Projects place => Projects Section => Topic started by: M4wdFab on August 22, 2012, 11:57:19 AM
Title: 571wreck wheel status
Post by: M4wdFab on August 22, 2012, 11:57:19 AM
man this was painful, almost off the lift haha
swapped on a spare CO, changed the springs and such into the back,
disconnected both rear calipers and bled out the master for front function.  washed and cleaned, front skid wreck removed, need to start over on that one.
headlights
rear bushings
some wireing issues
Title: Re: 572 wreck wheel status
Post by: mr.mindless on August 22, 2012, 12:18:09 PM
want my other 2 KCs for head lights?
those rear bushings are the worst I've ever seen!
Post by: M4wdFab on August 22, 2012, 12:26:56 PM
ill take a look if its electrical or not why the one doest work.
i should get a couple LED lights from Matt anyway.
Post by: Ryan on August 22, 2012, 12:36:55 PM
572?
Title: Re: 571 wreck wheel status
Post by: M4wdFab on August 22, 2012, 12:48:39 PM
ha, opps ya 571, dam cars.
Post by: Ryan on August 22, 2012, 12:58:18 PM
Ha, getting ahead of yourself there.
Title: 572 wreck wheel status
Post by: GBR928 on August 22, 2012, 02:15:30 PM
Haha I have glued both my fog lights back together. I should put an order in as well.
Title: Re: 571wreck wheel status
Post by: M4wdFab on August 30, 2012, 04:04:15 PM
14.5 gallons last race used  50 miles
at least 3 laps in full low range winding motor out a little more than usual
Post by: M4wdFab on October 08, 2012, 09:30:12 AM
how are my shocks coming along?
if they are whooped ill just take two new ones.
something is broke in my driver rear, its just slamming-  its the gif shaft one and the lower seal is stripped out of the body, looks like oil is all gone too.
Post by: Ryan on October 08, 2012, 09:34:40 AM
Got my shipment in on Friday, I will have them ready this week. They are whooped, but I can fix them up. Well, except for the dual rate stops, those are gone and the threads are whooped, at least on the one. I did not closely inspect the other.
Post by: M4wdFab on October 08, 2012, 10:26:53 AM
are you coming to the meeting tuesday?  bring two new ones for me?  fix what you can later for spares?
Post by: Ryan on October 08, 2012, 10:38:39 AM
I do not know for sure if I am coming. I will try. I will bring new ones for you if I can make it up.
Post by: Ryan on October 08, 2012, 09:07:51 PM
I got one of yours apart and fixed, ran out of lock tite and shock oil, after the shock fell over and spilled oil all over my floor.
Post by: Ryan on October 08, 2012, 09:08:36 PM
The other one is not coming apart very well.
Post by: M4wdFab on October 08, 2012, 11:24:58 PM
i have a half gallon of king oil
Post by: M4wdFab on October 08, 2012, 11:28:02 PM
on the lift, has new rear calipers and rear bushings.  4 links are tight, needs diff service, some rear brake lines run, and studs to mount up TLS's
Post by: M4wdFab on October 08, 2012, 11:30:30 PM
tell me no!  (30)  44" blems available....
BOG-45 NON HIGHWAY SERVICE BOGGER       18/44-16.5   30   $435.00
Post by: mr.mindless on October 09, 2012, 12:13:54 AM
Does than mean stickies???
I think that means stickies.
Post by: M4wdFab on October 09, 2012, 07:53:12 AM
i dont think so, i think that just means they are square
also trying to get a better price from lou on some 43's
Post by: M4wdFab on October 10, 2012, 10:37:13 PM
rear calipers installed
new rear hardlines
brakes bled, still suck
front hubs serviced, decided on 4 longer wheel studs improperly pressed in, with 4 shorter studs on each side.  wheel spacers and TSLs mounted.
need to replace rear coil over, tie up some lines, do some fluid changes, pack tools and swap to 42 spare
Post by: M4wdFab on November 12, 2012, 07:08:33 PM
this thing amazes me, it will be tough to let go.
it just takes a beating, and my mercy ran out long ago.
Post by: JEEPWERX on November 12, 2012, 07:19:30 PM
She amazes me too!
That was alot of whoopass applied Sunday! And she didn't even hiccup!
Post by: M4wdFab on November 12, 2012, 07:26:48 PM
i try to push 2x as hard wreck wheeling than racing.  its the only way to finish races and learn your level.
The car has gotten about 2 days of prep in the last 6 wreck trips, and just keeps taking it.
Post by: M4wdFab on January 09, 2013, 12:26:50 AM
pulled this guy apart tonight to replace the blown shaft...
front ring and pinion blown also!
b itch
Post by: M4wdFab on January 09, 2013, 09:55:19 AM
i have 2 expired gift certs to this place for the club running adds on the site.
wonder if they would honor.
http://www.streetsideauto.com/p/g2-axle-and-gear-2-2034-538/?utm_source=googlepepla&utm_medium=adword&utm_content=pla&gclid=CNOW7OfD27QCFYVFMgodKn4AZg
Post by: M4wdFab on January 09, 2013, 04:00:25 PM
hmm summit has the item.  i might call and see if they will honor there price match / beat policy.  looks legit same item.  but i know summit will ship it.
http://www.summitracing.com/parts/gta-2-2034-538?seid=google&gclid=CPy5u42V3LQCFegWMgodlx4AFQ
Post by: M4wdFab on January 10, 2013, 12:35:46 AM
eh, all the parts i need were gathered tonight
she is going back to 4.10's for now.
Post by: M4wdFab on January 10, 2013, 11:21:30 PM
4.10's in the front with new joints in shafts.
rear 4.10's is on the list for tomorrow with fluids and wrap up on both ends.
Post by: M4wdFab on January 12, 2013, 01:09:52 AM
she is a fully 4.10 geared machine.
no ambition to wrap up.
debating to pull the 14 to the bench and add 1/2" to bottom thats GONE
Post by: mr.mindless on January 12, 2013, 07:56:04 AM
Probably not a bad idea to plate a thin diff. Would suck to crack it, just as much as it'd suck to crack the front. Also just as annoying to fix :)
Post by: M4wdFab on January 12, 2013, 08:51:24 AM
6 bolts and and crack a break line is all it takes right now.
i think it will get done.
im not worried about it cracking, just its wore 1/2 way though the bottom bolt threads.
Post by: JEEPWERX on January 12, 2013, 08:37:36 PM
Let's get this PIG done. RAUSCH IS CALLING!
Post by: M4wdFab on January 14, 2013, 12:21:10 PM
14 bolt is pulled and on the bench, will finish adding back steel and try to get her back in tonight.  Fluids and prepped tomorrow.
Post by: M4wdFab on January 14, 2013, 11:25:59 PM
man, needs a 4th night. it is killing me
front shafts ujoints changed, spares prepped for both sides
front and rear 4.10 gear setups done
14 bolt pulled and plated and re installed
Front end assembled 100%
just need drive shafts put back in, fluids put in diffs, a brake line hooked up and bled, tins, under hood fluids, and tools packed.
maybe a wash or dirt scrap
Post by: M4wdFab on January 15, 2013, 11:31:00 PM
loaded in trailer
feels like a tbi again with 4.10;s
sad face.
Lifetime LED light is sickk!
Post by: M4wdFab on January 26, 2013, 12:02:02 AM
on the lift.  MEh.
Post by: M4wdFab on January 26, 2013, 07:29:21 PM
New 60 on.  High steer arm bent!
Post by: M4wdFab on January 27, 2013, 01:25:50 AM
done and back in the trailer.  shitty brakes still.  got some air out of the front driver that made it much better to typical 1.5 pump
Post by: JEEPWERX on January 27, 2013, 09:09:46 PM
What? You bent the solid High Steer arm?
Post by: M4wdFab on January 29, 2013, 09:06:50 AM
ya, its got about 3/8" of an inch arc up in the center when you lay it on the bench.  driver heim was all bent up too.   i had to disassemble to get it bolted back up
Post by: JEEPWERX on January 29, 2013, 07:23:44 PM
Wow.
Post by: Ryan on February 09, 2013, 12:28:34 PM
http://rochester.craigslist.org/pts/3577033340.html
Post by: M4wdFab on February 09, 2013, 10:45:46 PM
This guy jumps a lot better with a new knuckle.
snow banks are fun.
Post by: M4wdFab on February 10, 2013, 07:16:40 PM
she is back to full duty.
turns Rs like a sunday drive.
Post by: JEEPWERX on February 11, 2013, 09:32:42 AM
Yes she does.
How much air u got in those Swampers? :o
Post by: M4wdFab on February 11, 2013, 09:36:18 AM
i will check, im guessing im still around 10psi
huge difference even from what i did.   sorry  :o
need a real winch one of these days too.....
Post by: orange anchor on February 11, 2013, 10:53:57 AM
[attachment deleted by admin]
Post by: Ryan on February 11, 2013, 11:03:08 AM
I heard the PitBulls were unstoppable.  ;D
Post by: mr.mindless on February 11, 2013, 11:50:20 AM
Sweet Scout!!
Post by: orange anchor on February 11, 2013, 11:52:38 AM
The scout was impressive with a 408 built motor in it.
Post by: JEEPWERX on February 11, 2013, 11:59:28 AM
Sounds amazing.
I def have cylinder envy more now than ever. Thanks mike and Jim
Post by: M4wdFab on February 11, 2013, 12:02:51 PM
erik, i might have a high miles 5.3 and 4l60e for sale soon :)    would wake up that little green CJ :)
Post by: JEEPWERX on February 11, 2013, 12:25:17 PM
You have my attention. But im still in the fence.
I can drop an amc 360 in , bolt it to my tf999, and basically be up and running with only a custom exhaust being a major change. That and possible swapping back to gasoline.
Im looking at both Holley and FAST EFI systems for Wide band plug and play EFI
Post by: M4wdFab on February 11, 2013, 12:29:06 PM
you got stop throwing jeep parts at that thing and start throwing chevy parts at it  :)
Post by: JEEPWERX on February 11, 2013, 02:21:01 PM
Its never gonna be a racer... so why not?
Can't justify redesigning the Jeep, let alone the cooling, drive train mounts, drive shafts and new t case just to have chevy parts in a CJ7 based wheeler.
She goes and is fairly capable as is.
The original 1985 4.2 is just getting a little more tired.
Chevy drivetrain - new tube chassis.
Post by: rejeep on February 11, 2013, 02:57:40 PM
my 258 would run sweet with LPG
Post by: JEEPWERX on February 11, 2013, 03:42:38 PM
Did you yank it out?
Post by: M4wdFab on February 11, 2013, 05:49:24 PM
i still have all my 258 LP parts
sold all my V8 LP parts
Post by: rejeep on February 11, 2013, 06:42:39 PM
looking for a reason to :)
Post by: JEEPWERX on February 12, 2013, 08:19:08 AM
We should discuss numbers.
Does it come with a NU Way Warranty?
Post by: etk300ex on February 12, 2013, 11:24:07 AM
how much evan williams would it take to put a 5.3 in a toyota?  ;D
Post by: M4wdFab on February 12, 2013, 12:09:14 PM
55 gallon drum will do it
Post by: etk300ex on February 12, 2013, 12:39:41 PM
shit that might be worth it.  probably like $80 should cover that!
Post by: JEEPWERX on February 12, 2013, 04:11:48 PM
Lmao
Post by: M4wdFab on February 12, 2013, 04:43:48 PM
you sir are incorrect!
Post by: M4wdFab on February 19, 2013, 11:50:25 AM
got new GPS mounted for this weekend.  Put it on drivers side so i can use it this weekend, not planning to have a passenger.
Cut out the double knot F stick put in my winch cable at Jeffs
Fixed an internal blown fuse that made my radio not work
dried out and cleaned drivers seat.
Hog needs a wash and tool prep.  Also want to swap radiator fan polarity, and may swap to LOW speed- maybe even make it selectable some how.
Post by: orange anchor on February 19, 2013, 03:21:19 PM
who was the F-stick that put the knot in?
I never touched a winch cable all-day :)
Post by: M4wdFab on February 19, 2013, 03:44:32 PM
orange big block man- was getting on my nerves even asking me if id like to winch again to save the motor.  he apparently doesn't know me very well or my buggy that even after 3 asks would not be traded
Title: Re: Re: 571wreck wheel status
Post by: JEEPWERX on February 20, 2013, 02:16:00 PM
Lol
I wasn't going to ask!
Post by: M4wdFab on February 28, 2013, 01:21:00 PM
just hit up the king for a set of 90% KRTs
200$ to get a pallet to this side of the pond not bad.
Post by: Ryan on February 28, 2013, 01:25:50 PM
I can get new for about $500 each shipped.
Post by: M4wdFab on February 28, 2013, 01:36:47 PM
ok-
looks like 4 90% are on the way for 1000 total
Post by: KingtheZJ on February 28, 2013, 01:42:12 PM
stole them!
Post by: Ryan on February 28, 2013, 01:45:55 PM
Good deal.
Post by: etk300ex on February 28, 2013, 02:57:39 PM
Thought you were not impressed with them?
Post by: M4wdFab on February 28, 2013, 04:08:44 PM
there is nothing better the way i drive unfortunately.
i was not happy how fast they wear.
Post by: Ryan on April 03, 2013, 10:01:28 PM
http://www.hardlinecrawlers.com/forums/index.php?topic=23281.0
Post by: etk300ex on April 04, 2013, 07:50:51 AM
it sounds like the bigzj xtranormal cartoon lol
I want moon buggy so i can get all the chicks
Post by: KingtheZJ on April 04, 2013, 07:52:33 AM
ad says no junk :flipoff2:
Post by: M4wdFab on April 04, 2013, 08:12:11 AM
22k is about my low end unless parts come off.   18.5k in parts nose to tail.
Post by: M4wdFab on May 04, 2013, 10:43:33 PM
After 50 miles of sustained go fast, front shocks luke warm, rear shock so hot I couldnt touch the bodies or resiviors.  Puzzled on that one.   Wondering if nitrogen pressure needs to be checked more often, or rear air bumps are needed.
Brakes and steering still shitty
Gps is AWESOME again.
Post by: M4wdFab on May 06, 2013, 08:43:44 AM
both o2 sensors smashed off
driver motor mount 80% material failure around welds.
skid vacated (not recovered from course)
rear pass shock needs looking at, ridding dirty
trans took 2.5 quarts after powerwashing to make truck move
motor took a quart of oil
2hours of power wash and she is ready for some lift time / wreck wheeling.
Post by: GBR928 on May 06, 2013, 09:50:26 AM
Was the fan on low?
Post by: M4wdFab on May 06, 2013, 09:54:23 AM
forgot to check
Post by: M4wdFab on May 08, 2013, 03:53:49 PM
http://www.pirate4x4.com/forum/axles-tires-wheels-sale/1269058-39-5-bfg-baja-ta-stickies.html
Post by: M4wdFab on May 21, 2013, 12:01:06 AM
so sick of this fucking thing i want to be racing my other car.
chassis is broke clear in half on both sides where the sub meets the main rails, looks like its been slamming for a wile with a good beat 1/16" gap
Fawk me.
I can see what Balduci brothers build millers sub out of 188 wall chromolly sleved over solid aluminum.  redoncuoulus.  meh
motor mount area cut out and replaced, masive steel and 3/8"s gussets inplace on drivers side.
Post by: Wingman on May 21, 2013, 07:46:15 AM
Are you planning on pre-running on Friday?
Post by: Ryan on May 21, 2013, 08:22:55 AM
Are you going to race it?
Post by: Ryan on May 21, 2013, 08:23:35 AM
Time for a full tear down and rebuild?
Post by: M4wdFab on May 21, 2013, 08:43:27 AM
not happy about a couple loose ears / caps on the front end so that has to come all apart.  going to see if i can source some spicer joints today to have, and piece together some good shafts or put the RCV's in
fix front axle shaft situation
fix frame, gusset failure
make skid
put a new O2 on
prep the rest of the car
Post by: KingtheZJ on May 21, 2013, 08:45:25 AM
i'm planning to stop by m4 after work. i can help if you give me a project
Post by: Ryan on May 21, 2013, 08:53:03 AM
If you need anything from Vics, I can grab it and bring it up.
I have time to run around this afternoon if you need anything picked up.
Post by: M4wdFab on May 21, 2013, 09:02:58 AM
that would be awesome.  i need (2) SPL55-3X Spicer Dana 60 Non Greasable Axle Shaft U Joint 1480 5-806X
F81Z3249AA, SPL553X, 5-806X, 5806X, 5-732X, 5732X,
Post by: mr.mindless on May 21, 2013, 10:12:06 AM
I'll be over tonight after work to help out.
I would tomorrow too but I hear a rumor that you'll be out of town? Have to see where things stand tonight and if there are any projects left to work on, trailer stuff maybe?
Post by: M4wdFab on May 21, 2013, 10:27:09 AM
probably gona run to buffalo wednesday night to see mom quick. ill be back around 8 or so
Post by: Ryan on May 21, 2013, 12:20:12 PM
Thats a lot of part numbers.
Heading to Vics now, you just need the 2 joints? I have a set of full circle clips if you would like to use them.
Post by: M4wdFab on May 21, 2013, 12:30:44 PM
Actually get three, I have a delco to swap out.  Should be like 35$ or so each I think
Post by: Ryan on May 21, 2013, 01:16:02 PM
$50 each :o
Post by: mr.mindless on May 21, 2013, 01:45:10 PM
I guess they're getting expensive? I couldn't find them on RA, but $39 from JBG
http://broncograveyard.com/bronco/i-11793N-dana-60-spicer-1480-series-axle-u-joint.html
Post by: M4wdFab on May 21, 2013, 02:16:42 PM
50$ seems a little marked up lol but sure
Post by: M4wdFab on May 21, 2013, 02:20:18 PM
next time ill have them overnighted from drivetrain america that has 32 in stock
hoping for no next time!
Post by: mr.mindless on May 21, 2013, 03:00:30 PM
amen
Post by: TrailTamer on June 10, 2013, 09:07:01 PM
We talked a bit about your axles' breaking 5.38 and now running the 4.10
Here the link to how to put Dana 70 gears in your Dana 60 housing. Goes by "Jana 76"
http://www.pirate4x4.com/forum/axles-tires-wheels/946421-jana-76-tm-how-install-70s-your-60-a.html
Post by: M4wdFab on June 30, 2013, 05:44:31 PM
Almost race prepped.  Psc ram on and bled.
Post by: M4wdFab on July 01, 2013, 12:23:35 AM
race prepped, and in great shape a week early.
Alex grabing some bolts for me tomorrow to swap out all link bolts
new steering is nice
bumped rear CO up 1.25" bumped front up .5"  for go fast
rear brake lines fixed
fan wiring upgraded
front pass wheel bearing rebuild after found loose.
grease
tires at 28psi
driver motor mount poly swapped
driver caliper braket shimmed (only mechanical slop found in brake system)
MC bench blead, four wheel brake bleed.  SHIT STANE brakes still.
rear flex 3 way changed
Rear driver bango copper changed and tight
vacated driver lower window net bar fabd
Post by: M4wdFab on July 01, 2013, 12:26:03 AM
PSC in and tight
Post by: mr.mindless on July 01, 2013, 08:23:07 AM
I have no ideas on why the brakes are shitty. That sucks. My only thought is that it may be related to actually having flow to the rear. The crushed SS line may have been acting like a residual valve?
Post by: M4wdFab on July 01, 2013, 09:22:06 AM
speaking of the crushed SS line- that got replaced with a rubber line.   i was thinking this system has 8 rubber flex lines.... maybe too much for the displacement of the MC?
thats what it feels light to me- just not enough stroke to make pressure.
Post by: etk300ex on July 01, 2013, 09:50:54 AM
There is no residual valve?
Post by: M4wdFab on July 01, 2013, 10:08:37 AM
never, not on anything i have ever owned or worked on.
Post by: M4wdFab on July 01, 2013, 11:45:35 AM
i have a corvette 1 1/8 bore MC
Going to try to get Dorman M39324 which is chevy 1.25" bore
or M390530 which is ford 1.375" bore
Post by: mr.mindless on July 01, 2013, 11:48:07 AM
Seems reasonable.
Post by: M4wdFab on July 01, 2013, 12:16:20 PM
found cardone 10-1584 with a 1.330 bore for 24$ at advance
gona try it.
Post by: M4wdFab on July 01, 2013, 01:03:43 PM
thing is large lol.  no idea if it will fit under the hood haha.  looks like same hydralic outs.
Also just thought of something, i wonder if that line lock is F'd up.  it hasent worked in a while.  I think thats going to get take out also.
Post by: mr.mindless on July 01, 2013, 01:24:39 PM
hood there doesn't seem important ;D
I don't think those symptoms could result from a fubar line lock but it really isn't doing much these days so fuckit
Post by: etk300ex on July 01, 2013, 01:43:03 PM
Sorry I meant proportioning valve
Post by: M4wdFab on July 01, 2013, 02:58:46 PM
and my same answer-  proportioning valves are a myth in a 4wd locked truck.
want brakes and all the brakes i can get from any corner.  never run proportioning valves.
Post by: matt on July 01, 2013, 03:47:25 PM
I could see your point if you where running all the same caliper on all four corners but with a proportioning valve could you use that to "set or plant" the front end in a corner better since they are 70 front / 30 back bias?
Post by: mr.mindless on July 01, 2013, 03:53:30 PM
front and back are locked together. No differentiation aside from driveline slop of well less than half a tire rotation.
Post by: M4wdFab on July 01, 2013, 04:07:26 PM
its more like 5% of a tire rotation.  watching all 4 tires lock in a controlled slimmy creek slide shows this :)
Post by: mr.mindless on July 01, 2013, 04:37:00 PM
I knew I was being super generous from what I see the Dakota do
Post by: M4wdFab on July 01, 2013, 04:43:35 PM
test run last night in lot- included some three wheel action turning around with sticky tires :)
Post by: gif on July 01, 2013, 11:05:11 PM
how is the DE Cylinder?   does it steer any better?  worth the $$?
Post by: M4wdFab on July 02, 2013, 01:56:02 AM
new MC in.  id say 3x improvement in brakes.  i cant push hard enough on the petal.  i like it.  needs a booster next if more is wanted.
awesome.
DE ram is sweet.  its odly smooth and tight like something is wrong lol   4 wheel locked and pulling wheels with sticky tires on pavement and it feels tight and smooth.
if we wreck saturday it will be hard and my fault.
Post by: gif on July 02, 2013, 08:07:44 AM
did you get a new PS pump?  or is this still the factory GM P-pump?
Post by: M4wdFab on July 02, 2013, 08:41:54 AM
factory whatever on the 5.3
i am 3 turns lock to lock now.
Post by: M4wdFab on July 06, 2013, 08:51:49 PM
 Karl knack informed me the reason that my KRTs seem to chunk down to cords is because all red label BFG tires are recaps.  you can see on all my tires where the mold meets the carcus.    after 8 full throttle assults on devils den prerunning, i have about a 10" section pealed off on one.
both rear CO's showed no dampening and blown out after prerunning.  all shocks so hot you could not touch.  we changed the worse one with my spare friday night, along with swaping out the tire.
race day cost us the other side in the rear CO from slaming up travel.  and the tranny wont hold fluid, killed it self.  brown toast, she is done.
brakes and steering were awesome.  rest of the car was shit from mile one.  needs a suspention upgrade and limit straps.  the trans needs to be pulled and the trans mount / Tcase mounts need to be allinged / repaired to help life of tail seals.
fuck this car.
Post by: mr.mindless on July 06, 2013, 09:19:44 PM
Don't know why I didn't think of this before but some fault may lie in the single ujoint configuration. That counts on absolutely perfect alignment for all seals and bearings to live long happy lives.
I only mention since both new cars are getting the same layout.
Post by: M4wdFab on July 12, 2013, 09:10:46 AM
its the trans mount that is f'd up, which comes from failing motor mounts.  im sure everything is out of wack and the seals and inputs/outputs are beat to shit.
needs a full floor tear out while motor / trans is out
Post by: KingtheZJ on November 13, 2013, 08:20:34 AM
http://rochester.craigslist.org/pts/4170267721.html
Post by: M4wdFab on December 12, 2013, 04:06:03 PM
new trans ready.  2 new shocks in boxes ready.
Lets do this one more time....
Anyone want a buggy at reduced cost before it gets fully prepped?
Post by: Nick on December 12, 2013, 04:20:34 PM
I will give you $200 for the buggy and shovel!!
Post by: M4wdFab on December 12, 2013, 11:12:51 PM
rear shocks pulled.  5 brokens to make 2 good ones for Jeff.
Post by: M4wdFab on December 15, 2013, 11:09:59 PM
Vroom vroom tonight for first time since August!
Post by: M4wdFab on December 16, 2013, 10:14:27 AM
new trans in back of ZJ
Post by: M4wdFab on December 20, 2013, 11:54:51 AM
did some procrastination on this last night, stripped all tins, pulled the battery.  Was whipped from playing truck / trailer / buggy shuffle in the lot
Post by: M4wdFab on December 21, 2013, 12:28:06 AM
Motor pulled
Post by: M4wdFab on December 21, 2013, 01:14:05 PM
Two hours powerwashing.  Roller thats sparkly newish clean!
Post by: M4wdFab on December 21, 2013, 11:32:48 PM
Wire wheeled, welds inspected, chassis painted hammared black, new rear shocks in.
Couple snags with trans.  Managed to snap trans temp sensor and need a different filter for dedp pan extension.
Post by: rejeep on December 22, 2013, 08:17:03 AM
Did I miss.. Is this sold or?
Post by: M4wdFab on December 22, 2013, 10:10:49 AM
will be up for sale.  race prepping and cleaning it up.
Post by: M4wdFab on December 22, 2013, 10:36:33 AM
i have wasted 3 fucking hours trying to find an application lookup for a TF727 or 904 transmission filter to see if stupid stores have one
ridiculous
Post by: mr.mindless on December 22, 2013, 02:39:51 PM
727 is in a million things (roughly 1968?-1988 smallblock anything, from there to 96 is A518 same case w OD tail housing. 84 ram charger 360 is a guaranteed good lookup) and I probably have a filter in the shelf - but wtf are you looking at mopar tranny stuff for?
Tapatalk (http://tapatalk.com/m?id=1)ing in traffic
Post by: M4wdFab on December 23, 2013, 12:16:27 AM
B&M deep pan uses a mopar filter.  The filters changed over the years when the eliminsted drain plugs after justifying longef fluid changes.  I figured it out and got one close enough.  What a cluster at the shit box counter.
Post by: M4wdFab on December 23, 2013, 12:19:14 AM
Slight panic when fluid was dumping out of new trans.  A phone call later i was able to swap out a rolled oring behind a snapring with out pulling trans.  I think i would have rather set it on fire.
Post by: mr.mindless on December 23, 2013, 10:17:10 AM
eew, sounds shitty.
price just went up more, huh?
Post by: M4wdFab on December 23, 2013, 11:25:35 AM
Incomplete thought- rather set it on fire than pull the trans out.  Lucky it was an easy fix
Post by: M4wdFab on March 04, 2014, 10:02:45 PM
cranked and warmed up tonight.
looks like removing radio draw keeps the yellow top happy.
Post by: M4wdFab on March 24, 2014, 09:59:10 AM
need a nice day to take some for sale pictures!
Post by: M4wdFab on April 07, 2014, 05:24:32 PM
SOLD.
