Projects place => Classifieds => Wanted => Topic started by: M4wdFab on September 20, 2019, 12:24:15 PM
looking for a free old steel winch cable, 5/16-3/8" need at least 40' or so of good cable
my old trailer winch is still spooled up. Should actually diagnose and see if worth fixing. that's the only steel cable I've got. I do have a used synthetic hanging around.
ya we should figure that out to see if you need my winch or not. i could use that on my equipment trailer.
I have brand new steel cable from HF 5k winch... not sure if it’s ‘strong’ enough for you
I have at least one brand new unused 3/8. Could give to mark next weekend.
the 5/8" turn buckles im planning to use are rated at 3500lbs working limit. its to run some tension cables for my Lift I beams. extra peace of mind to make the bases rock solid.
Ill take anything thats free, other wise ill find something. Matt was gona look too.
