Projects place => Classifieds => Wanted => Topic started by: KingtheZJ on August 31, 2015, 10:12:51 AM
looking for tires or wheels and tries for my cummins
preferably used
285s ish
anyone have anything lying around?
Related, what do you recommend for ball joints?
I have stuck to MOOG chassis components when I can - but that's based on many many years ago info. These days I trust Arie's judgement :)
whatever arie says.
borrow or bring the truck to my shop to use the M4 ball joint press. will save you 4 hours of swearing and pounding on a C clamp style garbage press.
I shall default to the recommendation of the parts master.
I will definitely take you up on the M4 ball joint press. thanks
Looking for (2) 285/70r17 load range E with good tread
gona rock H2's noice!
The guy I just didn't buy snows from has 4 265/75R 17 no – name load range E for 100 bucks if you're interested.
I am potentially.
Can you send his number my way?
thanks
I used XRF ball joints in my truck but one got a little loose after 60k-ish miles. I replaced them with MOOG from AAP so that way I can get them warranted and replaced on my truck in a day. My HF ball joint press with HF's ball joint press adapter set work perfectly.
