Projects place => Projects Section => Topic started by: tony on February 28, 2015, 03:27:05 PM
New to me 2012 Chevy Silverado 1500 z71
5.3l
22k miles
All star package
Soft tonneau cover
Z71 off road package
Side steps
Towing package
locking rear diff
Not sure what gear ratio it is
Looking to add a lifetime bar and headlights.. Currently shopping trailers for after academy to move and transpo jeep
Sharp! 8)
Very nice!
Looks really nice. Let us know real life mileage numbers!
Electronic locking rear diff
is that aftermarket?
to find out what gear ratio u have, look at the RPO code list and then look at this: http://www.sierragear.com/gm-rpo-axle-ratio-identification-codes-3/
No all z71 offroad packages have them per chevy I guess eaton g80 locking diff
G80 = gov lock = limited slip if I recall right. Electronic locker would've something else.
Owners manual says eaton g80 E locker.. Not sure
http://youtu.be/KbMZ9vcYVSg
He might have a switch for the newer electric g80....
not sure much about it.. I only drove it home.
My e-locker ruled. New trucks have sweet toys.
Its a locker. Not a limited slip. I have one in my sierra.
Its complicated to explain, so google how it works. Basically when g80 notices a big difference of speed, it becomes a locker otherwise it is an open diff.
Mmmm, clutch packs on both sides of the carrier...
Good G80 video here (https://www.youtube.com/watch?v=tTGZOJQQBeE)
Informative.. So what makes this electronic then.... Seems like someone with a heavy foot can grenade this
No electronics at all in this version of the G80. The only "E" explanation that I can come up with is "Eaton".
It's a slow-speed traction device. Keep your foot out of it. :(
Nice score. You'll be very happy with that truck.
G80's work well and will last a good long while if not overly abused.
sharp truck!
Thanks all....
Just installed one of Ryans led headlights in driver side... Passenger side needs to have airbox removed to install. I will wait until I install my CAI later this week
Thanks all....
CAI is waste of $ drop in know filter does the job fine.
Found some type of Snake oil product inside my engine compartment
Those do work, up to a point.
Haven't seen one of those since the 80s
20mpg Highway my ass
Thats worse than my truck.
15-17 ya thats about what id expect
Better than mine, I'm at 13-14 with the way my wife drives
That's the average from day one.. Given I drive more city than Highway but.. I'm getting g 15-18 Highway depending on grade of road
89 octane fuel?
87.. Says I can use e85 not sure if that will be better
it will be worse
my truck is supposed to run on e85 and millage sucked
Ethanol contains fewer Btu/gallon. #science
Give the 93 a try.
Always better milage in my experience.
But almost never fewer $/mi, if that's your goal. E85 can potentially win on that front with all its fucking subsidies. I don't think its THAT cheap here in NY though.
my coworker has a 2014 f150 with the 5.0. 18.5mpg on 89. 12mpg on E85. F that
Tony,
This is the brake controller I was talking bout. IMO, the only one to get. It should be plug and play.
http://www.amazon.com/Tekonsha-90195-Electronic-Brake-Control/dp/B000P17NXQ
Thanks. Keep it in mind when I buy a trailer
Tony,
That's the same brake controller I have in my Sierra. Fantastic! Don't get anything else other than the P3.
BTW it wasnt plug n play for me. I had to splice wires together, but it was such an easy job. The wiring harness was under the dash.
...and under the hood by the fuse box. Easy.
'07+ GM made you work for it.
CAI installed .. 2 mpg more from Rochester to buffalo and back...
Hand calculated? Lieometer isn't worth anything for that.
