotors haha
ordered new front calipers and braided hoses. probably should get rear calipers and new rotors/pads all around.
still takes overdrive away after about 30 min of driving, and new thing falls to zero oil pressure at idle once hot. must be a fake FCA gage thing because it would have blown up or started tapping by now lol
ha
found driver front shock broke free from axle, blown bushing on passenger front ratteling around
changed both front calipers and brake hoses, driver hardline crumbled when i touched it. changed both sides hardlines. bled
greased all fittings, removed plow frame, changed oil / filter
tied up some hanging trans cooler lines
rear brakes all look shot. so that will be next time.
Well I guess whatever I did with the Trans lines I should have left alone. Looks like it blew as I backed out of lot away from house. Noticed smoke show pulled I to fuel station, saw garden hose leak of atf everywhere, drove right back home barely and shut it off coasting back to shop. Left a nice blog trail everywhere.
This may be the end of this thing. Bah
i feel mildly better about this now- what i touched and re hung a few weeks ago was not failure point. hose popped off at trans on other end.
pulled both hoses and added bubbles to hard lines, replaced 2 clamps at each of the 4 locations, new 300psi trans cooler hose. filled and tested good.
back to full duty i guess again.
not sure im going to order the rear rotors and calipers / hoses it needs. i think its gotten enough thrown at it for the year.
i did notice the cirp belt is about to come apart. found a brand new one in the glove box when i checked to see if an old spare was there or not before leaving on maden voyage with trans lines.
wegmans trip and back no issues.
i guess ill change a belt today bah
belt changed. added 10 gals of recovered stale hot rod donar fuel haha
tossed a battey in, 2 quarts of ATF, and 30$ in fuel for its maiden winter voyage. i dont think its moved since July when it got taken to the shop for a sticker.
needs brakes all 4 corners. was expecting a blown line, but no the brakes just suck.
hawged to wegmans and back to get a turkey and some thanksgiving supplies.
lift work it needs: oil change, 4 calipers, 4 rotors, pads, ebrake stuff, center steering wheel, air up tires, clean out organize winter recovery stuff.
4pad sets, 4rotors, 2calipers, wipers
plow on. welded broken plow mount. fresh section of wire rope for the lift winch
