Projects place => Projects Section => Topic started by: rejeep on May 30, 2012, 09:10:56 AM
I have always just tapped into the positive battery terminal for constant power..
is there a right way to do this? like a side block or???
just seems I have an awful lot of wires coming off the top post of my battery..
Could install a sub-panel/junction. Not sure of the tech name...
(http://t0.gstatic.com/images?q=tbn:ANd9GcSCo_rB1k5xMMerBkMEMzrgNMmCZ17BJbHKPX92hzvnWiDCctVgf03B3pw)
yeah.. I think I’m going to have to do a 6 circuit fuse panel...
I had the painless one at one point.. it was just a PITA remembering what was ignition hot, constant hot, and running the enormous length of wire all over the place..
I think BUSS makes a quick connect constant hot panel..
off the top of my head I only need around 6..
i just threw one of those out that was on the LM7 5.3
(https://images-na.ssl-images-amazon.com/images/I/21ttUtV5TgL._SX100_.jpg)
I have exactly that right there. Hate messy batteries!
it is all about the birds nest water proof fues holders and hack and taps!
Well yours runs and mine doesn't lol
i think you need to do some rock auto parts cross matching quality time and camp out at J&J to get some parts to swap
you can use this link to lookup and cross parts from Alliance Vendors..
http://www.autovalue.com/lookupparts.html
:barf:
I'm soooo glad it mostly works and I haven't been around when there have been issues.
571 has had 3 electrical issues to date:
failed tail light pigtail that shorted out ignition fuse (Tail lights moved, fixed)
Taurus fan on HI pops a 30 amp fuse (40 amp MAXI fix)
Alternator ring terminal Fail (race prep item, Both fan ground terminals also replaced)
yo cant hate
I'll go ahead and hate, that's okay. Don't confuse reliability for serviceability.
