Projects place => Classifieds => For Sale => Topic started by: matt on January 29, 2013, 12:07:22 PM
I got a bunch of dana 44 fronts and a couple of sets f&r that I will never use
44 front and 60 rear out of J-truck 8 lug
d44 f&r out of Cherokee 6 lug
d 30 out of Jeep cj
a couple d44 f out of chevy 1/2 ton 6 lug
a couple d44 8 lug out of fords
If people have specific questions I can take a look for you.
Thanks,
Matt
What year cherokee?
Wide Track?
What side Drop?
It was old, like late 70's early 80's. I know it had a dana 20 transfer case. I will get a width measurement tomorrow night.
That may be what I'm looking for.
I have a dana 300 for my waggy, and would like to upgrade to the slightly wider axle set (passenger drop) to get the front tires away from the springs a bit.
Gear ratio would be helpful as well.
Thanks.
X2 on all these requests..
looking for a set... pass drop front
I have some Toyota axles that would work......... ;D
I will look tonight or tomorrow, between work and grad calsses I haven't had time to, well you now...
Axles are front 60 wms to wms disk brake
rear 58.5 wms to wms
6 lug cherokee Drivers or passenger drop?
I only asked due to them coming either way depending on the year.
I'm looking for a passenger drop.
Do you know gear ratio or year they are out of?
I can pop off the cover and check the ratio, problem is that the axles are not my house.
Same drop as a cj. I knnow that cause I got them to use in a cj, sold the cj7 before swapped them in.
I think it was a late 70's It had a dana 20 t-case and a 6 cyl in it.
Yes 6 lug.
well im interested
(http://i126.photobucket.com/albums/p97/mattmey/gears1_zpsdf738f52.jpg)
(http://i126.photobucket.com/albums/p97/mattmey/gears2_zps6f7bdacc.jpg)
This was the rear 4.10's. I am surprised by that.
Matt
very interesting- didnt know they did an 11 / 45 (4.09) and a 10 / 41 (4.10)
weird.
I don't THINK you'll see that for the same axle model, or have you seen 10/41 for a D44?
ive always thought that was the case with most gear sets..
Price on the axle set with the 4.10's
(Drivers drop 6 lug).
I researched the width and it's the same as I have, but it would allow me to run a dana 300.
CJ's are passenger side drop not drivers side.
Anyways, I would like to get 250/bo
Where are they located?
I haven't been over the to the rochester area in a while. Might be time for some beers.
Would $200 take them picked up?
i might have a set of driver drop coming in- i have to grab them this week
I actually need the passenger drop axles.
I just screwed up in my one post.
