Projects place => Projects Section => Topic started by: M4wdFab on February 28, 2015, 04:29:01 PM
do i spy a new brolite on the deck headed home!?!
(http://tapatalk.imageshack.com/v2/15/02/28/f476ff6cb5a51b9f60c65f179324681a.jpg)
He was driving it w brokenfront spring hangers. Brake line went and he driove it for 3 more days. Shop couldn't fix it since they can't pick it up.
$300 '97
THE PURPLE PEOPLE EATER!!!
Yeeehaw!
300$ is a sweet score
(http://tapatalk.imageshack.com/v2/15/03/10/b03eeec46e44f214707145d0dd1a5ce3.jpg)
Tonight's objective: remove broken shit. Bed, spring hangers, etc. Inventory exhaust. Fix brakes. Maybe get to installing things?
take your biggest breaker bar and just snap all the bolts from the top side, lift bed off.
I glanced - giant torx? I may need to buy a tool. Or grind heads off. I think t40 is as big as I own
they go into clip nuts that just snap into holes. actually nice way to do it. i assume a bed mount kit you just use new hardware and clip nuts
ya big torx i think
45 rings a bell
T55. HF "pro" torx set is the shit. Impacted all 6 out. No twist no issue.
Rotten frame behind gas tank needs patching. Scale was completely hiding that until we were pounding rivets out. One crossmember is Swiss cheese. All hangers are off. Leaves look good.
Need two spring bolts, intermediate pipe between cat and muffler.
Fuel tank straps are gone. probably ignore that. Wish I could ignore exhaust as easily!
Bad brake line is up front somewhere. Everything under the bed is new.
(http://tapatalk.imageshack.com/v2/15/03/10/281dc21df577fef097123d0db3071ccb.jpg)
(http://tapatalk.imageshack.com/v2/15/03/10/e282af65e0394c4e13833fc9b810de95.jpg)(http://tapatalk.imageshack.com/v2/15/03/10/257a4f08a8133fe85319405b4217f0d5.jpg)(http://tapatalk.imageshack.com/v2/15/03/10/7a2eac01e34a27a678563b0efee8cf3e.jpg)
You owned a 40 or less torx and were in a "jeep-ish" club? ?? For shame!!! Lol
this dream of streatable is going to slow progress down
I'm aware...
not for lack of parts...
i made sure we have everything :)
...and Kim's doing work! Go Kim!
Did I mention that only the replaced right rear hanger and shackle were still present, all three others had failed? Extra scary. The bad brake line probably saved a bus full of orphans and blind nuns.
He didn't own a jeep silly!
Dakota s have poprivets!
Does that have a rear swaybar?
Yup. Seems to be 100% good. Is that not standard issue? It probably had a lot to do with the rearend not entirely vacating the truck
I'm pretty sure mine didn't have one.
no sway bar on mine or ryans
#bropro
"handling package" some came with looks like
tonight's goals: remove fuel tank, patch bad spot on frame (and check for others), maybe replace rotten crossmember, mount rear axle w shackles flipped, fix brake line, consider fuel tank mounting, reinstall bed.
Frame patch finished unless I don't like something in daylight.
(http://tapatalk.imageshack.com/v2/15/03/16/812170ac20e5d449c6427c77da66c867.jpg)
Next session: hang front of springs, tank and exhaust in, bed on, tighten spring bolts, flip it around in the garage and do a brake line. Done. ?
ready for some Fox shocks yet? i should have numbers tomorrow. took input from decker to further tune what Erik and him are running for the build.
Once you have specs and numbers, can you send them our way? I would like to place our first order in the racer program and establish a history.
lemme know, should be no reason not to submit an order.
Out of the garage this afternoon. Frame and suspension done, exhaust done. Needs brake line and bed installed.
Flipped shackles seem really low. Maybe 5" from tube to frame with a full tank, spare tire, bumper and no bed.
status?
yup.
getting shocks should be the first hurtle to not stall on. no shocks no point in trying to build for Batavia.
rest is easy :)
still street-able as a goal once its been bro'd? or bro now with caution so can be made back to street next phase
No title-no street. Easy.
Get going on shocks!
Rest is easy peasy!
When are we scheduling the first bro night?
i have an offer for 1000$ for my (4) used 16" 2.5 profenders. not sure ill take it from a rando, would give them to you for 1K though haha
That sounds like more of a bitch to try and package up front than anything, no?
im running 12"s up front there is probabaly 8"to the hood. probably dont use 2" of uptravel where they are mounted.
8 or 10" would be more than enough up front. gets tight near the Brake booster
monthly bump :-\
100% out for sept race. available to staff
boo.
And im shopping for a rental bro- looking at another extened cab this weekend
Rental bro to be done by the sept race?
If so PM me.
get a seat and cell ordered!
boo.
agreed.
for the best, I guess. More important and longer term things have priority. Also, avoiding fines from Brighton.
Get shocks ordered asap
is this unit for sale mike?
Whats the offer? I haven’t seen another one for 300, seems like I shouldn’t let it go for cheaper than I can replace it. It could go. Just gonna sit and tie up my garage all winter most likely
Sucks but the whole partner project aspect kinda got distracted with jumping out of aircraft
I have too much going on to build it solo and we’ve got plenty of house shit to work on together. Would be nice to have something for fun. Next year I guess.
sell it
may have a buyer here at delphi. or i could build it / store it and you could decided on buyback next year.
i prefer the extended cab though
come on brolite for oct 24!
that weekend is my deadline to have mule and dakota gone and tdi running.
definitely can't build a truck.
want to go anyway. not sure if there will be any chances for u4 rounds, I'm guessing not since I got the impression things are already set and brolites are the added event to an existing race.
sell it to Matt or Bill then
Bill?
Bill is a dyno guy i work with, he is looking for one to build a bro
400 for anyone I know here. 300 if you twist my arm hard. 500 to a rando.
I've never seen someone get talked down that easy!
Same pricing structure for the mule? :D
it's the "I paid nothing but don't want to sell but don't have time to store/project" pricing structure.
mule is more like $500 trans, $500 axles, $350 tcase, and probably $300 in scrap minus a day's labor pricing structure. I would take $500 for it right now with no tires if it was going to do something more than get scrapped, or I'd take buyer's choice of the 800 I have into it, or 50% of profit, if it is being parted/scraped.
(arm twist discount may apply)
Sold for 300.
hey you got enough haha
bidding war!
Do I hear 325? :D
I'm still high bidder on this page!
300.00
Going once?
nope. not yet.
just made a jeggs cart
683$ will get you
Shopping Cart
Terrain Suspension Seat
Black Velour
Part Number # 942-80-1620-61
This item will ship Today.
$173.66 $173.66
Fuel Cell w/Steel Can
12 Gallon
(1) -8AN Male Outlet
(1) -8AN Male Rollover Vent
19"L x 19"W x 11"H
Part Number # 555-15511
$191.99 $191.99
Blue High-Flow Fuel Cell Bulkhead Fitting
-6AN
Part Number # 555-100560
$11.99 $11.99
AN Female to Hose Barb Adapter
-6AN Female to 3/8" ID Hose
Blue
Part Number # 555-100845
$6.99 $6.99
Barb Swivel Fitting
-8AN Female x 3/8 Barb
Each
Part Number # 259-98201
$8.99 $17.98
Master Battery Disconnect Switch
125 Amps
3/4" Mounting Hole
3/8" Terminals
No Faceplate
Part Number # 555-10305
$22.99 $22.99
5-Point Cam-Lock Racing Harness
Black
Part Number # 140-30298
$64.95 $64.95
Remove
3/8" Universal Fuel Hose
Length: 25'
Part Number # 555-15998
$24.99 $24.99
5/16" Universal Fuel Hose
Length: 25'
Part Number # 555-15995
$20.99 $20.99
In-Line Gasoline Filter
Height: 3.67"
In/Out: 3/8" Tube Connector
Diameter: 1.75"
Part Number # 410-G3
$4.69 $4.69
Universal 28x19x2.2 Gm Chevy Aluminum Radiator TL-BR O/Lets Non Polished
Part Number # 746-PCE190.1018
This item is expected to ship in 24hrs.
$125.00 $125.00
14" Straight Blade Electric Fan
Height: 14.5"
Width: 14.875"
Thickness: 3.5"
Blades: 10
CFM: 1,585
RPM's: 1,945
Amp Draw: 7.9
Part Number # 746-PCE185.1007
$17.25 $17.25
Shipping Options
FREE Ground Subtotal:$683.47
FREE Handling: $0.00 FREE Shipping:$0.00Tax:$0.00
Total: $683.47
seat
fuel cell
AN fittings
Filter
MS disco
Radiator
Radiator Fan
short of tube, shocks, fire ext, and radiator hoses, clamps thats a bro.
$301 sold!
man you guys are rough on mike
$302 8)
I like purple much better than the pink one.... but the pink one has the short bed
I thought the MMTR unit was a short bed...
This is a short bed reg cab.
Eric is the only one with any arm twist since I've owed him a case of cider forever...
You all need to do better ;)
Like I don't deserve it ::)
have a feeling this will be delivered to Henrietta...... ;D
Hey guys...
I didn't set the price and then knock it down in the same post.
I just saw an opportunity to buy another running and driving truck for parts.
It's worth 300.00 to me
Or apparently 302.00 now.
LOL
That's my limit
No hard feelings if you sell it
To mike or matt.
you should gut this thing so i can use it for mock up. i have 3 sets of cage pillars to do now :)
bro build in 2 weeks after April race right :)
order some parts to have on hand! full broabrication will be in full operation at M4 after the Rausch race.
fuel cell, fuel pump, seat, harness, shutoff switch, shocks, bumps.
forgetting anything outside misc consumables & steel?
tire plan?
stock shocks fine. i assume stock steering wheel column.
id rather get a good radiator in there with efan but meh
o, window net?
ill help on this, planning on those first two weeks of may for Brolite
3" race bullet and a mandrel 180 will get you a clear flowing cool kid exhaust.
your probably goingto run a full front end though i bet to cut down on initial build.
you know the size radiator you put in off the top of your head?
is this the fuel pump I want? I saw 40psi spec'd but I guess if it's a return style that's really just a minimum. Is that the same pump in 571 as well?
http://www.ebay.com/itm/NEW-PREMIUM-HIGH-PERFORMANCE-INLINE-FUEL-PUMP-FORD-LINCOLN-MERCURY-GA2000-/380959815042?hash=item58b2f97582:g:1xcAAOSwxCxT0tor&vxp=mtr
asked Chris whether they know the brolite baseline tuning there
i thought the ones we got were 90 psi
more like this guy
http://www.ebay.com/itm/New-Inline-External-Mount-Fuel-Pump-70-95-PSI-For-Ford-Lincoln-Mercury-Vehicles/360985861193?_trksid=p2047675.c100010.m2109&_trkparms=aid%3D333008%26algo%3DRIC.MBE%26ao%3D1%26asc%3D20131231133846%26meid%3D841f7456ce114c1b9f317c3d42044380%26pid%3D100010%26rk%3D2%26rkt%3D19%26sd%3D121939668021
search E2000, and whatever china one comes up interchangageable.
edit:
this is what i last ordered 4 of
http://www.ebay.com/itm/221472628293?item=221472628293&viewitem=&sspagename=ADME:L:OU:US:1120&vxp=mtr
for shocks, need more compression in front. i think mine is 70/30.
my shocks might be for sale, but not sure for the first race.
i got one of these, sadly the mirror panels are not adjustable but you cant beat the price
http://www.summitracing.com/parts/AAF-ALL76405
So this this is finally getting built? Scheweeet
Hopefully in a 2 week rampage after lm@rausch
is there a set of 14s around for me to use? Maybe alloy if I'm lucky?
My steel 15s would be available to trade if needed.
Going to try the UTV tire route and see how it goes. all sizes are 6 ply rated; 14s are much cheaper than 15s.
same price as those Federal MTs. hrmph.
would be nice to compare weights. lighter == mo' betta
i think Eriks MT tires are too much lateral traction. i think a street or AT tire with large paddle groves in the rear, and steer paddles cut in the front is the way to go (and follow how miller and 2-3 top trucks run)
I've always been top 3, until I either broke or rolled over! ;)
Planning to cut my BFGs. Mostly for steering. But your point is valid. They don't slide laterally in the rear. They bite and grab.
Worst case mike you can use my spare wheels that smike has. Although they are 15". I'm most likely going to buy another truck and use its front end for #201! Looking for one with aluminum 15"
So no 14s about? Damn.
i sold my 14's with the snow tires they came with. should have kept them for the 150$
http://rochester.craigslist.org/wto/5500594014.html
Mike,
interested in grabbing this for me tonight? (you pay and pick up, with clean signed but undated title and open receipt)
ill trade it for time and materials to put in a simple cage in yours if you drop it gutted. cage would be just like mine, id leave shock mounts and seat mounts for you to do
http://syracuse.craigslist.org/cto/5505816315.html
see what I can do. you talk to him at all yet?
I see there's an overpriced xcab in need of motor in buffalo.
a few other under-a-grand regular cabs up right now too.
ever talk to the Brighton/Henrietta or Naples posts? Unless the first is you. I didn't check the phone number but it didn't sound like you...
i emailed him a bit about it, runs and moves, might need a battery, or jump, but charges good. says frame, springs and motor good. has 101K on it.
didnt talk to him about pickup or if i could get him lower than 600 on it.
your recent comments don't seem to jibe with this.
I'd love to reuse profender stuff for now and save a chunk of change while I pour dollars into the real car that's less fun. was it that much of a packaging problem up front or could I jam more shims in the compression side until Fox gets their head out of their ass and gets inventory flowing?
the problem up front is the brake booster is in the way.
I removed the clutch and went willwood, i may do the same with the brakes. A lot of my problems were because of the 35's but i still have problems with the shocks way too cloose to the coil towers (already cut down) and the booster. they have to be tipped in because they hit the tires at compression.
have to keep lower factory mount- makes things hard. if you could loose the booster and just run manual brakes, you could fit a 16" in there i bet.
i have 12 front 14 rear. 2.0 smooth. fiting a 12 2.5 will be a chore with my car with out brake changes.
i dont know if i answered your question
Maxxis Ceros tires ordered.
fronts will surely be good on factory 14s. might buy a pair of 14x9s for the 11" wide rears.
excited to see how a totally different tire setup than anyone else is running will do.
What's the weight of these brolites? The ceros going to be pushing their limit on hard jumps?
Fullsize 4dr utv ought to outweigh a well prepped bro
They’re 6 ply rated. I think thats factory on the trucks.
I didn’t bother to check maxxis to see if they list an actual weight capacity. It’ll be fine!
Load rating 935# drives and 805# steers at 18psi
Maybe close to capacity on steers.
id bet a bro is in the 2500-2800 lb range
I was thinking closer to 2300. we can see once you can just rip up the street to frstvehredvegh land! :)
Tire guy is nervous.
how nervous?
I would not run them. These truck fly like the wind.
Pre-run them with a set of something else on standby for race day.
I hope these work. I like em.
Unmounted they sit at 7†and 9†rim width. I think I’ll be ordering rear wheels.
(http://uploads.tapatalk-cdn.com/20160412/a19cb15b9e0a8d4f0518e0b215b9bf54.jpg)
Wow.
Keep that rear Trac width narrow and the front wide!
i think we are planning a tire night sometime at spensers, we can try to mount them up
wheelspacers!
Just got news that the most complicated diploma ceremony that I run is being drastically simplified this year.
That gives me a chance in hell of horse trading that work with someone else. Fingers crossed!
Otherwise I'm pretty well screwed out of the season opener.
Fingers crossed here!
you look at wheel options yet? i am going to order a 4th snow for that set. will try to round up another set of 14's or i can help towards some if you buy
holding off to see what the CL meet up tomorrow brings. i should have 4 more mounted snows on 14's and 2-3 loose 14's
I’ll probably order a pair of 14x9 from speedway
looks like they only go to 8"
http://www.speedwaymotors.com/Bassett-48SF2-14X8-D-Hole-5-on-4-5-2-Inch-Backspace-Black-Wheel,71721.html
Thought I saw a 9 somewhere. Didn’t leave the tab open though. May have been elsewhere
i will have a loose 14 at spencers tonight if you want to try one (dismounting the junk front right from the new bro)
Not sure if I'll make it over tonight or not...
I did find a pair of alloy 14x9 on fleabay for rears. If this setup works out, I'll keep an eye out for another pair of 14x9 for a second set. Otherwise I'll just go to 15s. Too much hunting.
http://www.ebay.com/itm/14x9-PRO-WHEEL-5-ON-4-5-LUG-2-/191830374819
i should have tried to get you to come over to the shop mike to see what you dont like about wills
yours will be a direct copy of the cage other than being 1.75" instead of 1.5" it turned out nice. i even fit in it almost.
I saw the back pillars were pushed back a bit. Seems good for interior room.
14x9s due to arrive Friday.
back pillars, rear roof bar, and X all outside of the cage- it turned out great.
rear down tubes all go to the frame, front pillars tied into cab body mounts like my truck with slight improvements
scratchpad:
need fuel cell, pump, line
need e-fan
need window net
get 1 more stock 14 and mount remaining tires
something for better bump stops espc in front
check radius arms
replumb & bleed brakes
check shock stash for what I've got travel-wise. may run edelbrock IAS that I have sitting around if they're long enough
will throw in a seat from 571
old 571 harnesses should be in the bed
have main shutoff. may have enough cable to relocate battery
need to empty bed
strip truck, probably put bed on flatbed and strip into it; haul straight to scrap.
- any attempts at selling anything from these? any luck? thinking a mint interior bits might be worth something, ditto air bags, maybe lights, and probably not glass.
I'm thinking leave factory wiring for now, mount cluster and stock column to A pillar spreader. interrupt alt charge/battery + with cutoff switch and hard wire the fan with a 40a fuse. simplest & quickest. Move battery to bed if I've got enough heavy gauge cable around to hit the starter from there.
Flip intake into cab for filter life? Need to adapt one of my cone filters to the right size or grab one.
would like to drop max weight: skin doors, front fenders, delete core support. mount 'glass bedsides, fender skins, door skins; attach grille to hood, pin the hood to the rad mount, and remove the rest.
Weld rear diff
everything interior is junk and plastic, just rip it out and throw away
no bed and gutted cab delivered to M4 by Wednesday should be the plan for success. Give me a night or two to get most of the cage done, then we can plasma out the front and doors, and have it ready to go minus a fuel system and shocks by saturday night.
it takes me 5 hours to gut and prep a truck
leave front windshield in until interior cage work is done (broken glass sucks!)
I have more wheels available now
scratchpad:
fuel cell:
http://www.summitracing.com/parts/sum-290112/overview/
pump:
http://www.ebay.com/itm/NEW-ELECTRIC-FUEL-PUMP-FITS-FORD-LINCOLN-MERCURY-VARIOUS-REF-E2000/221472628293?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D36499%26meid%3Dd90139bbf7324b0781726610432ff32c%26pid%3D100005%26rk%3D2%26rkt%3D6%26sd%3D152069996559
Fuel fittings:
(3) http://www.summitracing.com/parts/der-98201
vent bulkhead fitting:
http://www.summitracing.com/parts/vpe-16893/overview/
Need line:
http://www.summitracing.com/parts/dac-80063/overview/
Need filter:
http://www.summitracing.com/parts/frm-g3/overview/
need e-fan
need window net
http://www.summitracing.com/parts/gfr-4134bk/overview/
check radius arms
need to empty bed
Weld rear diff
thank you!
Need line:
thought supply and return were 2 different sizes?
i cant remember if mine is all 3/8 or 3/8 and 5/16
speed way was best for radiator and a 14" or 17" cheap fan no shroud i run
my other summit order with some stuff
radiator hoses
GTR-52425 (NLA but summit provides another number)
http://www.summitracing.com/parts/GTR-52425
GTR-52418
http://www.summitracing.com/parts/GTR-52418
gator rad hose clamps (4)
http://www.summitracing.com/parts/CCA-G31240
CCA-G31240
muffler
WLK-24215
http://www.summitracing.com/parts/WLK-24215
02bung relocate
VPE-11105
http://www.summitracing.com/parts/VPE-11105
steering cooler
FLX-3818
http://www.summitracing.com/parts/FLX-3818
fuel line or steering line clamps for 3/8 hose (12)
CCA-G3912
http://www.summitracing.com/parts/CCA-G3912
water proof togle
PCO-5513PT
http://www.summitracing.com/parts/PCO-5513PT
water proof push button
PCO-5509PT
http://www.summitracing.com/parts/PCO-5509PT
relay kits
PCO-5591PT
http://www.summitracing.com/parts/PCO-5591PT
batt cable neg to chassis
SUM-XTP225BK
http://www.summitracing.com/parts/SUM-XTP225BK
batt cable disco on to truck
SUM-XSS451R
http://www.summitracing.com/parts/SUM-XSS451R
batt cable- batt pos to disco
http://www.summitracing.com/parts/SUM-XTP472R
SUM-XTP472R
rad cap http://www.summitracing.com/parts/SNN-10230
SNN-10230
rad overflow http://www.summitracing.com/parts/SUM-G1478
SUM-G1478
boom.
I probably should have clicked a button to stock up on some electrical connectors too, but I think things should be pretty well covered.
they were out of stock on 5/16 line, so only bought 3/8.
And 2 minutes after I place that order I find out that I _DO_ have to work that weekend.
Let's get her built anyway. Maybe the MA un-sanctioned race will end up the debut.
I was REALLY hoping to try and get both rigs to Rolling W so I could actually shake something down and make some shock tuning notes. I guess I'll work on it but the baseline is vacation request for 5/14 is denied.
booo!
Bed empty save for 2 leaky tires.
Cab empty except a siren speaker.
Garage doesn’t look much fuller, so density is greatly increased.
If anyone wants 1310 or 1330 driveshafts stop over before they hit scrap - hopefully Thursday.
Hopefully an earlier start on stripping tmw than there was on emptying tonight.
(http://uploads.tapatalk-cdn.com/20160504/69dbd17888005d75cb7c7533ed0542bd.jpg)
(http://uploads.tapatalk-cdn.com/20160504/4a8706baca216dafe3352efef2987ce5.jpg)
(http://uploads.tapatalk-cdn.com/20160504/82c84f71c8c3fe4f5a7e5f9e8785a6f6.jpg)
how nuts did you go on the wiring? looks like its all gone haha
does it still move?
Nope. All unplugged and pulled. Whole, but still attached to the dash.
Would it be easier to rewire just the basics like yours is, or to thin out the factory harness?
If I do that, I’d keep gauges, key, bypass inertia and clutch interlock, delete most of the rest. Not sure if the passenger kick panel module or the two modules behind the radio are important?
i would throw the harness back in for now so its mobile still. 2-3 hours wiring work get to where mine is.
Hopefully less hours than that to get it semi wired again
ya probably 10 minutes to get it going if the heavy gage and under hood is untouched from my writup on here.
Plugged it all in while my fiber internet is being installed. Runs.
(http://uploads.tapatalk-cdn.com/20160504/efe951715ef0798d8b4fca7f3bbf62a5.jpg)
awesome. still gona drop it off tonight? i can get started on the cage tonight.
That’s the plan! I have meetings all afternoon so hopefully I won’t get into anything that’ll delay me. Should just need to move 6 things, drive buggy out, drive ranger in, strap down and go.
Should be less than 3hr :rolleyes:
Great progress on this unit tonight! Main bars bent, sweet tires all mounted and on, bumpers, spare carrier and front clip all off.
Would like to get core support off and underhood stripping done tmw. Fuel cell vs rad mount stuff depends on smikes cage work order of operations...
Exciting to see this coming together! Two days in a row of meeting goals is great too.
Awesome guys!
looks good. threw a dash bar, and 2 lateral roof bars on this thing also last night. tube will go fast!
brotime!
rear X in, 4 door bars in
rear upper shocks mounted
doors cut out
more under hood junk removed
Hopefully get over there a little earlier tonight. Kim's gonna jump tomorrow so I'll have the day. Sunday off, gotta clean the house for visiting parents...
that wiper linkage is just amazing... that's got to take 15m to install through those little holes.
Remaining list is getting shorter.
Good day yesterday.
(http://uploads.tapatalk-cdn.com/20160508/1ddd971c3f0c712055ab3839e8ed3a6a.jpg)
(http://uploads.tapatalk-cdn.com/20160508/36122fcecc92c07307464af6c5de6f16.jpg)
I think this is everything I can think of
(http://uploads.tapatalk-cdn.com/20160509/9c62f314d9fd75b98fb81d8d760d779c.jpg)
Air intake mounting and air filter.
finish by tonight or tomorrow?
like to think about another spring change in my truck meh
I’ll be over tonight. Kim a bit later.
Might be able to wrap it in one sitting. I think it’ll be close.
(http://uploads.tapatalk-cdn.com/20160510/7d64fb81b64eabac35a023b30254bfc3.jpg)
truck is looking good- full legit!
should be one more night of details and good to go!
race hit list is in the ones or twos
shop lot ripped around and it feels nice and tight!
Some things I remember from last race tech inspection.
Cover positive battery terminal
Number panels behind cab.
Very curious on how the tires will hold up.
Looking good.
All dressed up and no race to go
Going to do a little testing tmw night hopefully. Cage paint in the trailer in the rain Saturday while it's still cleanish is the plan.
(http://uploads.tapatalk-cdn.com/20160513/4377445b2eb7bf0232ee6a8061eb4f35.jpg)
Rewrote the full list with immediate musts, prerace musts, things, and B-list things.
(http://uploads.tapatalk-cdn.com/20160513/c04ba122d0e408d3d6cdec43427bc74a.jpg)
thing looks great.
we are getting pretty good at this.
i cant wait to build my next one.
Anyone do a clutch in one of these yet?
Should probably be done for Monson. When hot its an on/off switch ALL THE WAY at top of travel.
We put on at least 20 miles at Jeff’s. Zero issues other than clutch getting bad.
Best vid and one of the scarier things I’ve done
https://vimeo.com/166633394 (https://vimeo.com/166633394)
Immediately previous to that I hit it faster but straighter and at was GREAT
Flying purple people eater! Noiccee
Nioce
found one other issue when washing yesterday: radiator tank almost rubbed through from a bolt on the core support! need to fix the bottom mounts, and get that bolt out of interference range. it broke off unscrewing it so I've got to see if I have room to cut it off without pulling things.
One or two nights of punch list if we ignore the clutch.
But we're not going to ignore the clutch, I'll have clutch and flywheel tonight. It felt better when not cooked from 20+ miles of race pace, but I'd like to swap it before the race, would suck to waste that long a trip. Sooner I do it, the sooner I know if the hydraulics are fine too.
With that and the front gears in my car it'll be a 4th or 5th long week in a row. Probably take a day or 2 off to work on things again.
How's shop space this week? I don't want to tie up things if you have work to do on your own shit. I'll beg a favor from Spencer or deal with things on the ground in my own garage if i need to - just squares or cubes the amount of cursing.
check that the tire did not hit the clutch slave and crack the fitting, making it leak
bunch of shit blown up on my brolite, and my xj needs water pump at the least. tied up for now.
Accessory drive stuff or more? Saw the shredded belt.
Will check slave but I'm 99% sure I looked and the resi was not low.
Also got better again after it cooled off.
FYI- i for the life of me could not get the mast line out of the slave- its easy to get to, just would not pop out. the line is hard thick wall plastic 3/8 tube that swedge lock compression fittings work find on :)
and it's an internal slave so it has to get pulled?
its internal, there is a big window, and the bleeder was easy to get too-- ya if you are pulling the trans it has to come out i assume, unless you might beable to just unhook petal assembly and stuff rest though fire wall and keep with the trans and res...
if you need to bleed the master, it HAS to be done on the bench upside down. it CANT be done on the fire wall.
clutch slipping or clutch not disengaging? id try to give it a good bleed first if engagesment issues especially since it was low when i looked at it in the shop
Slip, when hot its an on/off switch ALL the way at the top of travel, and sometimes even takes a beat to engage.
Got a bit better when cold. I know I slipped it a bunch from letting my foot hover not realizing how high in clutch travel it was operating.
so the UTV tires are jump tested! lol
i might be looking at a set as a mud bog option. this weekend race was a race of time, stupid rain.
Set at 40/20 now. No grass in beads. No ’pop’
cool, Miller said they run 8ply. best bang for the buck looks like you chose what i would have. you have 9" wheels? Maxxis says 8" ok for rear?
any more video from this weekend?
Took a bunch. That one was really the only ’good’ one. Might be able to edit them into something but not sure. Mostly speed runs. The jumps other than that one don’t have good sight lines. Missed the good landing.
8†probably be ok. These have a great profile on the 9â€s
Great braking too.
Jeffs is decent for testing. Needs more width for anything but test & tune but I’m as confident as I can be that mine is a runner before heading to MA.
10-20% more rebound in front and 100% more in back is what I’d change. Maybe 10-20% less compression in back but I’m not sure I’d change it. Otherwise shocks are great and it flies well and drives solid
welding on two new bolts to lower the vertical component in the rear will do what you just asked for - in the right direction less compression, less rebound
did you look to see if the front bump stops were still present and happy?
More rebound in back is the most important change - not sure I'd add compression to get it though.
Take a look at the way the back bounces on landing in that video the instant before I catch the berm.
didn't double check front bumps
If you guys didn't know or if it even helps but explorer rear leafs are direct bolt in upgrade from 3 to 4 leafs
I need less rate and more travel, not less. I'd consider dropping the bottom leaf or even going to a main leaf only and adding a traction bar (should be legal: rules state stock main leaf, all else is open)
driver side looks perfect, passenger side still 2/3 attached.
looked like on millers and a few other cars, standard procedure was to take a cut off wheel and remove the two halves of the bottom leaf without unbolting anything
makes sense.
only suspension thing I may do is swap out those front bump stops, not touching anything else unless I discover it falling off.
No worry about axle wrap?
so much wrap with the 2.3 power house to worry about!
I have a set of explorer spring if you guys want to try them at some point.
Matt if they don't want them I'll take them, looking for some for the ranger
All yours, Troy, I think.
Ditto. Hours wasted trying.
Fucker won’t bleed out. Got some strange white spooge out of it.
Hopefully Spencer will share an epiphany when he arrives.
All goddamn day to load shit up on 571 to brig over, load drive and park a trailer, and R&R a trans and clutch.
I’d starve to death working book rate.
clutch slave has to be bled on the bench upsidown, it cant be done in the truck
I thought the master had to be bench bled not the slave
Master never went dry either. Probably going to bleed it next anyway. I assume the gravity bleed I’m doing now won’t do shit.
sorry master yes
This hack of a trick worked like a charm. Pull the plunger out of the master to let the air out the top
https://m.youtube.com/watch?v=Pd1KDCAhTLc
No let downs all weekend.
RF bump stop vacated as expected. Front shocks are NOT up to the task with stock springs for my desired pace.
TJ lift springs should help droop, and that’ll help these shocks do better. Decker says he has some fox 2.0 s, waiting on a price and status.
Fancy bump stops need installing up front. Rear appears to never have touched the bump stops so not worrying about that.
Need to flatten some pinch seams in the front fenders, minor tire cuts.
Biggest task will be some sweet bumpers and some bed paint. Winning!
Second place out of three due to Eric’s flat.
nice work. i have those progressive coils (unknown origin) and the set of TJ RE express 4 or 5" that i just took out of my truck. i think the coils im running now are rough country 4" and they are about 1.5" more lift over the RE express ones^
also have a lot of JK springs but not quiet the same lower attachment. FYI, 3/4x8" bolts are what holds the spring on through the beam- crap shoot if you can get it out with out cutting or replacing..... had to cut on the new ranger
no good source for wide boy 14" wheels i can find
might get on the UTV bandwagon have a couple sets of 15's also
I got the only set of alloy 14x9s on ebay when I got mine. I found none new. maybe fox body mustang forums?
the 15" wheel UTV tires are 27s as opposed to my 26s. I'd expect they have a slightly higher weight rating but I don't remember if that's actually true. There's a table on the maxxis site.
I don't feel like I need more ride height, I just need more droop so the landing has more distance to absorb. An inch spacer would help that too. If I'm keeping any of the metal inner fender I don't think I can do more than an inch of spacer, they rub at full crash as it is.
Decker's shocks are new-out-of-box 2.0x10 Bro front base tune. $300. I told him to bring them to line mountain. figure on slapping those in along with bump stops and a spring change after that race.
thats a great price.
interco has some blems up for 14"s
XATV-100 INTERFORCE 27X7.75-14 8 $55.00
(http://static.chaparral-racing.com/productimages/600/553-A505.jpg)
Those look like freaking ag tires, damn
they have another kind that look like sand paddles too lol
(http://www.intercotire.com/tire_photos/6xe5q9k66dfaa_sm.jpg) 87$ lol
max load 495lbs hmmm boo
I am surprised they don't have a "must be dot" tire spec.
not yet, anyway
I would imagine if your looking for tire in a dot flavor you would look at golf cart tires since those are driven around like cars in the retired areas
Aveo has 14. As do some older. Couldn't weld in hubs?
I always liked their Black Mamba...(http://uploads.tapatalk-cdn.com/20160607/2eb7c278d677e7bb0da29ac0be5fcc70.jpg)
there are factory 14s for Rangers, I'm running a pair on the front, and 14x9s in back. nothing sketchy needed.
golf cart tires are not going to be DOT approved either, nor will they have weight ratings or be anything but a turf tire.
UTV applications are what have enough weight rating to work - though I do have a 24hr-to-flat level leak in my right front. haven't investigated beyond filling it twice waiting for it to get better. need some slime.
I always liked their Black Mamba...[IMxG]http://uploads.tapatalk-cdn.com/20160607/2eb7c278d677e7bb0da29ac0be5fcc70.jpg[/imxg]
I googled black mamba to see what it looks like mounted on something.... damn! this looks wicked!
(http://i80.photobucket.com/albums/j198/bjsmith0098/samari325.jpg)
Hehehe ohhh yeahhhh :-D
damn that front axle looks SMALL for those tires
Absolutely nothing like 37's on a d44 ;-)
No tire damage whatsoever. Inner lip. Wierd!
(http://uploads.tapatalk-cdn.com/20160607/380930a58e3cb4446be0ea5f609e386c.jpg)
only you could do that with a UTV tire mike
I know, right? I don’t get how its even possible. No chip or scratch or pinch or anything visible other than the crack.
could it have been bent before and straightened, then finally failed/cracked?
there are another pair of these wheels in the shop lot, right?
I have a bunch of tire shit to do, and even more once the new KMCs show up, might as well get this tire swapped over too.
not really since my car is on 14's now also.
i bought 5 more but one has egged lug wholes
booo!
trying to reach this guy, only cheap option I located in a quickie search
http://buffalo.craigslist.org/wto/5582277474.html
delivering tomorrow. couldn't be better timing, he's driving past on his way to Pulaski. should be meeting at the Scottsville plaza around 0830.
score!
$47 for my three fucked up wheels.
Took a LOT to break down the back beads. Couldn’t dismount solo on the tire machine. Too heavy a tire.
Heading back to the shop now to get the InnerAirLocks put in the good tires and bring all the crap home.
Anyone need 14†rollers? One pair and 2 each oddballs. Planning to loose them instantly if no one needs them.
I think one of the matching pair was tubed :rolleyes:
The worse of the two bent wheels was cracked. I’d give 90% odds on cracking the other trying to straighten it so I figured I’d just get them out of my way. Saved the beadlock rings since they were fine.
Broken wheel scrapped. Tire re-mounted. 3 spare 14s now in stock.
M4 bead breaker does work!
Have both front header panel body mounts failed. Don’t think I care.
All shock bushings completely shit. Already replaced rear upper bushings with nuts.
Front mounts are set up ~1†too short for fox shocks. Fuck. Length is 16.1â€, I have been full bump at 15 +/- 1/8
EDIT: I’m dumb. I have about an inch to spare on bump and will have room for almost 4†more droop if I ever get softer longer springs on there. I knew I was mathing something wrong.
Radiator mount al-al tig is cracked on one side. So much for using the sweet easy aluminum ears forever.
Also need to plate a radius arm.
Hoping to leave around 5 tomorrow evening and bolt in shocks upon arrival.
I’d like to get rear wheel wells for saturday’s mud but odds on that have gone to zero.
I’m working on it today and tmw. Work keeps bugging me. 16 hours yesterday was apparently not quite enough.
(http://uploads.tapatalk-cdn.com/20160908/08fcb3c0335ecb93e9316a3557c874f1.jpg)
(http://uploads.tapatalk-cdn.com/20160908/123ebc9bd4fd27556d7a15ec1be5d921.jpg)
(http://uploads.tapatalk-cdn.com/20160908/02fdbda832efb57632683f841f9bdaa0.jpg)
Edited above, fox shocks are 1†longer at full compression, thats all. I’ll have 1†of shaft showing at full bump instead of 2â€
solid performance!
back to our redline discussion, remember i have 4.10 gears also in my truck
and I have NO idea what I have.
door code will have it
mike, im calling on shocks for will tonight, you want a pair of 12"s for the rear to match in the order?
yeah, do it.
thanks. lmk total
you have 10" on the front now right?
so ill get the same setup for Will 10front 12 rear
i have 12 front 14" rear because i am difficult.
yes 10" front
10" probably fine for rear too, I think I'm seeing similar travel use in the rear shocks as mounted, but plenty of room for 12s and it'll give some flexibility for removing shackle reversal or other travel improvements.
you still have some TJ springs for me after tweaking yours? thinking I'll ignore bump stops for now and try to make more use of travel and droop to not bottom as much. I want to pull that stuff apart and do radius arms if they're thin after what yours did. next week projects. I a pair of 2" spacers for the front on the way.
ill check my spring stock after i decided if my tweaked spring on the truck needs to be replaced. i loved how my truck rode and jumped. was best its ever felt smooth as can be running as hard as possible into any jump or corner.
any idea what actual springs are on it, brand-wise? TJ 4L 4" lift fronts, right?
they are rusty skyjacker 4" TJ coils
looks like 468 plus shipping for a pair of 12"
wont know shipping until packed.
Kartech gives me a 10% discount calling to verify stock.
FOX is 25%, 2-3 week lead on 10", 4-6week lead on 12"
sounds like typical Fox ::)
at least springs are under $200/pr
Karteck guy said they do a 4400 race discount he is calling me back in a few. laughed at how many people he sold shocks to this week that fox has sent them to them.
ordered
10" @ 208 per shock
12" @ 220 per shock
valve spec is 30/90, what i have
shipping today, TBD
Hopefully good valving. Seems to work for you!
Thank you.
$470 total for you
will let you know when they come in.
expected mid next week delivery.
ordered 13.5" wheel, quick release, 2:1 quickener and some shaft spline connectors.
4" TJ front coils are also on the way.
2" wheel spacers arrived.
need manual steering box and water pump asap. my power steering is dead. have not checked fluid, but those pumps just suck!
already rec'd a shift light, since my rev limiter isn't noticeable. I'll set for like 500 below actual redline and hope it holds its setting. Might try hot gluing the back of it - knob is looser than I'd like.
Need a little shop time & material for some bumpers, and to install new springs and ball joints and fab some longer swaybar links.
Should I just do radius arms as PM since it seems that replacing springs is halfway there already?
id replace the radius arms now before your truck falls apart like mine did haha.
bushings and new bolts to. 8" x 3/4" if i recall correctly are needed.
i used up the last of my 1.75x120wall for my rear bumper. i just have 4 sticks of 095 wall left for the next bro cage.
095 probably no good for bumpers anyway. there is a 1.625" 120 wall size commonly at KSD that would work also if you got some.
shocks say tomorrow by end of day
1Z9E51380371733548 UPS
radius arms and longer 4x4 swaybar links rock'd, should be end of week.
rest of parts arie'd and gathering for friday.
haven't seen my Summit order of steering goodies yet (wheel, disconnect, couplers, quickener) but that should be here today or tomorrow.
gotta get some tubing!
shocks say delivered!
shocks in and look good. Will and I working on brolites tonight at M4
need to get bumper steel, radius arm bolts.
springs will be here Weds, I fucked up and didn't push the button late last week, I guess - fixed that wednesday night. Hopefully will have everything else taken care of this weekend and just need to button up the spring install late next week, we'll see how things go this weekend.
feel free to grab shocks from shop anytime. working in shop tonight, gone sat and sunday all day.
- passenger ball joints done, that was a bit of a bitch, should have brought the knuckle to a press.
- springs out, radius arms 3/4 of the way out.
- 3 new radius arms prepped for 1/2" bolts. All gave me the same trouble drilling at the weld as the ones in the truck now did, I wonder if the arm might be hardened steel and the pin of the shock stud that goes through to be welded is closer to 7/16? That wouldn't make sense since the base of the stud doesn't fall off after drilling to 1/2" though. I had to open up the back side with a burr, could not drill. Need to sharpen half a dozen drill bits now...
- 2 radius arms are set for double shear and just need paint.
- restocked bolt bins
- did a minute of lathe work on a steering coupler and picked up shocks
- cut out more rotted rust from bottom of front clip. new qty of front body mounts: 0
needs:
- rewire everything from the stock ignition switch
- remove column, mounts; mount quickener, extend steering shaft, weld quick release
- rock sheild for radiator
- permanently wire and mount shift light
- install seat
- grab parts from Arie
- R&R steering box. my puller doesn't clear the box, I might just cut the casting to get clearance for the puller to grab the pitman arm unless someone has a better idea
- R steering pump
- change up rear shock mounts to 1/2" double shear & install shocks
planning to take WRF of this week off.
i should have shared my method
flap wheel weld on back of stud, punch stud out. weld 7/16" (actually a tight 1/2" hole) washer on shock side, weld 1/2" top lock on back side. weld double shear bracket chopped from scrap box tube. 30 min or less to do the pair.
the stud hole is 5/8 after tapping it out FYI
Just hardened from HAZ I guess, then.
Trying to find belt routing info I came across this thread saying the pitman arm doesn’t interchange between power and manual boxes! Shit.
http://www.diyelectriccar.com/forums/showthread.php/manual-steering-97-ranger-72323.html#/topics/72323?_k=qjgisg
Details on whats needed
Sounds like cj may fit?
http://www.therangerstation.com/forums/showthread.php?t=158818
rock auto says they interchange and use the same coupler. was hoping to have parts to look at today
since you posted after midnight "today" might happen..
steering shaft should be good. Rock only lists power steering pitman arms. manual arms appear to be NLA.
hoping some of the Jeep junk you have laying around might be good, otherwise I'll just not spin the pump and run the power box for the moment and hopefully fix it for the 22nd.
that was also my plan.
the only manual pitman arm from CJ stuff i had i think gif got and it end up on the hotrod project.
will need to see what it is on ford junk. CJ arms and drop arms def available still.
i still have the cj box. I went with a reversed corvair steering box
Found one, but in Wisconsin.
Also found my leak: PS bracket is almost touching the pressure and return lines leaving to top of the box. bad leak around one thats kinked just out of its fitting.
Droop on this thing is ludicrous. Haven’t checked ride height yet. Tomorrow morning before meetings that drag me back to work.
12†shocks out back are too long. Shackles are gonna get un-reversed. Probably will level it out with the new front springs.
Too much to do too little time as usual.
Friday can be a long day though - dropping Kim off at the airport for a 0630 flight.
method for rear shocks:
hang truck in rear by frame
attach shocks to lower mount.
fully extend shock minus 1.5"
weld bolt to cage where eye lines up
done
Shoulda gone for 2†TJ coils instead of 4â€
I think I got a 4†lift from these that I didn’t need or want
I guess I’ll align to max camber and run it...
(http://uploads.tapatalk-cdn.com/20160929/e68cd4c2ed3d6c177e886bdef0c5e77d.jpg)
They'll probably settle a little
hmmm
cut a coil or two off the top?
Want me to just sit on the hood for a while
Sent from my SCH-I545 using Tapatalk
Now that's funny.
Needed that laugh. Thanks.
Can’t find a pitman arm that will work. Not sure I can cobble hoses to a non broken state to loop them since the ps bracket crushed one. I guess I’ll make due if I don’t hear good news on a pitman arm measurement from gif.
Humbug.
Other than bumpers and steering things are looking good. I guess I’ll have to throw the power box back on no matter what to get over to bumper fab.
I have a flat cj and YJ drop
Manual steering? I think that’s key to the smaller shaft. Flat is good too but I can make what I need if I can get the right splines.
All power boxes checked (yj cj zj and ranger) are just shy of 1.25†od on the shaft at the top of the arm. What I’m after is ~1.1†there.
Flat pitman from a manual cj box
Humbug.
(http://i98.photobucket.com/albums/l264/jeepgif/20160929_203126_zpssnv9l1sf.jpg) (http://s98.photobucket.com/user/jeepgif/media/20160929_203126_zpssnv9l1sf.jpg.html)
(http://i98.photobucket.com/albums/l264/jeepgif/20160929_203151_zpsmtnxpimg.jpg) (http://s98.photobucket.com/user/jeepgif/media/20160929_203151_zpsmtnxpimg.jpg.html)
Thanks Gif!
If there's a pitman arm that goes with that it's got a chance of being right.
I'm up for the day and about to throw the power box back on so the truck is mobile, I'll keep an eye here in case I can run out and pick something up today.
i didnt see the arm. but i really didnt look that hard.
mike ill send you a text shortly
73 cj5 stock length 7†with small taper
Power ranger arm 5†with medium taper
I poked a hole in the cj arm at 6†and made a medium taper. If this works I’ll run it. Might do minor plating since its a thinner arm.
Installing after a snack. Wish me luck
(http://uploads.tapatalk-cdn.com/20160930/c49e823ea13f5dfa7a3f07fb3ccd5715.jpg)
neat
This might be hard to explain.. But I'm going to take a shot at it..
I had previous pit man arm failure on my scrambler and decided I wanted to make a custom pitman arm.
I ended up using the steering box end of the pitman arm to retain the splined end and approximately 1"of the arm length to create a "key".
I drew up a new pitman arm (wider and the length I needed) and cut it out on my plasma at work using 1" think material, with the exact shape of the pitman arm I cut up "key", think hole or internal opening, and then tig welded it all together and reamed the drag link hole where I needed it.
The reason I created a key was to take the load off of the weld it's self.
I just wanted to throw it out there..
Fully plan on ghetto fabbing an arm with these splines if needed.
cut, splice, plate = done?
dorman doesn't make pitman arms?
moog K8754
I don't have here but listed as ford ranger pitman arm
that’ll be a power steering arm
Here’s the input ujoint. Goodbye rag
(http://uploads.tapatalk-cdn.com/20160930/6887201259e05ac7bbf4b3c244bf2156.jpg)
Slowpoke is headed to build some bumpers. Everything else done.
Except for what I forgot...
Bumpers came out AWESOME. Much better than the pictures of the bumpers.
(http://uploads.tapatalk-cdn.com/20161001/8cc63ff5dc6482594e9804229f7acf39.jpg)
(http://uploads.tapatalk-cdn.com/20161001/9c1ee36b060341def5a879b56e1c748b.jpg)
Manual steering was a mistake. Handled like absolute shit with the new front ride height too. I’ll give it a second chance after aligning properly but it might just be the increased ride height.
Had to fix a rear shock mount fuckup on-site, many thanks to the Jokinens for the welder use.
Rolled it in practice and have some front clip straightening to do. Had to put a front coil back in place too. Might beef up the inner retaining ring though a 5/16 retainer bolt did hold through the final.
3rd place in the final after missing the heat race for repairs.
List for 10/22:
Alignment
- fancy camber bushings
- fresh tie rods & adjusters
Swap power box back in
- right input ujoint for steering shaft
- New pressure and return lines
Figure out why the motor moved far enough to crush the steering lines and fix it. Motor mounts?
(http://uploads.tapatalk-cdn.com/20161002/f2892487dce29897e97c628702d1df60.jpg)
(http://uploads.tapatalk-cdn.com/20161002/645058e0c0f482ab6246b288dcd8e9f8.jpg)
watching my rollover video, front droop was absolutely the cause. the outside beam jacked and the tire laid down and tripped it.
front swaybar didn't do shit, and may actually have harmed since the inside corner's spring rate helped push down the outside tire.
correct method to fix is to lower the beam pivot point. we can't do that.
not sure if going to max negative camber would help much. it's the additional droop/travel that caused the issue - but having that additional travel to soak up a landing is pretty invaluable. I don't know if anything could be done in shock tuning for more rebound valving as a handling bandaid that would worsen suspension performance overall.
I think I will go to max camber, maybe cut half or one coil off to get it sitting lower and have a hair less droop, and get now steering hardware in there to get toe right where it should be. Along with power steering to react to that more easily maybe it'll be better.
it was pretty rutted there too.
if you watch the Main race i pushed that front right tire off the rim that ended my race in the same spot... my truck looks in control just digging hard with body level.
i think you have too much lateral traction with those tires in the rear, not letting the truck slide out in a controlled drift or what ever you fancy race drivers call it
Been thinking on this a lot. I think I want to limit front droop and get more compression into the shocks. It handled 300% better before. if they're 90/30 now, probably something more like a 110 or 120.
I also want more rear travel. this thing doesn't droop out for anything. Since we're stuck on stock main leaf, shackle, and locations, I think running a 2 leaf setup with a greater arch in the second leaf for similar ride height with less spring rate might do the trick? I'm already running 250psi in the shocks. I guess I could test nuking the swaybar, and loosening all the spring bolts from tight to just barely snug to let them rotate.
#30 compression and #90 rebound
i dont know what 30# means or how that correlates to a shim stack, there is 5-6 shims each in the tower on the compression and rebound sides of the one i took apart and rebuilt with a new shaft.
also jumped 10X worse before.
I havent talked to Will yet about his feel for change with just new shocks by staying with ranger "leveling coils"
From the pics, it looks like he was jumping way better and didnt roll it.....
id fix Camber first, since you absolutely know that is wrong and thats def hurting you.
I have a set of explorrer "fleet ride" springs if you want to try id trade for your springs.
I really doubt that - should be a lot more compression in there than rebound and higher number should mean more dampening.
for an OE application from what i have read typically a shock is set with more rebound valve to counter act spring force spring back.
30 compression / 90 rebound is what they are set too (listed on Kartek and also what FOX race program quoted..)
http://www.kartek.com/parts/fox-racing-shocks-2-body-5-stroke-58-shaft-hose-remote-reservoir.html
o neat, just found this- now it makes sense how fox valve charts work.
http://www.ridefox.com/dl/offroad/FOX_OR_20_VALVING.pdf
ya just checked a couple fox applications, they all come with more rebound than compression.
Not to say that is correct for a stadium style truck lol
shopping list:
arie
full set of steering tie rods, ends, adjusters
power steering pressure & return lines
fancy front camber bushings
motor mounts?
troyer
steering ujoint for power box
pacific customs?
shock shim kit to drastically increase front compression
tbd
more-arched 2nd rear leaf
todo:
power steering
more front compression
more rear droop
lower front ride height; limit droop. would like 2-3" more up travel than stock and probably no more
rear bumper supports to kill hooking chances
paint on fresh steel
clean up wiring
- add brake light back
- reenable head lights
shopping list:
arie
motor mounts?
email will be best.. in an out of office for next little bit
yeah i need to collect some p/n for you. thanks!
how do YJ leaf packs compare to Ranger? Any chance of a more arched 2nd leaf option there?
my worn out yj leafs are great.. when my cj runs.. haha
I'm quite sure I want more arch than that. And I have to keep factory main leaf.
agreed, you do
haha
lots of YJ leafs out back with mains junk.
maybe an ADD'ALeaf might do you right since those are generally poorly made to be lots of arch to pull a whole pack?
I was thinking the same. Maybe for ranger, maybe for jeep junk? I don't want to get much more if any rate of course. Just more sit-in at similar ride height. They're usually really high rate too.
reminder for shock $$, i had forgotten and will forget again so posting here to remind us.
looks like 4.5 sticks of tube left? thats ~150$ off the 470$ tab?
ill keep it all unless you want more. no matter to me.
sounds right. I'll probably need a bit more for front clip mounts (might as well gut them now that they need straightening) and rear bumper braces.
are it from the trailer to the garage. On deck...
Clutch feels fine. Wtf?
Reminded myself that it's a hydraulic throwout. No pivot issues or so forth.
Overheated fluid growing between master & slave if I was riding the clutch?
I have a really really bad habit of leaving my left foot on the pedal. Maybe I need a really strong return spring.
identical problem on identical truck. no resolution.
https://www.reddit.com/r/Cartalk/comments/2gy8yc/clutch_overheats_on_97_ranger_ceases_shifting/
I already have pretty fresh fluid from when I did the clutch and the line was cut & spliced (IIRC).
I'm thinking I run it again and see what happens (while being prepared to be sad), and if it does the same thing again, fully replace the hydraulics and put in some high-zoot DOT 5 high temp full synthetic unicorn juice. Any other ideas?
should I try to drain and fill it ahead of time? I guess I'll see how brown the fluid in the reservoir is.
Wasn't Erik having the very same issue?
doesn't ring a bell, I'm not sure.
Just ordered some fancy 600Ëš DOT 4 Motul brake fluid. Hopefully that'll be a quick flush & swap.
Clutch felt funny loading it into the trailer after the second race. Low pedal instead of typical high pedal and very sudden engagement.
Unloaded just now to let the rain wash it for me, and I've got almost no clutch. I can hold it with the brakes and it will idle with the clutch on the floor, but it's partially engaged. The starter won't turn over the engine without letting the truck move.
Any ideas other than just throwing a new master & hydraulic throw out at it?
I'm sure I could bleed it now and it'd last a race but this feels like a new ongoing issue that needs more than fluid changes. I just don't understand the failure at this point.
Master and slave are original to purchase. It got a clutch last year after what could have been the same issue - it was slipping during a race so I changed it.
Seems strongly related: (https://uploads.tapatalk-cdn.com/20170604/6de7738a05226182233ad1d4dfed0820.jpg)
Hmm. Guess that needs a clamp or something.
(https://uploads.tapatalk-cdn.com/20170604/d1c098cfa522b4660d11abf383c3b52c.jpg)
i have to say i am very disapointed in the clutches and steering on these trucks. everything else is way above expecatation.
Mine is getting a chevy steering pump next. I already have a wilwood master for the clutch.
With landings from clearing the table top that moved my go pro, and not having the steering give out, I think my chained passenger mount must be good.
I'll probably have to bleed the master but I don't think I'm touching anything else on here before Broome.
Need a straight front clip and some spare tires, and probably a new driver bedside along with more flexible bed mounts.
crap movies:
Heat 1: https://youtu.be/WA5MC7OMEp0
Heat 2: https://youtu.be/-3KdlM_m3Nk
at :26 im motioning to that stupid XJ though my window net to get his ass moving, then i say screw it and just pass him on the line up
moron.
sorry for the mud. was a good race.
he's a fool.
Watching that video I also have no idea why I didn't go wide on the outside of him. I know better, he can't corner for shit. I need to just let him hit me if he can't hold his line. I don't need to be his personal cameraman, or whatever it was he gave me credit for.
rear spares found. $125 shipped.
http://www.ebay.com/itm/322530998527
Just need to spend on a spare set of tires now.
Hopefully all parts will be here Friday for this.
Going to try to fix master with a 1/16" npt 90 to reroute resi hose high & tight. Hopefully enough time to get a spare if that doesn't work out.
Why doesn’t my grease fix this?
(https://uploads.tapatalk-cdn.com/20171026/aff8b38f44cb175ac8a0fa163e79c6d6.jpg)
What are we looking at?
Fuel cell cap gasket
Clutch works fine now btw, but I can’t hit the floor with it. Pedal hits a stop of some sort an inch off the floor.
What's the filler ID? Use an expansion plug?
black or red shit grease is needed, that looks like fancy molly grease
It eventually shrank with the good grease. Just wasn’t instant.
8.8 procured today. Has fresh drum brakes and a mini spool. Just need to do maths and decide on gears to be happy running 3-4 instead of 1-2.
For sale: Yukon 4.88 and master install for a d30. Idk high or low, need to make sure all is present. It was dark and cold, deal good enough I didn’t go through the boxes.
i just took out a 4.56 gear set out of an 8.8 that has a nic in a pinion tooth from spider gear explostion. the damage really isnt in the patten load area, but it was wanted to be changed.... sitting in scrap pile
also have a new 8.8 yukon instal kit sitting on shelf,
Trade?
you can have the gear set, and you brobably dont need a whole install kit. external shims i have stacks of. the bearings are probably fine reuse. the carrier the scrap set on has new timken bearings on it 1 month old.
can talk and look when we shoe brolites away this week, or are you doing the swap before winter?
the comando and some motors need to go back to arie this week too.
I’ll put off stripping the decking again. Figure I’ll build the axle over winter and swap it in the spring.
Sounds good.
building that axle sure hasn't happened yet.
I think a new slave will fix the clutch issues. Gotta do that.
Want to support the radiator more better for durability in AOAA race. those are really the only known issues I can think of - aside from desire to put more compression in the front shocks.
New slave installed and gravity bled. Feels good around the lot.
Exhaust hanger installed. Trans mount and radius arm crossmembers both ridiculously tweaked and replaced by dom. Trans was rotting out. Radius arm too tweaked to get the trans over it. Hopefully there’s enough engagement on the radius arms to last. Otherwise the brackets are replaceable.
Washed. Topped off clutch resi. May try to bleed that some onsite. Still needs tire pressures set, and fuel.
Otherwise might be ready.
Still severe clearance issues getting the trans out. New crossmember should have had a kink.
Destroyed newish o2 sensor after anger occurred. It didn’t want to come out.
Flywheel and flex plate have hot spots but zero wear. Clutch disc is just melted on both sides.
Here’s where the clutch smoke came out
(https://uploads.tapatalk-cdn.com/20180613/ac07eeb3c7b7513bbfcec50777553c4e.heic)
(https://uploads.tapatalk-cdn.com/20180613/5307198863fb3ff0f512bbdd0ba6ffd8.heic)
Glazed disc
(https://uploads.tapatalk-cdn.com/20180613/06b90382e9bbb492aeacfff5b39b3d38.heic)
(https://uploads.tapatalk-cdn.com/20180613/3ac0ca8ef80fb5d268823fcde5848141.heic)
(https://uploads.tapatalk-cdn.com/20180613/caae95f11cafe1c55aacad9e2e43e4d6.heic)
Flywheel and pressure plate look new aside from a couple warms spots. Fingers look fine. It’s an auto adjust clutch, I’ll reset that and just throw a new disc in it.
(https://uploads.tapatalk-cdn.com/20180613/b3ccc8ea6b36377efafbaaf018fadf13.heic)
(https://uploads.tapatalk-cdn.com/20180613/eeace6c6e681d9723d7e8bc57000f647.heic)
(https://uploads.tapatalk-cdn.com/20180613/c19f1808c76efdf05bce509823d261f9.heic)
(https://uploads.tapatalk-cdn.com/20180613/fd7f7ec0ab7c4e867d1ef57ed056dfdf.heic)
Part number
(https://uploads.tapatalk-cdn.com/20180613/6fae339ef457b3b55d29de5ab56cd6a5.heic)
Driver ball joints have tiny click. I think i did passenger already. Front brakes are done.
(https://uploads.tapatalk-cdn.com/20180613/34809c7b144f336df45719cc575c5a79.heic)
(https://uploads.tapatalk-cdn.com/20180613/d9ed31566f99dac46ad2efa7182d4f65.heic)
Driver bj click is the camber adjuster backing out. Second time.
Rotors are live hubs. Pain in the ass. Done after like 3-4 hr. I greased to bearings. Otherwise it woulda been 2. Still need to swap pads. I think I did a pad slap one already. They’re tick but inners are grooved to shit and not fully contacting.
Never fails. Lost vital part. Clip that holds the line into the slave.
Can’t find listing for replacement clip. Gonna see if safety wire will retain it. Uugh.
The retaining c clip on this type is what I need. Prob have to just buy one tomorrow to get it, and see if I can get a replacement clip from Precision directly to have a useful spare or return.
https://shop.advanceautoparts.com/p/carquest-technovation-clutch-slave-cylinder-360016/19340232-P?searchTerm=Slave
I bet I left it half seated in the trans and it fell out or went flying wheel horsing the trans out or in. It really doesn’t fit over my new crossmember. Magnet sweep of shop didn’t find it.
Ford 7.5†duty cycle exceeded. I’m certain the c clip is holding that tube in the housing. We noticed it was bent before I pulled it out of the truck, now I know it’s done and I have to assemble that 8.8 I have waiting for it.
(https://uploads.tapatalk-cdn.com/20180813/501e4c30373400cc6642e49a3a2d5541.jpg)
(https://uploads.tapatalk-cdn.com/20180813/869af43172674a6e83926aa3ebe0d788.jpg)
4.56 gears dropped into 8.8 yesterday with significant parts labor and expertise provided by mr smike.
Slammed the axle into the truck in 3-4 hours today. Stops, goes, loaded and ready for me to relearn how to drive it!
Grabbed a pair of bedsides for future efforts as well. Not sure if I’ll get those on in time for rolling w but might do!
Not final pattern, but the only picture I took
(https://uploads.tapatalk-cdn.com/20180827/84ed240356774fa004d91c7cb82592d0.jpg)
1st try failed to seal on water pump. Took half thickness off tabs to seat deeper, zero difference. Fuck me.
Only other option is bigger o ring. Static dims of what I have:
Id 0.91â€
Od 1.19â€
Thick 0.139â€
Actual OD of inner piece 1.188 - both dorman part and what I made. To the thou. Guess I shoulda oversized by .003-.005. Damnit.
Either Arie has in stock or I’m not racing. All other locals have nothing in stock. 3-4 day special order.
(https://uploads.tapatalk-cdn.com/20180907/22e82bc8829dfa10cae3d86dd8f5effd.jpg)
can you just cut both of the above pieces and hose clamp in a short 2" section of rad hose from your part to the part that has the right interface?
good effort but i had my doubts sorry!
F57Z-8290-A
ford steel PN
tried calling corteese they aren't answering there service parts/phone yet.
Done
Done
found one for mike?
experience and skepticism wins the day. I'm surprised it didn't work better than it did. I'll hang onto the part and probably try to find a thicker o ring in case I ever need ti again but I'll have one plus a spare this afternoon FROM THE BEST PARTS GUY AROUND!
2nd place this weekend. 5ish hours to wash. Front end ride height sagging a bit. I wonder if I should get some different coils again.
Camber bushings continue to twist on their own to max out camber.
Threw belt in second race. Still need to refill coolant. Handful to drive in the mud with no power steering, I was keeping pace with Dylan easily and it was anybody’s race until the belt went. If it weren’t for attrition I’d have been much further back. No issues and it didn’t throw it again. Must have taken a clod if mud between belt and pulley.
Oh, I almost forgot. That time I thought I flatted a tire?
(https://uploads.tapatalk-cdn.com/20180910/9d5cad390b01cd709e0c495dbdc56493.jpg)
I think I remember where my other factory 14s are. I forgot to check the back, back stash behind the axle pile. I think they’re there along with the F150 17s needing to be redrilled to run cheap 32s on Gus.
Wheel swapped. First wheel I pulled to use had a bad crack. So down to 1 spare front wheel.
Forgot I bought that bead breaker. Wasted an hour. Dumbass.
Lost coolant in the truck on the way home. Wtf/booo.
Broken wheel changed. Tire fine once again. That tire has been through 2 broken wheels in the last month. Maybe 3 lifetime.
I’m out of stock 14†ranger wheels :(
Coolant was plumb full. Dunno what all the water on the floor was.
i need a 15" wheel, its fubared. my spare steer aired up ok that was my second flat.
150# of steel bought for $150 to add to tail.
Makes the lead route look not as bad if it could be found but I was seeing people asking $1/lb and up. This I just get to weld on. See what difference it makes...
Alternator locked up. Smoked the belt on the crank. Don’t think I’ve had the crank spin in the belt before, thought I had a few seconds to look at what was still but all of it was still
My XJ did that. Twice.
Alternators seem like they love to seize from lack of use.
I’ve learned that seized alternators usually can be revived and keep going for a bit longer via force it to turn again on the pulley nut.
Felt like shit trying to break free with the nut. I would t race on that 6hr away. I’ve seen poor charging after that having done same myself.
I think corrosion jacked the case. This broken side faces the block. Do see what almost looks like impact but that doesn’t make sense. Maybe an old drop? Appears to have been seriously cracked at least through the winter.
(https://uploads.tapatalk-cdn.com/20190426/d8438346e493d6f697852915cddfad72.jpg)
100% scrap! LOL
New belt and alt on in a few minutes. Sweet. Check that belt is running right, and it is. Timing belt looks like it’s riding funny through the back of the cover though.
Can’t get cover all the way off, but this is right near the top as it shut down.
That’s a hard stop.
(https://uploads.tapatalk-cdn.com/20190426/2b2cf229ed43d46792003477cdacca5c.jpg)
that baby has at least 20 laps left in her!
lol
Shoooooort laps.
Pretty sure these are interference too.
Not good enough for being alone on the track when it munches the engine and I have to get pushed off, then don’t have a winch to get it in the truck, 6 hours from home.
Would be a good acid test for Sarah
This. Is. Racing.
God bless Ingersol-Rand
(https://uploads.tapatalk-cdn.com/20190426/2b48dbde9222e6880768e036800bebfd.jpg)
Crank was keeping the belt from walking off.
Puller just cleared radiator. Should pull off with a tap. It’s keyed and straight fit.
(https://uploads.tapatalk-cdn.com/20190426/c8fce926b352f59673060100f3fbcad4.jpg)
(https://uploads.tapatalk-cdn.com/20190426/ca03518ac9cf897facf5b237994085e1.jpg)
That feeling when every attempt is resulting in being a half tooth off. How even?
Probably NOT interference BTW. Fully rotated cam with crank at or near its timing mark.
Done. Small coolant leak returned after reassembling everything and purring the belt on.
Water pump and water neck were new late last year due to same issue. It’s probably that stupid plastic water neck to pump o ring seal. Humbug.
moved mine to the new barn today to empty out my enclosed. didnt even air the tire up, fired right up and go. surprising!
I had to jump mine. Think the bad alt wasn’t charging well. Hasn’t hesitated to start since even with 4-6 starts without a belt.
Tied down, hood closed, ready to rock. Ish.
Thanks to any-Way for the support! :)
#portapower
I don’t think I’ll straighten it here but I could. Just in case need of heat or welder that i don’t have here. No tire contact.
Took the wind out of the other driver :(
Shouldn’t have. But did. Might post a video clip later if I feel like pulling it. I definitely have it.
(https://uploads.tapatalk-cdn.com/20190622/9a6f50ceaadd554ed9948d07eea5528b.jpg)
Adjusted the core support right into the radiator today. Patched up to run second heat and it hardly even leaked on the way home. Gooder as newish.
Ignorably dry. What a dismotivation!
(https://uploads.tapatalk-cdn.com/20190624/9833474dd0dafac0ce047e892c0b146d.jpg)
Probably because mud is holding it together haha
Should probably move that plug next to where the tire rubs
(https://uploads.tapatalk-cdn.com/20190918/ac8542ce3a982ef58f7f204804f8c732.jpg)(https://uploads.tapatalk-cdn.com/20190918/49f603c5f6d9cecfdd8201eb77953d36.jpg)(https://uploads.tapatalk-cdn.com/20190918/a4e954f73eff2a89474c31a71236207d.jpg)(https://uploads.tapatalk-cdn.com/20190918/19c2bfb025b3999f2d56f4d733e4cad5.jpg)
Driver side axle seal is out in that 8.8. Coolant was low so temp fix on rad isn’t permanent.
See if I can stick the 571 radiator in or not since I have a spare of that. If not it’ll be something skinny enough to go between the uprights. Or I park it for a parts truck and race Kim’s for 1500.
Or I give up since nobody else races them anymore
my truck is ready minus some air in a few tires
Shame you’re not here instead of falling off ladders!
Another ford ps pump bites the dust. Leak source unidentifiable without removal. Assume between plastic and housing. Tighten the hose clamp didn’t help
Battery is either low on water or has a weak cell too. Saw a boil bubble out the cap charging at 14.0. Sits at 12.6 but didn’t want to crank. Terminals have been shit every time I look and that hydrogen bubble is definitely why. Cleaned.
It’ll do another lap then sit all winter and I’ll read this later.
Power steering pump is leaking probably between pump and can
Driver axle seal is leaking
That battery thing
Radiator
If you don’t put antifreeze in it, it’s done. Been on tapwater most of the summer.
Quickeners don’t like catching a trackside tire, I don’t think.
PS pump was kilt in heat one. Pulley vacated. Did a lap or three without any PS and just couldn’t quite hang onto it in the hairpin once. Thought I could skip the tire but I hooked it instead, swung the truck right around the RF tire.
https://www.youtube.com/watch?v=yvaoBmYoNBs
Reverse torque overload failure of the sun and planet both. Wasn’t enough to even hurt my hands, but without power assist the shock was more than would have come though with power assist working. Those teeth are awfully small.
(https://uploads.tapatalk-cdn.com/20190929/8e97900bd0236b2e26598d300599f926.jpg)(https://uploads.tapatalk-cdn.com/20190929/1ebaa2b4ce46bd77ca9b3c4703e40a0d.jpg)
that's not a sun and planet. it's a ring and pinion.
I ordered a replacement which _is_ a planetary setup. Supposed to be stronger and should be better than 3x if it's 3 planets (since they also support each other). I didn't look to see if Howe quoted torque rating, or torque load to failure.
(https://uploads.tapatalk-cdn.com/20191002/2e94a41073b756a261f2e38cade6d6a2.jpg)(https://uploads.tapatalk-cdn.com/20191002/6330d853b847e440e0fa7de5cbc55603.jpg)
Interesting. And unfortunate on the length/offset
How much faster you need steering to be? I read that stock Ranger have 4 turns lock to lock.
What about swapping in a different steering box, like from a Crown Victoria for the faster ratio at 3 turns lock to lock.
somewhere in the other 26 pages are some further info on steering. I think the manual box is 4 turns and the power box is 3 turns. I tried to run a manual box with the quickener after seeing the power steering issues so many others had early in these trucks, too much physical effort. So I put the power back in and I've loved it. It's still relatively high effort but it's exactly what's needed for a tail happy 4x2 in party mode. Now that I've had the same pump failure that everyone else does, I may try to gear pump it along with the big car just for consistent spares. Either that or I'm raising the driver side of the engine an inch to keep accessory brackets off the steering gear and trying to fit a TC pump in there. Anything to get rid of the troublesome plastic rear housing-to-pump case setup.
TC pump about 1/4 installed.
I’m short on long 5/16 bolts.
Going to make a back plate for the pump and brace to one mounting bolt of the bracket.
Need to make a clamp to mount a resi, and that resi needs a pressure relief, and a drain port out the bottom to pump suction.
(https://uploads.tapatalk-cdn.com/20191129/5a48c7eb7dc44b646099e8a0362104df.jpg)
(https://uploads.tapatalk-cdn.com/20191129/99c4a83fac1551b9fe6417c41cbc0aad.jpg)
Need to mount and plumb. May need a line or 2, might be covered with what’s laying about. I think stock belt will work, centerline didn’t move much and i think stock Jeep pulley is same size. Should clear all I hope. Not sure I have a belt, lost on track last run when the Ford pump failed.
(https://uploads.tapatalk-cdn.com/20200102/457d196f17f7dccca7bd6dcd8a5400a8.jpg)
Jeep TC pump now.
Should try to seal up the bad parts of the radiator before I park it, that should have it at 100% (ignoring bed sides)
That plate didn't fit the cap under the engine cage. Going to secure resi to the intake manifold instead.
power steering pressure hose might be fun. I think the fitting types listed on RockAuto aren't fully defined. So I've got Ranger PS box and Jeep PS pump.
Ford hose is .3125 inverted flare at the box to 16mm 'swivel o-ring'
Jeep hose is 16 & 18mm o-ring. I don't have a hose around.
I do happen to have a (garfed thread) Malibu hose. which is listed as 16 & 18mm o-ring.
And doesn't fit the Jeep PS box. I think the thread pitch is different.
I can clamp on to the factory Ford return to make that long enough to go into the resi, no problem. I probably need to get a conversion line or fitting for the pressure side but need to finger out the right fitting for the Jeep TC box.
hopefully got the right junk on the way. this improvement has ended up costing more in plumbing and fittings than I could have imagined. I think more than a new in box pump and new ford spec lines would have. hilarious.
Still out for delivery. Zero chance it’s arriving tonight.
And there’s a lost amazon driving in front of my house right now. Hahaha
Sweet multi post.
When your cheap braided lobe and AN fitting set comes with o-rings for each AN fitting, you know it’s quality.
My jump pack doesn’t have enough ass to start the bro on its own. Charging the shot battery that was in it last season. Missed one fitting. Will be running with no power steering and no belt. Fitting due Friday. Assemble and fill. Done. Assuming no leaks.
Hopefully the belt hanging off it is right.
Belt hanging off it was wrong. I have a lot of belts that are wrong. Some of these may fit smikes or Matt’s engines?
(https://uploads.tapatalk-cdn.com/20200717/a30460e83242ca7855232ef41617b692.jpg)
Did not achieve perfection. Pulley align must be slightly off, brand new belt walks 2 ribs at high rpm
(https://uploads.tapatalk-cdn.com/20200717/f908a2d3e2d61b09e9b50ee57b598ed6.jpg)
not sure whats on my car. dont think i have ever bought one. enough new complete engines with good belts :(
After I made the adjustment I thought it would need it walked 3 ribs at idle.
Need to take upper rad hose off to get good eye on things. Probably just need to pull the pulley off 0.25â€
Easy to pull off that upper rad hose since I failed at getting the rad damage to seal up. I’ll just throw some Barr’s Leaks in it if I get the steering good and it’ll be ready to run.
I cut, twisted, and flattened the 4 bad tubes after failing at soldering them a few times.
I need a tig. Probably could have touched the 5 bad spots and been done. Or blown some big, meaningful holes in it.
Backed off the pulley this far (sample pump, assumed same shaft length since they seem to be standard). Seems maybe ok! Load center is not beyond snout of shaft but is damn close.
(https://uploads.tapatalk-cdn.com/20200718/dbf3d0a17312b1f8aa9d23a35b7b2de6.jpg)
(https://uploads.tapatalk-cdn.com/20200718/11045a3894aec32191dff0aca9218226.jpg)
That depth is exactly as thick as the mounting ears on the bracket.
If this ruins the pulley or shaft, I should be able to make an offset pattern face mounting plate. Otherwise just make an entire new mounting bracket. Needs to incorporate an idler pulley that mounts on a different plane, so that’s annoying.
#fail
(https://uploads.tapatalk-cdn.com/20200718/de21d12cb28d105d019672613bb87c27.jpg)
Absolute max replacement width 24â€
Mounting terribleness will go away.
Should have new radiator in tomorrow, and a second truck OUT of the shop. Shame I don’t have straight fenders to put on it, would be nice to redo the whole front clip, but that can wait for never. Or if anyone uses these things again.
Bottom is lower than old radiator was. Channel is about the right size with isolator padding and should hopefully protect from any from-the-bottom damage. May add a tie or three to the bumper for good measure on that front.
Going from two fans to one due to smaller radiator surface. I’m certain that’ll still be plenty adequate. I think they’re 12â€
(https://uploads.tapatalk-cdn.com/20201220/907000d180e38826ea6f83256344ebce.jpg)
I still work like a heathen. Too much done on the floor. Still not putting things in sane places even with plenty of room. Not having “away†places yet to put things. Decades of habits from shit workspace to break. It’s embarrassing. How long will that take?!
I sure do love that portaband no matter what, though.
i was thinking about dragging up my spare truck and just scavenging good parts from it to scrap the chassis
its getting beat stored for so long with out care.
My crooked chassis makes me grumpy. Stupid mistake on that frame repair. Oh well
Didn’t touch rear fenders but it’s race ready. Radiator is done and full, battery box is on and hold down is tight.
Radiator got mud plugged and I overheated.
Found out from Will that after pulling my cluster I would not be charging. Battery went dead after second heat. Got a push start and crossed the right two wires to fix that.
Great shakedown. I need to wire up a mud muncher hookup in this one, badly!
Radiator protection as such installed. Double thick chicken wire across the core support. Hopefully it’ll plug and shake loose if things are thick enough that the radiator will plug. Time will tell!
I did forget to put that forgotten nut on. And to straighten my hood pin. So a sneeze more left to do.
Looks like rad leak is from where that dumb plastic pile enters the water pump. Also noticed front tubes to main cage broken both sides.
(https://uploads.tapatalk-cdn.com/20210612/94de39e8fc30fb38b76cb51b6d5961ac.jpg)
can't find a listing for just the small o-ring. seems to only come with water pumps.
I've never had fantastic results measuring an o ring and ordering blind. ever.
the new red and blew case oring kits at HF are fantastic, i have all 4 of them. i was able to find a new oring for Jeffs trucks and installed with RTV as lube.
yup i welded some cracked tubes on mine too.
Cage cracks fixed. Trans mount should be here tomorrow. Nothing else needed that I know of.
No drips from 2x o rings plus black RTV with 24hr cure time before coolant was added.
Left rear shock needs o rings on n2 fitting. :(
Didn’t bring any.
Issue at the steering box with my AN adaptor. Fitting is tight but swivel is leaking pretty badly. I hate the way those AN fittings work. Real aircraft quality ones have to be better than these.
Issue at the hub with left rear axle too.
(https://uploads.tapatalk-cdn.com/20210627/006c8cadd6bc60e953f800cb4b7cb8a3.jpg)
(https://uploads.tapatalk-cdn.com/20210627/d6772e70f2d1df9b2ae19443ff4845e0.jpg)
(https://uploads.tapatalk-cdn.com/20210627/2493dd390fc9b2bb81bf7411913c49e1.jpg)
(https://uploads.tapatalk-cdn.com/20210627/3c4fe3028696b408394d56cd2f365b65.jpg)
(https://uploads.tapatalk-cdn.com/20210627/1a06f81c15daa657c651b861ef1ff42d.jpg)
(https://uploads.tapatalk-cdn.com/20210627/99d41035c5d00ef3156280d885b5acc0.jpg)
looks like there are LOTS of different lengths of axle shafts, but at least Summit lists many of them as in stock so should be a quick fix once I learn exactly how they're measured. I need some proper lug nuts for my other wide rear wheels too, definitely bent the wheel
tip to mounting flange, that's what I expected.
https://www.sierragear.com/differential-repair-help-topics/axle-shaft-length-bolt-circle-measurement/
I think this should be trustworthy. Ford axle dimensions from Dutchman.
https://dutchmanaxles.com/images/sr-c-clip/SR-CC-Ford-Truck.pdf
I put it into Excel for filtering, and it seems to say that all 8.8 are 31 spline.
I think I'll find it's a 95-98 Explorer. I think the newer were slightly wider with the disk brakes.
wouldnt it be easier just to find a junkyard ranger axle and swap the entire axle?
no.
gear setup.
at one point i had a set of 8.8 shafts laying around before the move. not sure what happend to them
May end up looking for one to get parts from, though. 10" drum replacement backing plates aren't available, only 9". At $150 in the rock auto cart without the backing plate, and do have some pretty significant tip-of-the-axle housing damage to consider. The bearing is fine, and three of the 4 brake mounting bolts are fine, but the tip of the axle tube past the bearing got significantly torn up.
No luck in Marketplace hunting. I think rangers as late as 2009 will have when I’m after so maybe j&j… probably end up with a 31sp and won’t be able to use my spool or something.
I’ll have to see if I can repair the one I ripped off. It hadn’t been rotted out so maybe. I haven’t really looked at it.
Humbug.
Stupid move.
(https://uploads.tapatalk-cdn.com/20210704/52c2d5b6cf06e2e48aca3ff02f8fa7b8.jpg)
(https://uploads.tapatalk-cdn.com/20210704/1428ec0db48c03492baf8f7652d2590a.jpg)
(https://uploads.tapatalk-cdn.com/20210704/f1483ba236eede2dc8e88c5b36741128.jpg)
doesn't look like I put parts info for my steering in back at post 400
this is the AN to steering box fitting https://www.amazon.com/gp/product/B000CPAS1E/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
this is the TC pump 90? to return fitting for a remote resi https://www.lsxconcepts.com/products/saginaw-type-ii-tc-series-90-degree-power-steering-return-fitting
and this is the shit -6 AN kit that I have a leaking fitting from that I can't actually recommend. https://www.amazon.com/gp/product/B07XXYBNWB/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Didn’t notice the condition of the 8.8 mini spool when I took the axle apart. All chips were in the diff so all damage is new from my use.
Musta been real cheap shit. Was new out of box with the axle.
(https://uploads.tapatalk-cdn.com/20210722/6ae8d5c780624551df626b4ed4cd03c7.jpg)
(https://uploads.tapatalk-cdn.com/20210727/2c926ab0dcf1c0a91c7d30bebf21a16c.jpg)
(https://uploads.tapatalk-cdn.com/20210727/ce05fff852c216b707440a5ffb350ff8.jpg)
(https://uploads.tapatalk-cdn.com/20210727/4e834e7645f8da91908c665074ee4b9e.jpg)
Just needs fluids and tires.
turns out it was a good thing for me that we called off the race. moved this today and it dumped all sorts of coolant and power steering fluid. Appears I didn't get a good seal on the braided hose when I replaced the bad AN fitting, and I may have to look for a crack in the radiator inlet. That is definitely the source, and the hose feels good and I cranked down the clamp. not sure wtf is going on there yet.
bah!
After the ride it took, at least the brakes feel great and it drives straight!
Coolant leak was power steering pully kissing rad hose. Had a couple hairline slices.
Shortened rad inlet and trimmed hose.
Redid ps pressure hose. Hopefully fixed?
Coolant leak duplicated.
Also apparently under-spec’d my trans mount.
(https://uploads.tapatalk-cdn.com/20210912/60be48ddb0f63f366ef123748312c237.jpg)
Trans mount rebuilt. Tons of clearance to rad hose now. Expect that issue won’t triplicate but will find out Saturday!
so, discovered today looking for 8.8 bearings /seals National and timkin make a fix it bearing with integrated seal that may have worked in the above axle failure that destroyed the seal bore.
https://www.rockauto.com/en/moreinfo.php?pk=1119537&cc=1438302&pt=1672&jsn=538
20$ seal and hammer the backing plate might have been good enough for a bro!
I had enough of a circle left there that I RTV'd and sent it. that's a good option if it starts leaking or kicks the seal out though!
backing plate was ripped clean off, didn't have an option on that bit. still annoyed I had to actually build it and couldn't just spend $30 but it seemed to work out. more payoff on the plasma cutter and Ryan's stack of box covers from a decade ago
I noticed that, Those pieces are older than my kids, hahaha
Long term rear tire leak found. Valve stem. Not Schraeder but stem to wheel. Haven’t seen that on an aluminum, but it was a sharp edge that shaved down the stem just a tiny bit.
4 flat tires and a fully charged battery after sitting many many months. Maybe since last fall? Aired up tires and drove it out of Joe - at WOT.
Need to fix intake, only runs at wide open throttle with all the air going around the MAF
Painters tape made it run enough to do a couple loops.
(https://uploads.tapatalk-cdn.com/20220904/c727602123ca04ba6effdb2b6a4f7377.jpg)
(https://uploads.tapatalk-cdn.com/20220904/aa9ee7abe009cc3f35ea9741c21f6026.jpg)
Not sure about building bed extensions. I’ll look at it in the rain and daylight tomorrow.
(https://uploads.tapatalk-cdn.com/20220904/d3d5e5a8cee759100e522ac3ef7431fd.jpg)
(https://uploads.tapatalk-cdn.com/20220904/d733e58d314bf6066bd900c6d549b406.jpg)
Just strap the front down good and let it hang…
chain the front, lift middle with jack, sit on jack stands at end of bed, more chain binder in rear haha
So I repaired the intake boot by cutting it up and using an intercooler kit aluminum elbow plus pieces of the boot to adapt to the MF sensor and to hold the IAT sensor.
Also threw a couple zip screw in the air cleaner adaptor. It had been held with 2 bolts, one broke out so not it’s got 2 zip screws and a bolt.
Added 1-2qt of water to cooling system.
No apparent issues in beating a bit yesterday at smikes.
Need to bring 12 gal of e0 and make a quick mud muncher setup for it and set up my helmet for that. Should be ready to rock n roll.
Ordered a crimped AN line for power steering pump to box. Hopefully the pump isn’t wasted from running dry. I think it’s ready for more abuse once that’s done
i think we swapped either the pump or the pulley i cant remember. i had a spare TC pump in my "ZJ" that got donated. i have a red AN nut on my fridge i found in my driveway i think is from your truck also
FYI i have had super good luck just buying both OEM lines, and then using a swedgelock 3/8" compression union at the hard section of the high pressure hoses to made dissimilar kinds
im also close to pulling the trigger on a spendy hydro crimp that has all hose types / fuel, brake, hydro, AC from will. should have just done it 2 or 3 jobs ago.
I'll be happy give you margin on making hoses. I spent way too much on the single crimped hose for this conversion application. that reusable AN fitting stuff clearly can't take power steering pressure. All the fittings that have seen that are going in the bin. Maybe consider it safe for engine oil or fuel pressure but not PS.
Keeping stock of proper ends and adaptors is scary expensive. but making right lines is priceless...
I noticed that whatever fancy pulley I'd had on there was gone, didn't note if pump was different too, used to used I wouldn't know. I _think_ I have one more on the shelf if backstock is needed.
that confirms, the pulley was loose on the pump and lost its press fit just spinning and no pumping. we pulled a stock XJ pulley off the pump i had and installed it, then the line blew next race.
5 out of 6 ribs on the belt seems fine. $94 hose and fixed. That’s -one- part that’ll never fail again. Meh. I want a hose crimper and thousands in inventory of special ends to make it useful
Gonna try to clean the bead on that leaky tire for the 87tg time before I check the coolant and shove it in Joe for the winter.
(https://uploads.tapatalk-cdn.com/20221112/bf0cb1c21b8f55a4333348611e92c23a.jpg)
surplus didnt have 2 fittings and a 12$ standard hose? thats what i have been doing on full hydro installs if im not in a hurry
I already had the -6AN adapters and just wanted to improve current design
I should have noted what fittings I adapted so I could get new adaptors to jic and do exactly that.
LR tire had sidewall damage and a very leaky but clean bead. Beads on the tire are a bit chopped up. Also has one lug partly ripped off but not leaking. I didn’t patch the sidewall, it got a tube.
Should probably get fresh drive tires if there’s a full race season, ever…
Harvested spare front clip and rear axle and driveshaft from a '98. unsure if that driveshaft is anything more than scrap, 3.0 auto 4x2 xcab. don't know if that's any sort of a match to a manual 4cyl. aluminum 1 piece.
need to get that to scrap. the spare rear isn't terribly desirable but would get a truck operational again. drum brake 3.73 7.5"
